Plex crashing my hole home server
Server Version#: 1.19.4.2902-69560ce1e
Player Version#: 4.30.2
OS Version: Ubuntu 18.04 LTS
OK so today I had two streams running for both movies in 1080p, and my friend informed me that the server crash. I check it out and it was not just Plex that crash but the hole server. My website was down for like 2 minutes, and all my other services as well. I check the logs but I’m not good at reading them. But here is what I found. We can clearly see that the no logs are being log to the syslog file for at least 3 minutes.
If you need any additional detail, let me know!
LOGS
Blockquote Jun 3 21:57:41 corius-server systemd-resolved[809]: Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.
Jun 3 21:58:01 corius-server CRON[2907]: (creative) CMD (/home/creative/mcserver monitor > /dev/null 2>&1)
Jun 3 21:58:01 corius-server CRON[2908]: (will-server) CMD (/home/will-server/mcserver monitor > /dev/null 2>&1)
Jun 3 21:59:01 corius-server CRON[3967]: (will-server) CMD (/home/will-server/mcserver monitor > /dev/null 2>&1)
Jun 3 21:59:01 corius-server CRON[3966]: (creative) CMD (/home/creative/mcserver monitor > /dev/null 2>&1)
Jun 3 21:59:15 corius-server kernel: [ 1955.474977] show_signal_msg: 3 callbacks suppressed
Jun 3 21:59:15 corius-server kernel: [ 1955.474979] Plex Transcoder[4865]: segfault at 7f8212047a9c ip 00007f8212047a9c sp 00007f81ddff20c0 error 7 in liblibx264_encoder.so[7f8211fa8000+1c1000]
Jun 3 22:02:54 corius-server systemd-modules-load[467]: Inserted module ‘iscsi_tcp’
Jun 3 22:02:54 corius-server kernel: [ 0.000000] microcode: microcode updated early to revision 0xd6, date = 2019-10-03
Jun 3 22:02:54 corius-server systemd-modules-load[467]: Inserted module ‘ib_iser’
Jun 3 22:02:54 corius-server kernel: [ 0.000000] Linux version 4.15.0-101-generic (buildd@lgw01-amd64-003) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)) #102-Ubuntu SMP Mon May 11 10:07:26 UTC 2020 (Ubuntu 4.15.0-101.102-generic 4.15.18)
Jun 3 22:02:54 corius-server systemd[1]: Started Create Static Device Nodes in /dev.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-101-generic root=UUID=6e7ff810-ff55-401d-92d1-efc4eb693665 ro
Jun 3 22:02:54 corius-server kernel: [ 0.000000] KERNEL supported cpus:
Jun 3 22:02:54 corius-server systemd[1]: Starting udev Kernel Device Manager…
Jun 3 22:02:54 corius-server kernel: [ 0.000000] Intel GenuineIntel
Jun 3 22:02:54 corius-server kernel: [ 0.000000] AMD AuthenticAMD
Jun 3 22:02:54 corius-server kernel: [ 0.000000] Centaur CentaurHauls
Jun 3 22:02:54 corius-server kernel: [ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
Jun 3 22:02:54 corius-server kernel: [ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
Jun 3 22:02:54 corius-server systemd[1]: Starting Flush Journal to Persistent Storage…
Jun 3 22:02:54 corius-server kernel: [ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
Jun 3 22:02:54 corius-server kernel: [ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: ‘MPX bounds registers’
Jun 3 22:02:54 corius-server systemd[1]: Started Set the console keyboard layout.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: ‘MPX CSR’
Jun 3 22:02:54 corius-server kernel: [ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Jun 3 22:02:54 corius-server kernel: [ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
Jun 3 22:02:54 corius-server kernel: [ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
Jun 3 22:02:54 corius-server systemd[1]: Started Load/Save Random Seed.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using ‘compacted’ format.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] e820: BIOS-provided physical RAM map:
Jun 3 22:02:54 corius-server systemd[1]: Started Apply Kernel Variables.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009efff] usable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000828d3fff] usable
Jun 3 22:02:54 corius-server systemd[1]: Started Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x00000000828d4000-0x00000000828d4fff] ACPI NVS
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x00000000828d5000-0x00000000828d5fff] reserved
Jun 3 22:02:54 corius-server systemd[1]: Reached target Local File Systems (Pre).
