Plex Constantly [Full] Library Scanning
Server Version#: 1.41.8.9834
Since yesterday, my Plex library has been full library scanning. I have tried to use Chuck Pa’s DB tool. I have rebooted my entire unraid server. Nothing seems to work. I have not made any changes that I’m aware of that would trigger these full library scans.
It appears to be looping as I’ve noticed it’s scanning over the same movies/shows/libraries over and over.
Please help!
Server DEBUG logs ZIP file please ?
(this will contain the scanner logs too)
Plex Media Server Logs_2025-06-24_12-11-08.zip (5.1 MB)
@phishyphun
Thanks for the logs.
PMS is attempting to scan the media but Unraid is unable to complete the scan
Jun 24, 2025 12:09:46.423 [23284410592056] ERROR - ETP: Uncaught exception in I/O service: thread constructor failed: Resource temporarily unavailable
Jun 24, 2025 12:09:46.424 [23284410592056] DEBUG - Push: Processing new content in section 6 for 34 users.
Jun 24, 2025 12:09:46.424 [23284410592056] DEBUG - Push: There are 0 new top level things for filter '0' (movie.addedAt>>=1750739090&sort=movie.addedAt:desc&type=1).
Jun 24, 2025 12:09:46.425 [23284451138360] DEBUG - Skipping over directory 'FLCL (2000)/Season 04', as nothing has changed; removing 3 media items from map.
Jun 24, 2025 12:09:46.425 [23284451138360] DEBUG - Activity: updated activity 9bc322a1-5116-4e3a-9e1a-a79afa0870a5 - completed 42.7% - Scanning Anime
Jun 24, 2025 12:09:46.425 [23284451138360] DEBUG - Scanner: Processing directory /media/tv-anime/FLCL (2000)/Season 05 (parent: yes)
Jun 24, 2025 12:09:46.425 [23284410592056] DEBUG - Push: There are 0 new top level things for filter '0x152d0c2fd138' (movie.addedAt>>=1750739090&sort=movie.addedAt:desc&type=1).
Jun 24, 2025 12:09:46.426 [23284410592056] DEBUG - Push: There are 0 new top level things for filter '0x152d0ad46ba8' (movie.addedAt>>=1750739090&sort=movie.addedAt:desc&type=1).
Jun 24, 2025 12:09:46.427 [23284410592056] ERROR - ETP: Uncaught exception in I/O service: thread constructor failed: Resource temporarily unavailable
Jun 24, 2025 12:09:46.427 [23284410592056] DEBUG - Push: Processing new content in section 1 for 48 users.
Jun 24, 2025 12:09:46.428 [23284410592056] DEBUG - Push: There are 0 new top level things for filter '0' (movie.addedAt>>=1750738789&sort=movie.addedAt:desc&type=1).
Jun 24, 2025 12:09:46.428 [23284451138360] DEBUG - Skipping over directory 'FLCL (2000)/Season 05', as nothing has changed; removing 3 media items from map.
Jun 24, 2025 12:09:46.429 [23284451138360] DEBUG - Activity: updated activity 9bc322a1-5116-4e3a-9e1a-a79afa0870a5 - completed 43.3% - Scanning Anime
Jun 24, 2025 12:09:46.429 [23284410592056] DEBUG - Push: There are 0 new top level things for filter '0x152d27fdde68' (movie.addedAt>>=1750738789&sort=movie.addedAt:desc&type=1).
Jun 24, 2025 12:09:46.429 [23284451138360] DEBUG - Scanner: Processing directory /media/tv-anime/Samurai Champloo (2004) (parent: yes)
Jun 24, 2025 12:09:46.430 [23284410592056] DEBUG - Push: There are 0 new top level things for filter '0x152d0c305218' (movie.addedAt>>=1750738789&sort=movie.addedAt:desc&type=1).
Jun 24, 2025 12:09:46.430 [23284410592056] ERROR - ETP: Uncaught exception in I/O service: thread constructor failed: Resource temporarily unavailable
Jun 24, 2025 12:09:46.430 [23284410592056] DEBUG - Push: Processing new content in section 6 for 34 users.
You have a volume which is offline but still referred to in PMS ?
Do you have a thread limits on the container ?
I do not have a volume offline.
I do not have a thread limiter on the container.
I remapped my folders for each library to see if that would help, but I just went through each library and all were correctly mapped.
@ChuckPa
Would you mind asking the Unraid folks what that error means?
What PMS is telling us is :
  1. It wants to start another processing thread to scan/do something else
    ( In Linux terms, it want’s to perform some variant of fork() )
  2. Unraid is saying “No, No resources”
Possibilities (to my knowlege)
  1. System-wide thread count limit
  2. Insufficient memory
  3. Insufficient swap (to allocate but not use)
When did you upgrade to 1.41.8 ?
Did you ever see any behavior like this on any version prior ?
Not really sure who to take this to. Should I take to Unraid forums? Plex > Unraid forum?
I upgraded probably morning after it was released to public.
Never seen behavior like this.
I downgraded just now to 1.41.7 and it was quiet for a minute then started scanning again.
I’d not recommend using 1.41.7 due to the known DB problems.
Would you be willing to downgrade to
  1. 1.41.6.9685-d301f511a
    -or-
  2. 1.41.5.9522-a96edc606
(change the version in the container definition and let it pull new code only)
If it reoccurs, then we know it’s a system limit problem with unraid
ALSO,
check what unraid is reporting for max-threads
[chuck@lizum ~.2004]$ cat /proc/sys/kernel/threads-max
510292
[chuck@lizum ~.2005]$ free -m
               total        used        free      shared  buff/cache   available
Mem:           63868       13339        7562         358       42967       49473
Swap:          61034         222       60812
[chuck@lizum ~.2006]$
EDIT:
root@Gerbil:~# cat /proc/sys/kernel/threads-max
255697
root@Gerbil:~# uname -a
Linux Gerbil 6.6.78-Unraid #2 SMP PREEMPT_DYNAMIC Thu Feb 20 13:33:15 PST 2025 x86_64 Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz GenuineIntel GNU/Linux
root@Gerbil:~#
root@WillyCloud:~# cat /proc/sys/kernel/threads-max
511355
root@WillyCloud:~# free -m
Mem:           64082       17283        1647        1204       47118       46798
Swap:              0           0           0
511355
root@WillyCloud:~# uname -a
Linux WillyCloud 6.12.24-Unraid #1 SMP PREEMPT_DYNAMIC Sat May  3 00:12:52 PDT 2025 x86_64 12th Gen Intel(R) Core(TM) i5-12600K GenuineIntel GNU/Linux
root@WillyCloud:~#
I’ve also downgraded to 1.41.6.9685-d301f511a. Same issue.
You have no swapfile / partition defined ?
I honestly don’t know what that means. As far as I know, I’ve never had one.
Then I recommend asking further in the Unraid - Plex forum.
All indications are you’ve run out of virtual memory or threads.
I highly doubt you’ve run out of threads.
I’ve started a thread here:
https://forums.unraid.net/topic/191460-issues-with-plex-constantly-full-library-scanning/
Not sure if they’ll know what to do with this info. Did I word it correctly?
That was good.
I replied as well.
So I went ahead and stopped all containers but Plex and all was fine.
Slowly introduced each container and found the problem container.
It was Soulseek.
I have never had problems in the many years I’ve used, but sure enough as soon as I ran it, a library scan would trigger.
Deleted and installed more modern container/app version “slskd” and we’re all good!
Confirmed , not a Plex problem?
Thanks for updating us.
Please mark solved appropriately.
Confirmed not a Plex problem. Thanks for your help!
