Server Version#: 1.40.0.7775
OK… the strangest thing happened over the last week or two… after purchasing plex-pass, i noticed my internet slowing down… I started to seeing mallocfail and chunkexpandmanger syslog’s from my cisco router… failing expanding the pool for ipnat… looking at the sessions created and nat translations i’m seeing an astounding 200-300k ssh sessions from plex to the internet.
Total active translations: 300541 (0 static, 300541 dynamic; 300543 extended)
Peak translations: 300544, occurred 00:52:14 ago
Outside interfaces:
GigabitEthernet0/0
Inside interfaces:
GigabitEthernet0/1
Hits: 95170443 Misses: 0
CEF Translated packets: 88387688, CEF Punted packets: 34218440
Expired translations: 20905568
Dynamic mappings:
-- Inside Source
[Id: 1] access-list HOME_NAT_LAN interface GigabitEthernet0/0 refcount 300534
netstat on plex (ubuntu 22.04.3 LTS) also shows… but can’t find out what is starting these sessions… ps shows nothing so I’m guessing something in python is doing it? I know nothing about python…
tcp 0 0 50.92.xxx.xx:41012 139.104.232.134:22 ESTABLISHED
tcp 0 68 50.92.xxx.xx:34008 139.104.232.181:22 ESTABLISHED
tcp 0 48 50.92.xxx.xx:39052 139.104.232.183:22 ESTABLISHED
tcp 0 68 50.92.xxx.xx:47980 139.104.186.2:22 ESTABLISHED
tcp 0 12 50.92.xxx.xx:47772 139.104.232.143:22 ESTABLISHED
tcp 0 0 50.92.xxx.xx:47752 139.104.232.143:22 ESTABLISHED
tcp 0 0 50.92.xxx.xx:54172 139.104.232.157:22 ESTABLISHED
tcp 0 12 50.92.xxx.xx:34020 139.104.232.181:22 ESTABLISHED
tcp 0 68 50.92.xxx.xx:48618 139.104.232.165:22 ESTABLISHED
tcp 21 0 50.92.xxx.xx:52080 139.104.232.158:22 ESTABLISHED
tcp 0 12 50.92.xxx.xx:35266 139.104.232.177:22 ESTABLISHED
tcp 0 12 50.92.xxx.xx:57198 139.104.232.182:22 ESTABLISHED
tcp 0 48 50.92.xxx.xx:52458 139.104.232.187:22 ESTABLISHED
tcp 0 12 50.92.xxx.xx:37388 139.104.186.1:22 ESTABLISHED
tcp 0 1040 50.92.xxx.xx:47988 139.104.186.2:22 ESTABLISHED
tcp 0 68 50.92.xxx.xx:34420 139.104.232.142:22 ESTABLISHED
tcp 0 12 50.92.xxx.xx:53336 139.104.232.188:22 ESTABLISHED
tcp 264 0 50.92.xxx.xx:59294 139.104.232.221:22 ESTABLISHED
tcp 0 12 50.92.xxx.xx:48716 139.104.232.160:22 ESTABLISHED
tcp 0 68 50.92.xxx.xx:35256 139.104.232.177:22 ESTABLISHED
This was a fresh Ubuntu server install.
Anyone run into this before??