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x00000000828d6000-0x0000000089f7cfff] usable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x0000000089f7d000-0x000000008a2c9fff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x000000008a2ca000-0x000000008a405fff] usable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x000000008a406000-0x000000008ab0dfff] ACPI NVS
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x000000008ab0e000-0x000000008b3fefff] reserved
Jun 3 22:02:54 corius-server systemd[1]: Started udev Kernel Device Manager.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x000000008b3ff000-0x000000008b3fffff] usable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x000000008b400000-0x000000008fffffff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
Jun 3 22:02:54 corius-server systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Jun 3 22:02:54 corius-server systemd[1]: Reached target Local Encrypted Volumes.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000046effffff] usable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] NX (Execute Disable) protection: active
Jun 3 22:02:54 corius-server kernel: [ 0.000000] e820: update [mem 0x821ae018-0x821be057] usable ==> usable
Jun 3 22:02:54 corius-server systemd[1]: Activated swap /swap.img.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] e820: update [mem 0x82986018-0x82992057] usable ==> usable
Jun 3 22:02:54 corius-server systemd[1]: Reached target Swap.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] extended physical RAM map:
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x0000000000000000-0x0000000000057fff] usable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x0000000000058000-0x0000000000058fff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x0000000000059000-0x000000000009efff] usable
Jun 3 22:02:54 corius-server systemd[1]: Started Flush Journal to Persistent Storage.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x000000000009f000-0x00000000000fffff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x0000000000100000-0x00000000821ae017] usable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x00000000821ae018-0x00000000821be057] usable
Jun 3 22:02:54 corius-server systemd-udevd[513]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x00000000821be058-0x00000000828d3fff] usable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x00000000828d4000-0x00000000828d4fff] ACPI NVS
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x00000000828d5000-0x00000000828d5fff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x00000000828d6000-0x0000000082986017] usable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x0000000082986018-0x0000000082992057] usable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x0000000082992058-0x0000000089f7cfff] usable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x0000000089f7d000-0x000000008a2c9fff] reserved
Jun 3 22:02:54 corius-server systemd-udevd[517]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x000000008a2ca000-0x000000008a405fff] usable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x000000008a406000-0x000000008ab0dfff] ACPI NVS
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x000000008ab0e000-0x000000008b3fefff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x000000008b3ff000-0x000000008b3fffff] usable
Jun 3 22:02:54 corius-server systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x000000008b400000-0x000000008fffffff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x00000000e0000000-0x00000000efffffff] reserved
Jun 3 22:02:54 corius-server systemd[1]: Reached target Sound Card.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
Jun 3 22:02:54 corius-server systemd[1]: Found device Expansion_Desk Seagate_Expansion_Drive.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000046effffff] usable
Jun 3 22:02:54 corius-server systemd[1]: Mounting /home/Media…
Jun 3 22:02:54 corius-server kernel: [ 0.000000] efi: EFI v2.50 by American Megatrends
Jun 3 22:02:54 corius-server systemd[1]: Found device KINGSTON_SA400S37240G 1.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] efi: ACPI 2.0=0x8a406000 ACPI=0x8a406000 SMBIOS=0x8b2b7000 MPS=0xfc9e0 ESRT=0x883a2858
Jun 3 22:02:54 corius-server kernel: [ 0.000000] secureboot: Secure boot disabled
Jun 3 22:02:54 corius-server kernel: [ 0.000000] SMBIOS 3.0 present.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] DMI: MSI MS-7977/Z170A GAMING M5 (MS-7977), BIOS 1.G0 12/07/2017
Jun 3 22:02:54 corius-server kernel: [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Jun 3 22:02:54 corius-server systemd[1]: Starting File System Check on /dev/disk/by-uuid/EF0E-7312…
Jun 3 22:02:54 corius-server kernel: [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
Jun 3 22:02:54 corius-server systemd[1]: Started File System Check Daemon to report status.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] e820: last_pfn = 0x46f000 max_arch_pfn = 0x400000000
