Server Version#: 1.41.5.9522
Player Version#: N/A
I have been running the plexpass Docker container for years now, with virtually no issues. The last three nights I have woken up to the container reporting unhealthy, and Plex no longer operating. I have captured the log from the most recent crash; the container reported as unhealthy at 5:04am, but the log continues to show Plex having activity of some sort. Included below is a clip of the log from around the time of the crash. I didn’t save the logs from the previous nights, but will do so again tonight if it crashes again.
I have not made any significant changes to my system in the last few weeks, there is no obvious cause for what has made it start crashing other than perhaps new media which is causing instability.
Mar 07, 2025 05:03:50.804 [138323779660600] DEBUG - [Now] Removing idle session for device w4h0c4op5d77rxkfbx3u2eo7_Video.
Mar 07, 2025 05:03:50.804 [138323779660600] DEBUG - Statistics: (grnthgqfd9qmtjnncvy1d9hk) Reporting active playback in state 3 of type 4 (scrobble: 0) for account 3565440
Mar 07, 2025 05:04:04.685 [138323897101112] DEBUG - Shutting down idle session sidnn0kd1thh1otvo7gvwfoc (idle time is 180 seconds)
Mar 07, 2025 05:04:04.685 [138323897101112] DEBUG - Killing job.
Mar 07, 2025 05:04:04.685 [138323897101112] DEBUG - Signalling job ID 157343 with 9
Mar 07, 2025 05:04:04.685 [138323897101112] DEBUG - Job was already killed, not killing again.
Mar 07, 2025 05:04:04.685 [138323897101112] DEBUG - Stopping transcode session sidnn0kd1thh1otvo7gvwfoc
Mar 07, 2025 05:04:04.685 [138323762883384] DEBUG - Cleaning directory for session sidnn0kd1thh1otvo7gvwfoc (/transcode/Transcode/Sessions/plex-transcode-sidnn0kd1thh1otvo7gvwfoc-5b27a409-4780-4e2a-ab1b-5ab11e1dec1d)
Mar 07, 2025 05:04:04.688 [138324037610296] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 157343 is -9 (signal: Killed)
Mar 07, 2025 05:04:04.692 [138323897101112] DEBUG - Whacked session sidnn0kd1thh1otvo7gvwfoc, 1 remaining.
Mar 07, 2025 05:04:04.692 [138323897101112] DEBUG - Killed 1 idle sessions out of a total of 2.
Mar 07, 2025 05:04:04.700 [138323762883384] DEBUG - Cleaning directory for session sidnn0kd1thh1otvo7gvwfoc (/transcode/Transcode/Sessions/plex-transcode-sidnn0kd1thh1otvo7gvwfoc-5b27a409-4780-4e2a-ab1b-5ab11e1dec1d)
Mar 07, 2025 05:04:19.839 [138323762883384] DEBUG - [Req#11572b/Transcode] Streaming Resource: Timing out session 0x7dce0ce0bcc8:w4h0c4op5d77rxkfbx3u2eo7
Mar 07, 2025 05:04:19.839 [138323762883384] DEBUG - [Req#11572b/Transcode] Streaming Resource: Terminating session 0x7dce0ce0bcc8:w4h0c4op5d77rxkfbx3u2eo7 which is using 3266kbps of WAN bandwidth. Used is now 0kbps
Mar 07, 2025 05:04:19.839 [138323762883384] DEBUG - [Req#11572b/Transcode] Streaming Resource: Terminated session 0x7dce0ce0bcc8:w4h0c4op5d77rxkfbx3u2eo7 with reason Client stopped playback.
Mar 07, 2025 05:04:19.839 [138323762883384] DEBUG - [Req#11572b/Transcode] Streaming Resource: Removing session 0x7dce0ce0bcc8:w4h0c4op5d77rxkfbx3u2eo7
Mar 07, 2025 05:05:18.884 [138323779660600] DEBUG - Butler: Starting delayed task ButlerTaskGenerateCreditsMarkers.
Mar 07, 2025 05:15:18.861 [138323712551736] DEBUG - PublicAddressManager: Obtaining public address and mapping port.
Mar 07, 2025 05:15:18.861 [138323712551736] DEBUG - PublicAddressManager: Obtaining public IP.
Mar 07, 2025 05:15:18.861 [138323712551736] DEBUG - [HCl#11be] HTTP requesting GET https://v4.plex.tv/pms/:/ip
Mar 07, 2025 05:15:19.378 [138323997764408] DEBUG - [HttpClient/HCl#11be] HTTP/1.1 (0.5s) 200 response from GET https://v4.plex.tv/pms/:/ip
Mar 07, 2025 05:15:19.378 [138323712551736] DEBUG - PublicAddressManager: Got public IP from v4.plex.tv: <redacted>
Mar 07, 2025 05:15:31.390 [138323712551736] DEBUG - NAT: UPnP, getPublicIP didn't find usable IGD.
Mar 07, 2025 05:15:31.641 [138323712551736] WARN - NAT: PMP, got an error: Not Supported by gateway.
