every time plex crashing and i sow the message
( There was an unexpected error loading this library )
anyone can help me
Mind sharing some more details on your setup?
e.g. which Windows version do you have installed, which version of PMS? Some more details under what circumstances you get that error message?
Can you share your logs?
its running as a service
Drive D is an ssd localy attached
its in data center with public ip
anything about the specific questions above?
Under what circumstances do you get this error?
The server itself appears to be running and playing content ok… there’s a number of occasional network issues, indicating the remote access isn’t properly setup (resulting in using a relayed connection)
how i can fix this problams
Please check and follow the instructions in the troubleshooting for remote access (with regards to the use of a relayed connection).
