Plex crashing, segmentation fault
Server Version#: 1.24.3.5033
Player Version#: 8.23.1.28053 (Android) and web
Plex is randomly crashing. Looks like some sort of segmentation fault. Logs and dump are attached.
Journalctl output:
[1]: plexmediaserver.service: Main process exited, code=killed, status=11/SEGV
Oct 09 02:56:59 europa systemd[1]: plexmediaserver.service: State 'stop-sigt[Plex Media Server Logs_2021-10-09_03-20-22.zip|attachment](upload://bXGXw0QrdKW8dUqMTDfSHd0TNeC.zip) (2.0 MB)
erm' timed out. Killing.
Oct 09 02:56:59 europa systemd[1]: plexmediaserver.service: Killing process 132200 (Plex Script Hos) with signal SIGKILL.
Oct 09 02:56:59 europa systemd[1]: plexmediaserver.service: Killing process 132283 (Plex Script Hos) with signal SIGKILL.
Oct 09 02:56:59 europa systemd[1]: plexmediaserver.service: Killing process 132290 (Plex Relay) with signal SIGKILL.
Oct 09 02:56:59 europa systemd[1]: plexmediaserver.service: Killing process 132217 (Plex Script Hos) with signal SIGKILL.
Oct 09 02:56:59 europa systemd[1]: plexmediaserver.service: Killing process 132229 (Plex Script Hos) with signal SIGKILL.
Oct 09 02:56:59 europa systemd[1]: plexmediaserver.service: Killing process 132233 (Plex Script Hos) with signal SIGKILL.
Oct 09 02:56:59 europa systemd[1]: plexmediaserver.service: Killing process 132294 (Plex Script Hos) with signal SIGKILL.
Oct 09 02:56:59 europa systemd[1]: plexmediaserver.service: Killing process 132314 (n/a) with signal SIGKILL.
Oct 09 02:56:59 europa systemd[1]: plexmediaserver.service: Failed with result 'signal'.
Oct 09 02:57:05 europa systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 26.
Oct 09 02:57:05 europa systemd[1]: Stopped Plex Media Server.
Processing: d58d2091-50cf-48e1-bfebaa84-986fb423.dmp…
d58d2091-50cf-48e1-bfebaa84-986fb423.zip (165.2 KB)
yep me too. dmesg full of pms segfaults.
can’t seem to get through loading my dvr guide data, which is bad. willl need to see how much it’s impacted my recordings.
[209047.212421] Plex Media Serv[100660]: segfault at 94 ip 00007f8d1944ea1a sp 00007f8d13d28900 error 4 in Plex Media Server[7f8d18fac000+ba6000]
[209047.212433] Code: 85 db 74 23 48 c7 c0 ff ff ff ff f0 48 0f c1 43 08 48 85 c0 75 11 48 8b 03 48 89 df ff 50 10 48 89 df e8 09 df 6f 00 49 8b 07 <8b> 90 94 00 00 00 83 fa ff 74 73 48 8d 7d d0 4c 89 f6 e8 af 71 fb
[209448.452928] Plex Media Serv[101002]: segfault at 94 ip 00007fb74d006a1a sp 00007fb7478f2900 error 4 in Plex Media Server[7fb74cb64000+ba6000]
[209448.452937] Code: 85 db 74 23 48 c7 c0 ff ff ff ff f0 48 0f c1 43 08 48 85 c0 75 11 48 8b 03 48 89 df ff 50 10 48 89 df e8 09 df 6f 00 49 8b 07 <8b> 90 94 00 00 00 83 fa ff 74 73 48 8d 7d d0 4c 89 f6 e8 af 71 fb
[209849.469222] Plex Media Serv[101345]: segfault at 94 ip 00007fe59c6c5a1a sp 00007fe596f88900 error 4 in Plex Media Server[7fe59c223000+ba6000]
[209849.469235] Code: 85 db 74 23 48 c7 c0 ff ff ff ff f0 48 0f c1 43 08 48 85 c0 75 11 48 8b 03 48 89 df ff 50 10 48 89 df e8 09 df 6f 00 49 8b 07 <8b> 90 94 00 00 00 83 fa ff 74 73 48 8d 7d d0 4c 89 f6 e8 af 71 fb
[210250.629974] Plex Media Serv[101700]: segfault at 94 ip 00007f7e6b9caa1a sp 00007f7e655c9900 error 4 in Plex Media Server[7f7e6b528000+ba6000]
[210250.629985] Code: 85 db 74 23 48 c7 c0 ff ff ff ff f0 48 0f c1 43 08 48 85 c0 75 11 48 8b 03 48 89 df ff 50 10 48 89 df e8 09 df 6f 00 49 8b 07 <8b> 90 94 00 00 00 83 fa ff 74 73 48 8d 7d d0 4c 89 f6 e8 af 71 fb
[210651.956901] Plex Media Serv[102050]: segfault at 94 ip 00007fe5b48baa1a sp 00007fe5b0165900 error 4 in Plex Media Server[7fe5b4418000+ba6000]
[210651.956917] Code: 85 db 74 23 48 c7 c0 ff ff ff ff f0 48 0f c1 43 08 48 85 c0 75 11 48 8b 03 48 89 df ff 50 10 48 89 df e8 09 df 6f 00 49 8b 07 <8b> 90 94 00 00 00 83 fa ff 74 73 48 8d 7d d0 4c 89 f6 e8 af 71 fb
[211052.916384] Plex Media Serv[102399]: segfault at 94 ip 00007f3b9666ea1a sp 00007f3b90f5c900 error 4 in Plex Media Server[7f3b961cc000+ba6000]
[211052.916398] Code: 85 db 74 23 48 c7 c0 ff ff ff ff f0 48 0f c1 43 08 48 85 c0 75 11 48 8b 03 48 89 df ff 50 10 48 89 df e8 09 df 6f 00 49 8b 07 <8b> 90 94 00 00 00 83 fa ff 74 73 48 8d 7d d0 4c 89 f6 e8 af 71 fb
[211453.892020] Plex Media Serv[102744]: segfault at 94 ip 00007f230dbeda1a sp 00007f23084a7900 error 4 in Plex Media Server[7f230d74b000+ba6000]
[211453.892030] Code: 85 db 74 23 48 c7 c0 ff ff ff ff f0 48 0f c1 43 08 48 85 c0 75 11 48 8b 03 48 89 df ff 50 10 48 89 df e8 09 df 6f 00 49 8b 07 <8b> 90 94 00 00 00 83 fa ff 74 73 48 8d 7d d0 4c 89 f6 e8 af 71 fb
[211854.927659] Plex Media Serv[103087]: segfault at 94 ip 00007f6b392d9a1a sp 00007f6b33434900 error 4 in Plex Media Server[7f6b38e37000+ba6000]
[211854.927676] Code: 85 db 74 23 48 c7 c0 ff ff ff ff f0 48 0f c1 43 08 48 85 c0 75 11 48 8b 03 48 89 df ff 50 10 48 89 df e8 09 df 6f 00 49 8b 07 <8b> 90 94 00 00 00 83 fa ff 74 73 48 8d 7d d0 4c 89 f6 e8 af 71 fb
Still getting this after updating to newest version.