Mar 07, 2025 05:15:31.641 [138323712551736] DEBUG - [HCl#11bf] HTTP requesting GET https://<redacted>.plex.direct:32400/identity
Mar 07, 2025 05:15:34.647 [138323997764408] DEBUG - [HttpClient/HCl#11bf] HTTP simulating 408 after curl timeout
Mar 07, 2025 05:15:34.648 [138323712551736] DEBUG - MyPlex: mapping state set to 'Mapped - Not Published'.
Mar 07, 2025 05:15:34.649 [138323712551736] DEBUG - MyPlex: Updating device connections (from timer: 0)
Mar 07, 2025 05:15:34.649 [138323712551736] DEBUG - [HCl#11c0] HTTP requesting PUT https://plex.tv/devices/d1f7f58bcaaccec0911ea2b9f47f719748f614e9?Connection[][uri]=http://<redacted>:32400&Connection[][uri]=http://172.21.0.4:32400&httpsEnabled=1&httpsRequired=0&dnsRebindingProtection=0&natLoopbackSupported=0&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Mar 07, 2025 05:15:35.259 [138323997764408] DEBUG - [HttpClient/HCl#11c0] HTTP/1.1 (0.6s) 200 response from PUT https://plex.tv/devices/d1f7f58bcaaccec0911ea2b9f47f719748f614e9?Connection[][uri]=http://<redacted>:32400&Connection[][uri]=http://<redacted>:32400&httpsEnabled=1&httpsRequired=0&dnsRebindingProtection=0&natLoopbackSupported=0&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Mar 07, 2025 05:18:27.431 [138323796437816] DEBUG - [Req#11730f/ViewStateSync] Starting
Mar 07, 2025 05:18:27.431 [138323796437816] DEBUG - [Req#11730f/ViewStateSync] Fetching user tokens
Mar 07, 2025 05:18:27.432 [138323796437816] DEBUG - [Req#11730f/ViewStateSync/HCl#11c1] HTTP requesting GET https://plex.tv/api/v2/server/users/services?auth_token=xxxxxxxxxxxxxxxxxxxx
Mar 07, 2025 05:18:28.118 [138323997764408] DEBUG - [HttpClient/HCl#11c1] HTTP/1.1 (0.7s) 200 response from GET https://plex.tv/api/v2/server/users/services?auth_token=xxxxxxxxxxxxxxxxxxxx
Mar 07, 2025 06:00:18.910 [138323779660600] DEBUG - Butler: we're outside the window, stopping.
Mar 07, 2025 06:15:17.520 [138323813215032] DEBUG - BPQ: garbageCollect - version - not forced - -1
Mar 07, 2025 06:15:17.520 [138323813215032] DEBUG - Versions: garbage collecting
Mar 07, 2025 06:15:17.573 [138323796437816] DEBUG - [CERT/OCSP/HCl#11c2] HTTP requesting GET http://r11.o.lencr.org/MFMwUTBPME0wSzAJBgUrDgMCGgUABBQaUrm0WeTDM5ghfoZtS72KO9ZnzgQUCLkRO6XQhRi06g%2BgrZ%2BGHo78OCcCEgPGN7QZDVSZahKu8XmELHD53g%3D%3D
Mar 07, 2025 06:15:17.832 [138323997764408] DEBUG - [HttpClient/HCl#11c2] HTTP/1.1 (0.3s) 200 response from GET http://r11.o.lencr.org/MFMwUTBPME0wSzAJBgUrDgMCGgUABBQaUrm0WeTDM5ghfoZtS72KO9ZnzgQUCLkRO6XQhRi06g%2BgrZ%2BGHo78OCcCEgPGN7QZDVSZahKu8XmELHD53g%3D%3D
Mar 07, 2025 06:15:17.832 [138323796437816] INFO - [CERT/OCSP] Successfully retrieved response.
Mar 07, 2025 06:15:18.520 [138323813215032] DEBUG - 6 threads are waiting on db connections held by threads: 138323716746040,138323788049208,138323788049208,138323788049208,138323788049208,138323788049208,138323788049208,138323788049208,138323788049208,138323788049208,138323788049208,138323788049208,138323788049208,138323788049208,138323788049208,138323788049208,138323788049208,138323788049208,138323788049208,138323788049208
Mar 07, 2025 06:15:18.694 [138323800632120] DEBUG - [HCl#11c3] HTTP requesting GET https://plex.tv/api/v2/user?includeSubscriptions=1&includeProviders=1
Mar 07, 2025 06:15:18.931 [138323712551736] DEBUG - PublicAddressManager: Obtaining public address and mapping port.
Mar 07, 2025 06:15:18.931 [138323712551736] DEBUG - PublicAddressManager: Obtaining public IP.
Mar 07, 2025 06:15:18.931 [138323712551736] DEBUG - [HCl#11c4] HTTP requesting GET https://v4.plex.tv/pms/:/ip
Mar 07, 2025 06:15:19.195 [138323779660600] DEBUG - [HCl#11c5] HTTP requesting GET https://plex.tv/api/taas/profile
Mar 07, 2025 06:15:19.279 [138323997764408] DEBUG - [HttpClient/HCl#11c3] HTTP/1.1 (0.6s) 200 response from GET https://plex.tv/api/v2/user?includeSubscriptions=1&includeProviders=1
