Plex Crashing on Win10 lock
Ever since the latest update (plex), my plex server, which is running on a win10 box, crashes when I lock the PC. Once the pc is unlocked, I have to open plex back up and wait. This is utterly annoying and I have yet to find an answer to the problem, only others facing the same.
I am experiencing the exact same issue
If anyone has a work around or fix… please let us know.
no one at plex.tv even exists to assist with technical issues… they need a tech support division or we’ll all switch to kodi
I’m having the same issue. It started after I updated the Plex server on a Windows 10 system. Plex will all of a sudden stop playing on the Roku and I have to login to the PC server and reopen Plex. I’ve never had this issue in the 7 years of using Plex until I updated 3 days ago.
I’ve checked for conflicting .dll files and nothing comes up as interfering with Plex. There’s no contact info for Plex, which is beyond frustrating. As of the last month or so, my plex server has been down as it crashes daily anyway… I can update until I turn blue, but never once does an update hint at fixing said problem. Plex, contact me somehow so I can actually use your product or I’ll move to another platform.
Please see https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
and also please ensure you have not disabled crash reporting - within same server setting page
After a crash, restart the server and download the logs and upload the zip here
See
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
After non stop pointless updates, I nuked plex and started over. Problem solved in regards to an unstable build. A new problem has arisen though… for the life of me I can’t get my double nat to take with thew new install. FRUSTRATING.
