Plex Crashing When Users Transcode
Oh, that’s good news. This specific crash hasn’t been addressed, but another similar crash was so I’m thinking this got automagically fixed by that as well.
Looks like it’s not fixed yet. Just had another crash on 1.25.4.5487.
I’m running PMS on an Intel NUC running Windows 11 (up-to-date software, firmware, and drivers). The libraries are hosted on a Synology Disk Station running DSM 7.01 update 2
Over the past 7-10 days, the Plex process has crashed numerous times, most recently a few hours ago. The logs are riddled with Transcoding errors - hundreds and hundreds of them. I will upload the logs if anyone finds them useful?
Agreed nothing changed for me with latest PMS (1.25.5.5492)
Specifically I can enable “use hardware acceleration when available” and I see the little (hw) syntax come up on the dashboard. It appears to do partial h/w transcoding (may be just h/w decode) but not fully.
However if I also enable “use hardware accelerated video encoding” then it appears to do no h/w transcoding assist at all. It is when this is enabled that it has hung PMS in the past, so I obviously no longer run with this enabled.
Yup, I did the same - I disabled “video stream transcoding,” “use hardware acceleration when available,” and “use hardware-accelerated video transcoding” and it’s been stable for 24 hours.
Exact same crashing issue for me. Had to downgrade to 5173 in order to keep plex from crashing. I need to be able to use transcoding. PMS is also on an Intel NUC running Windows 11 (up-to-date software, firmware, and drivers). The libraries are hosted on a Synology Disk Station
I don’t believe it is fixed - I just upgraded to the 1.25.4.5487 version and it crashed when attempting to transcode. Rolling back to 1.24.5.5173 has fixed it.
Do you still have the logs from when you were on 1.25.4?
I don’t have crash logs - I just downgraded back to 1.24.5 as that was the last one I was on with zero crashes. The Media Server Log just looks like this moments before the crash
Feb 03, 2022 19:44:11.797 [11112] ERROR - SSDP: Error parsing device schema for http://192.168.1.49:8080/upnp
Feb 03, 2022 19:44:15.048 [10460] WARN - QueryParser: Invalid field ‘contentDirectoryID’ found, ignoring.
Feb 03, 2022 19:44:15.049 [10460] WARN - QueryParser: Invalid field ‘pinnedContentDirectoryID’ found, ignoring.
Feb 03, 2022 19:44:15.055 [10460] WARN - QueryParser: Invalid field ‘contentDirectoryID’ found, ignoring.
Feb 03, 2022 19:44:15.055 [10460] WARN - QueryParser: Invalid field ‘pinnedContentDirectoryID’ found, ignoring.
Feb 03, 2022 19:44:15.066 [10460] WARN - QueryParser: Invalid field ‘contentDirectoryID’ found, ignoring.
Feb 03, 2022 19:44:15.067 [10460] WARN - QueryParser: Invalid field ‘pinnedContentDirectoryID’ found, ignoring.
