Plex connect breaks Web station - be careful
Sorry to write this but since i have installed Plex Connect, I have lost Photostation, Phpmyadmin and all my websites in the web folder.
Now when I try to enable or disable WebStation, I get an error
I have tried many and many tips but there is no solution.
It's impossible to save anyting in "services web" ---> Echec de l'opération (1048)
I have desintalled Plex connect --> same issue
I have restarted --> same
I don't want to reinstall DSM with more than 2 go of data.
What can I do ?
Can anybody send me a fonctional httpd.conf and hhtpd.conf-user to try to fix this ?
e have both websever and phpadmin on my Mac mini that runs Plexconnect.. no problems there.. gotta be in your end  :unsure:
So could you send me your httpd.conf and hhtpd.conf-user to try to fix it ?
what is in your  /usr/syno/apache/conf/httpd.conf-user
plexconnect does not modify httpd.conf but my guess is that your /usr/syno/etc/php.ini file is corrupt due to some mysterious reason...
​can you post the content of these files here?
When I look in usr/syno/apache/conf hhtp.conf-user was a 0 byte file.
I have tried to replace original files( from install) in my conf folder
Same result
I have tried to replace original php.ini
Same result
Impossible to save my params in web station
Always the same error Echec de l'opération (1048)
so you copied a good hhtp.conf-user file? after that you need to restart the apache service or reboot the nas
/usr/syno/etc/rc.d/S97apache-user.sh restart
