Segfault help
version: plexmediaserver 1.21.2.3943-a91458577 amd64
segfault:
segfault at c8 ip 0000000000c04051 sp 00007f665bffb270 error 4 in Plex Media Server[a04000+f0c000]
I’m getting this error and wondering if anyone could help me resolve it? ThanksPlex Media Server Logs_2021-02-03_20-32-49.zip (1.1 MB)
DEBUG log files ZIP please?
Can’t help resolve without seeing what caused it.
Note: If you’ve turned off DEBUG logging then you need to turn it on again and wait.
INFO logging is insufficient. VERBOSE logging will cause it to get lost before we can see what happened.
DEBUG logging ON, VERBOSE logging OFF.
have attached the logs on my original post but here they are
thank you for the reply as well. have added my logs
Any reply or joy with the logs please?.
@Hhhonlyfan
Sorry , but i’ve been swamped all afternoon. Only getting a chance to sit down now (everyone gone to bed) and see what else I can get done.
@Hhhonlyfan
There are no smoking guns in your logs.
This one is going to take direct examination of a DMP file (from the Crash Reports directory).
The best way to capture these is to turn off Crash Report uploading (Settings - Server - General) and recreating / getting the next one.
When it does, grab current logs ZIP
put the DMP in a ZIP.
Upload both.
I’ll grab that version of PMS + Debug files and run the post morten here locally.
Ok sorry for the delay. Will sort this out. Been having issues so haven’t been able to log on.
Hi @ChuckPa
I’ve been working on this with OP. Here are the crash report/debug logs for today. https://down.loaded.ie/qPCgrX6V.zip
we’ve tested with upgrading back to newest release but now it’s crashing even more often, and I’m not seeing any sigterms in syslog. Appreciate any feedback on this!
edit; we’ve had to downgrade serveral versions to 1.21.1.3876-3c3adfcb4 to get things stable again.
I’m seeing this segfault as well. Will try that downgraded version. Running on Ubuntu 20.10 x86_64
@jamiew0w
Which PMS version - build hash are these from? (so I know which PMS debug symbols to download and setup with)
Hi ChuckPa!
I believe these are from 1.21.3.4014-58bd20c02, the most recent build on the apt repos.
Distributor ID:	Ubuntu
Description:	Ubuntu 20.04.2 LTS
Release:	20.04
Codename:	focal
We downgraded several versions to 1.21.1.3876-3c3adfcb4 and things appear stable for now.
If you need anything else be sure to let us know, happy to help in any way.
new segfaults found in syslog:
Feb  9 00:33:21 test kernel: [12911.215940] Plex Media Serv[460502]: segfault at c8 ip 0000000000bf1411 sp 00007f10b6ffbb70 error 4 in Plex Media Server[9f2000+ee5000]
Feb  9 13:39:50 test kernel: [60101.066045] Plex Media Serv[712125]: segfault at c8 ip 0000000000bf1411 sp 00007f92bb7fcb70 error 4 in Plex Media Server[9f2000+ee5000]
Feb  9 15:37:12 test kernel: [67142.709891] Plex Media Serv[739620]: segfault at c8 ip 0000000000bf1411 sp 00007fb9aa7fab70 error 4 in Plex Media Server[9f2000+ee5000]
Feb  9 18:40:49 test kernel: [78160.123338] Plex Media Serv[783618]: segfault at c8 ip 0000000000bf1411 sp 00007f6cd77fcb70 error 4 in Plex Media Server[9f2000+ee5000]
Feb  9 20:16:43 test kernel: [83914.516242] Plex Media Serv[791370]: segfault at c8 ip 0000000000bf1411 sp 00007f6eb0ff7b70 error 4 in Plex Media Server[9f2000+ee5000]
Feb  9 20:21:39 test kernel: [84210.060461] Plex Media Serv[807844]: segfault at c8 ip 0000000000bf1411 sp 00007fdce5ff9b70 error 4 in Plex Media Server[9f2000+ee5000]
This is on version 1.21.1.3876-3c3adfcb4 also. yikes. Nothing new in crash reports either, presumably because ist segfaulting instead of crashing.
Would you mind jumping ahead?
Go right to build 4014.
They’ve been making corrections faster than I can keep up.
If we can track one in 4014, I’ll have something to pin it on there too.
(two different versions)
Sure thing, doing so now.
edit; done - I’ll keep you posted. Thanks for your continued help ChuckPa, appreciated :slight_smile:
thanks
segfaulted immediately:
Feb  9 20:32:22 test kernel: [84853.545662] Plex Media Serv[811297]: segfault at c8 ip 0000000000c04051 sp 00007f170aff9270 error 4 in Plex Media Server[a04000+f0d000]
updated crash reports from today - https://down.loaded.ie/MQRpfITH.zip
Let me know if you need other debug logs too
MODERATOR EDIT:
PMS Crash dmp files
https://down.loaded.ie/ZSUHXevl.zip
Need your PMS Logs Dir too :slight_smile:
Thank you to you and @jamiew0w who has bene massively trying to help me get this resolved.
done and done -
MODERATOR EDIT - These are the PMS logs
https://down.loaded.ie/NSLejeXo.zip