Feb 03, 2022 19:44:15.698 [12912] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:15.698 [12912] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:15.938 [12912] ERROR - [Transcode] [FFMPEG] - could not create MFT
Feb 03, 2022 19:44:16.201 [12912] WARN - [Transcode] Codecs: avcodec_open2 returned -40 for encoder ‘h264_mf’
Feb 03, 2022 19:44:16.202 [12912] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:16.202 [12912] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:16.202 [12912] ERROR - [Transcode] [FFMPEG] - Failed to load D3D9 library
Feb 03, 2022 19:44:16.204 [12912] INFO - [Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
Feb 03, 2022 19:44:16.465 [12912] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:16.465 [12912] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:16.684 [12912] ERROR - [Transcode] [FFMPEG] - could not create MFT
Feb 03, 2022 19:44:16.939 [12912] WARN - [Transcode] Codecs: avcodec_open2 returned -40 for encoder ‘h264_mf’
Feb 03, 2022 19:44:16.940 [12912] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:16.941 [12912] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:16.941 [12912] ERROR - [Transcode] [FFMPEG] - Failed to load D3D9 library
Feb 03, 2022 19:44:16.949 [12912] INFO - [Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
Feb 03, 2022 19:44:17.201 [12912] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:17.201 [12912] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:17.398 [12912] ERROR - [Transcode] [FFMPEG] - could not create MFT
Feb 03, 2022 19:44:17.651 [12912] WARN - [Transcode] Codecs: avcodec_open2 returned -40 for encoder ‘h264_mf’
Feb 03, 2022 19:44:17.652 [12912] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:17.652 [12912] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:17.653 [12912] ERROR - [Transcode] [FFMPEG] - Failed to load D3D9 library
Feb 03, 2022 19:44:17.655 [12912] INFO - [Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
Feb 03, 2022 19:44:17.778 [15744] WARN - [Transcode] Denying access due to session lacking permission to transcode key /library/metadata/19758
Feb 03, 2022 19:44:17.911 [12912] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:17.911 [12912] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:18.117 [12912] ERROR - [Transcode] [FFMPEG] - could not create MFT
Feb 03, 2022 19:44:18.375 [12912] WARN - [Transcode] Codecs: avcodec_open2 returned -40 for encoder ‘h264_mf’
Feb 03, 2022 19:44:18.376 [12912] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:18.376 [12912] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:18.376 [12912] ERROR - [Transcode] [FFMPEG] - Failed to load D3D9 library
Feb 03, 2022 19:44:18.378 [12912] INFO - [Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
Feb 03, 2022 19:44:18.628 [12912] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:18.628 [12912] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:18.813 [12912] ERROR - [Transcode] [FFMPEG] - could not create MFT
Feb 03, 2022 19:44:19.001 [15744] WARN - [Transcode] Denying access due to session lacking permission to transcode key /library/metadata/19758
Feb 03, 2022 19:44:19.015 [12912] WARN - [Transcode] Codecs: avcodec_open2 returned -40 for encoder ‘h264_mf’
Feb 03, 2022 19:44:19.016 [12912] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:19.016 [12912] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:19.016 [12912] ERROR - [Transcode] [FFMPEG] - Failed to load D3D9 library
Feb 03, 2022 19:44:19.018 [12912] INFO - [Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
Feb 03, 2022 19:44:19.170 [4084] WARN - Could not convert “state” (“error”) to the correct type
Feb 03, 2022 19:44:19.235 [12912] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:19.235 [12912] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:19.482 [12912] ERROR - [Transcode] [FFMPEG] - could not create MFT
Feb 03, 2022 19:44:19.686 [12912] WARN - [Transcode] Codecs: avcodec_open2 returned -40 for encoder ‘h264_mf’
Feb 03, 2022 19:44:19.687 [12912] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:19.687 [12912] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:19.688 [12912] ERROR - [Transcode] [FFMPEG] - Failed to load D3D9 library
Feb 03, 2022 19:44:19.692 [12912] INFO - [Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
Feb 03, 2022 19:44:21.387 [15744] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:21.387 [15744] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:21.604 [15744] ERROR - [Transcode] [FFMPEG] - could not create MFT
Feb 03, 2022 19:44:21.857 [15744] WARN - [Transcode] Codecs: avcodec_open2 returned -40 for encoder ‘h264_mf’
