Hello, having some trouble here. Out of nowhere, my Plex has been constantly buffering for all non local users and devices.
I have tried everything under the sun and consider myself pretty good with this sort of thing. I have tried the following
• complete reinstall of Plex
• I tried downloading an older version
• I have 350 MB down and 30MB
• I have a fully loaded Mac Mini i7 with 16GB of RAM
• I have ensure that no other computer processes are running
• I have rebooted my router and computer a dozen times
This configuration has been working flawlessly for years. Any help would be appreciated, I am losing my mind.
64 bytes from 71.228.241.18: icmp_seq=0 ttl=63 time=0.640 ms
64 bytes from 71.228.241.18: icmp_seq=1 ttl=63 time=0.704 ms
64 bytes from 71.228.241.18: icmp_seq=2 ttl=63 time=0.661 ms
64 bytes from 71.228.241.18: icmp_seq=3 ttl=63 time=0.590 ms
64 bytes from 71.228.241.18: icmp_seq=4 ttl=63 time=0.657 ms
64 bytes from 71.228.241.18: icmp_seq=5 ttl=63 time=0.637 ms
64 bytes from 71.228.241.18: icmp_seq=6 ttl=63 time=0.575 ms
64 bytes from 71.228.241.18: icmp_seq=7 ttl=63 time=0.557 ms
64 bytes from 71.228.241.18: icmp_seq=8 ttl=63 time=0.592 ms
Plex reports your external IP when you go to the Web App -> Settings -> Server -> Remote Access. This is the IP you and your friends should be doing a ping on. Also, if you have NOT changed this page to use a different port (and mapped the port on your router to a static IP on your PMS machine) you should. Many ISP (internet Service Providers) are throttling the default port 32400.
Read here: https://support.plex.tv/hc/en-us/articles/200931138-Troubleshooting-Remote-Access for very basic instructions on how to do this. Scroll down to the “Manual Port Forward” section. Each router brand and model is a little different, so you will need to find the model for your specific model and read up on the process. Read it first, read on the page, double check the settings then commit them. You will need to read the sections for specifying an IP (Or setting a static IP) and also for mapping a port.
I edited my previous post before you were done with yours. To be clear I am using port 80, not 32400
Ping
Try rebooting any switches or routers you have in your LAN. I’ve seen these devices cause this type of problem every once in a while and a reboot fixes the issue. Easy enough to try!
I would suggest not using port 80 as ISPs tend to throttle that as well since most (residential) ISPs usually have a clause in the terms and agreements about not running servers. Try a port in the 20,000 to 50,000 range like the link @“MikeG6.5” posted suggests.
