Plex Connect on a QNap TS-239
Hallo,
I have a QNap TS-239 with a working Plex Media Server Version 0.9.7.12
I will test if Plex Connect work on it! But how can i do this or where must i Start.
I am not a Dev or code guru :(
but maybe is it not so difficult?
Any tip or suggestion.
THX Robi
Looking to do this as well. Would like to not have my computer on and rather just have my nas do it all. I have the QNAP t459 Pro II
I got it running on a QNAP TS809Pro.
Can't test it as I do not own an ATV3 yet.
Just had to turn off the built in webserver.
Turning off the webserver on my QNAP doesn't work in getting the PlexConnect server to run.
{/share/Public/PlexConnect] # ./PlexConnect.py
./PlexConnect.py: line 8:
PlexConnect
Sources:
inter-process-communication (queue): http://pymotw.com/2/multiprocessing/communication.html
: No such file or directory
./PlexConnect.py: line 11: import: command not found
./PlexConnect.py: line 12: import: command not found
./PlexConnect.py: line 13: from: command not found
./PlexConnect.py: line 15: import: command not found
./PlexConnect.py: line 16: import: command not found
./PlexConnect.py: line 17: import: command not found
./PlexConnect.py: line 18: from: command not found
./PlexConnect.py: line 21: syntax error near unexpected token `('
./PlexConnect.py: line 21: `def getIP_self():'
Maybe it's missing some depencies.
Best thing would be to have this integrated in the PMS as a on/off thingie. Just like the DLNA.
UPDATE --->
Reinstalled Python version 2.7... Works.. ok turned off the webserver
I've just posted a guide explaining how I got PlexConnect running on a QNAP TS-459 Pro II.
http://forums.plexapp.com/index.php/topic/70373-plexconnect-running-on-a-qnap-nas/