Feb 03, 2022 19:44:21.858 [15744] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:21.858 [15744] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:21.858 [15744] ERROR - [Transcode] [FFMPEG] - Failed to load D3D9 library
Feb 03, 2022 19:44:21.860 [15744] INFO - [Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
Feb 03, 2022 19:44:22.123 [15744] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:22.123 [15744] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:22.309 [15744] ERROR - [Transcode] [FFMPEG] - could not create MFT
Feb 03, 2022 19:44:22.568 [15744] WARN - [Transcode] Codecs: avcodec_open2 returned -40 for encoder ‘h264_mf’
Feb 03, 2022 19:44:22.569 [15744] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:22.569 [15744] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:22.569 [15744] ERROR - [Transcode] [FFMPEG] - Failed to load D3D9 library
Feb 03, 2022 19:44:22.571 [15744] INFO - [Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
Feb 03, 2022 19:44:22.833 [15744] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:22.833 [15744] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:23.010 [15744] ERROR - [Transcode] [FFMPEG] - could not create MFT
Feb 03, 2022 19:44:23.263 [15744] WARN - [Transcode] Codecs: avcodec_open2 returned -40 for encoder ‘h264_mf’
Feb 03, 2022 19:44:23.264 [15744] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:23.264 [15744] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:23.264 [15744] ERROR - [Transcode] [FFMPEG] - Failed to load D3D9 library
Feb 03, 2022 19:44:23.266 [15744] INFO - [Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
Feb 03, 2022 19:44:23.446 [4848] WARN - [Transcode] Denying access due to session lacking permission to transcode key /library/metadata/19759
Feb 03, 2022 19:44:23.538 [15744] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:23.538 [15744] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:23.718 [15744] ERROR - [Transcode] [FFMPEG] - could not create MFT
Feb 03, 2022 19:44:23.972 [15744] WARN - [Transcode] Codecs: avcodec_open2 returned -40 for encoder ‘h264_mf’
Feb 03, 2022 19:44:23.973 [15744] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:23.973 [15744] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:23.973 [15744] ERROR - [Transcode] [FFMPEG] - Failed to load D3D9 library
Feb 03, 2022 19:44:23.975 [15744] INFO - [Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
Feb 03, 2022 19:44:24.196 [16356] WARN - [Transcode] Denying access due to session lacking permission to transcode key /library/metadata/19759
Feb 03, 2022 19:44:24.235 [15744] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:24.235 [15744] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:24.267 [13240] ERROR - Thread: Uncaught exception running async task which was spawned by thread 16356: bad allocation
Feb 03, 2022 19:44:24.301 [16356] WARN - Could not convert “state” (“error”) to the correct type
Feb 03, 2022 19:44:24.387 [0108] ERROR - Thread: Uncaught exception running async task which was spawned by thread 12508: bad allocation
Feb 03, 2022 19:44:24.482 [15744] ERROR - [Transcode] [FFMPEG] - could not create MFT
Feb 03, 2022 19:44:24.729 [15744] WARN - [Transcode] Codecs: avcodec_open2 returned -40 for encoder ‘h264_mf’
Feb 03, 2022 19:44:24.730 [15744] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:24.730 [15744] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:24.731 [15744] ERROR - [Transcode] [FFMPEG] - Failed to load D3D9 library
Feb 03, 2022 19:44:24.733 [15744] INFO - [Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
Feb 03, 2022 19:44:24.992 [15744] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:24.992 [15744] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:25.190 [15744] ERROR - [Transcode] [FFMPEG] - could not create MFT
Feb 03, 2022 19:44:25.440 [15744] WARN - [Transcode] Codecs: avcodec_open2 returned -40 for encoder ‘h264_mf’
Feb 03, 2022 19:44:25.441 [15744] ERROR - [Transcode] [FFMPEG] - Cannot load nvcuda.dll
Feb 03, 2022 19:44:25.441 [15744] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Feb 03, 2022 19:44:25.442 [15744] ERROR - [Transcode] [FFMPEG] - Failed to load D3D9 library
Feb 03, 2022 19:44:25.445 [15744] INFO - [Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
Feb 03, 2022 19:44:25.451 [12504] WARN - Crash: Crash reporting disabled
Can confirm this update seems to have fixed the crashing issue I was experiencing.
Hope those with the H/W transcoding errors see a fix soon as well.
I’m looking for the regular server logs. Please post the entire log. Your snippet doesn’t reveal anything.
