Drewbie is asking you to post all of the information requested in the Read Before Posting thread at the top of the forum. This info will help us more quickly help you solve your issue. As it stands we don’t have enough to work with.
That is one problem. You need to be on 2.7x. Plexconnect does not work with Python version 3 and above. Also, I am not sure why your ip_pms and ip_dnsmaster are the same.
OK so I need to downgrade my python. I need to figure out how to do that.
What do I need to set my ip. Pms and dnsmaster to?
In settings.cfg, set your dnsmaster to either your router ip address (which is usually the ip the ATV uses when it is set to automatic) or Plexconnect’s default google ip (8.8.8.8). In the post above you have it set to the same computer that is running your PMS.
In settings.cfg, set your dnsmaster to either your router ip address (which is usually the ip the ATV uses when it is set to automatic) or Plexconnect's default google ip (8.8.8.8). In the post above you have it set to the same computer that is running your PMS.
This did not work. I tried it with both my router IP and the google ip. still over it was 42 seconds to connec to hulu and 1 min to connect to netflix. I took off manual dns and both were near instant connections.
With the limited info we have (we don’t know anything about your computer or network setup, still) I would try setting “enable Plexgdm” to true to see what happens. If that doesn’t work you will need to provide ALL of the info requested in the Read Before Posting thread, as it is apparent the dribs and drabs we have been receiving are not doing the job.
When Plexconnect is running (IE My DNS is set to same as computer with plexconnect running) I cannot connect the ATV to any other app. Not net flicks, hulu, or any app that needs internet.
At first it was connecting, just taking about 3 mins to do. Now it does not connect at all.
So I dont know really how to read the log, but i see the request going to 10.0.1.4, But my computer is set to 10.0.1.3 and the DNS on the apple tv is set to the same.
The 10.0.1.1 is the IP of the router, I tried that and 8.8.8.8, both are the same results.