Jun 3 22:02:54 corius-server kernel: [ 0.000000] MTRR default type: write-back
Jun 3 22:02:54 corius-server kernel: [ 0.000000] MTRR fixed ranges enabled:
Jun 3 22:02:54 corius-server systemd-fsck[578]: fsck.fat 4.1 (2017-01-24)
Jun 3 22:02:54 corius-server kernel: [ 0.000000] 00000-9FFFF write-back
Jun 3 22:02:54 corius-server kernel: [ 0.000000] A0000-BFFFF uncachable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] C0000-FFFFF write-protect
Jun 3 22:02:54 corius-server systemd-fsck[578]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] MTRR variable ranges enabled:
Jun 3 22:02:54 corius-server systemd-fsck[578]: Automatically removing dirty bit.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] 0 base 00C0000000 mask 7FC0000000 uncachable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] 1 base 00A0000000 mask 7FE0000000 uncachable
Jun 3 22:02:54 corius-server systemd-fsck[578]: Performing changes.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] 2 base 0090000000 mask 7FF0000000 uncachable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] 3 base 008C000000 mask 7FFC000000 uncachable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] 4 base 008B800000 mask 7FFF800000 uncachable
Jun 3 22:02:54 corius-server kernel: [ 0.000000] 5 disabled
Jun 3 22:02:54 corius-server systemd-fsck[578]: /dev/sdb1: 10 files, 1538/130812 clusters
Jun 3 22:02:54 corius-server kernel: [ 0.000000] 6 disabled
Jun 3 22:02:54 corius-server kernel: [ 0.000000] 7 disabled
Jun 3 22:02:54 corius-server kernel: [ 0.000000] 8 disabled
Jun 3 22:02:54 corius-server kernel: [ 0.000000] 9 disabled
Jun 3 22:02:54 corius-server kernel: [ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
Jun 3 22:02:54 corius-server kernel: [ 0.000000] e820: last_pfn = 0x8b400 max_arch_pfn = 0x400000000
Jun 3 22:02:54 corius-server kernel: [ 0.000000] found SMP MP-table at [mem 0x000fcc10-0x000fcc1f]
Jun 3 22:02:54 corius-server systemd[1]: Started File System Check on /dev/disk/by-uuid/EF0E-7312.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] esrt: Reserving ESRT space from 0x00000000883a2858 to 0x00000000883a2890.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] e820: update [mem 0x883a2000-0x883a2fff] usable ==> reserved
Jun 3 22:02:54 corius-server kernel: [ 0.000000] Scanning 1 areas for low memory corruption
Jun 3 22:02:54 corius-server kernel: [ 0.000000] Using GB pages for direct mapping
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BRK [0x32e391000, 0x32e391fff] PGTABLE
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BRK [0x32e392000, 0x32e392fff] PGTABLE
Jun 3 22:02:54 corius-server systemd[1]: Mounting /boot/efi…
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BRK [0x32e393000, 0x32e393fff] PGTABLE
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BRK [0x32e394000, 0x32e394fff] PGTABLE
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BRK [0x32e395000, 0x32e395fff] PGTABLE
Jun 3 22:02:54 corius-server systemd[1]: Mounted /boot/efi.
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BRK [0x32e396000, 0x32e396fff] PGTABLE
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BRK [0x32e397000, 0x32e397fff] PGTABLE
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BRK [0x32e398000, 0x32e398fff] PGTABLE
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BRK [0x32e399000, 0x32e399fff] PGTABLE
Jun 3 22:02:54 corius-server ntfs-3g[619]: Version 2017.3.23 integrated FUSE 28
Jun 3 22:02:54 corius-server ntfs-3g[619]: Mounted /dev/sda2 (Read-Write, label “Seagate Expansion Drive”, NTFS 3.1)
Jun 3 22:02:54 corius-server ntfs-3g[619]: Cmdline options: rw,nosuid,nodev,default_permissions
Jun 3 22:02:54 corius-server ntfs-3g[619]: Mount options: rw,nosuid,nodev,allow_other,nonempty,default_permissions,relatime,fsname=/dev/sda2,blkdev,blksize=4096
Jun 3 22:02:54 corius-server ntfs-3g[619]: Ownership and permissions disabled, configuration type 7
Jun 3 22:02:54 corius-server systemd[1]: Mounted /home/Media.
Jun 3 22:02:54 corius-server systemd[1]: Reached target Local File Systems.
Jun 3 22:02:54 corius-server systemd[1]: Starting Set console font and keymap…
Jun 3 22:02:54 corius-server systemd[1]: Starting Tell Plymouth To Write Out Runtime Data…
Jun 3 22:02:54 corius-server systemd[1]: Starting ebtables ruleset management…
Jun 3 22:02:54 corius-server systemd[1]: Starting AppArmor initialization…
Jun 3 22:02:54 corius-server systemd[1]: Starting Enable support for additional executable binary formats…
Jun 3 22:02:54 corius-server systemd[1]: Starting Create Volatile Files and Directories…
Jun 3 22:02:54 corius-server systemd[1]: Started Set console font and keymap.
Jun 3 22:02:54 corius-server systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 642 (update-binfmts)
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BRK [0x32e39a000, 0x32e39afff] PGTABLE
Jun 3 22:02:54 corius-server kernel: [ 0.000000] BRK [0x32e39b000, 0x32e39bfff] PGTABLE
Jun 3 22:02:54 corius-server systemd[1]: Mounting Arbitrary Executable File Formats File System…
