Has anyone else here put their Plex server behind an nginx proxy (using subdomains)? and then subsequently stopped having this problem? If your answer is no I suggest you try it out to see if things improve.
Do you have any instructions for that? Iām willing to try anything to be stable again.
Are you using Linux?
Iām using unRAID with Plex running in docker.
Yea, I dunno about unRAID. Iāve never used it. But if you can get nginx installed I will post the config.
And people wonder about Plex support?
An issue that is originally and still is tagged as Windows and yet there is hardly a post about Windows since. Now weāre on which variation of Linux/Docker and unraid.
Hold your head in shame Plex.
Q. What are logs.
A. That thing that someone else can be bothered to provide on the relevant OS
I was having the same issue on CentOS until I 1) got rid of all Android clients and 2) put my servers behind nginx. So what may have originally been about windows is more widespread than it.
Yeah and I havenāt read the whole thread to be honest.
To be fair anything involving Android clients seems seriously screwed as a random forum browser.
I didnāt (but may have missed) the correlation.
I guess itās why my Shield (next to the Apple TV) needs dusting down⦠well plugging in actually.
Hi
Hi - I am still waiting for you to have a look at my post
Plex Deadlocking with to many hung connections issues for last 5 months Now!. (This ended up giving me anxiety attacks!) (Edited title for clarification) - #195 by sa2000 and look at the windows event log for any disk issues and also doing a surface read test and chkdsk on the drive
It would be a kill -SEGV <pid> where <pid> is the process id of the PlexMediaServer process
But our dump uploads do not always succeed and you may need to search for the dump file after the attempt to upload - search within the docker files/directories
This is an example of me doing this in docker under windows wsl (as a test)
sudo ps aux
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
sa 13518 0.4 0.2 99340 60160 ? Ssl Jul26 37:36 /usr/lib/plexmediaserver/Plex Media Server
The Plex Crash Uploader logs would have the dump identifier after a process is killed with a -SEGV
I found a copy of the dump file in my case in this path here
sa@DESKTOP-87HJ4EP:~$ sudo ls -ail /var/lib/docker/overlay2/68ffa8d2b5fd18fce4f6a48b943dd1fc9f33fd6a72ec7dccd9ba979c51e54230/diff/tmp
total 424
101508 drwxrwxrwx 4 root root 4096 Jul 26 09:53 .
101382 drwxr-xr-x 6 root root 4096 Jul 26 02:00 ..
103433 -rw------- 1 sa sa 415768 Jul 26 09:53 2492d061-aa66-4549-1bcafe94-ed01d014
101510 drwxr-xr-x 2 sa sa 4096 Jul 26 02:00 pms-6a06576e-557d-4db5-b3ee-2817c99066ac
103428 drwxr-xr-x 2 sa sa 4096 Jul 26 09:53 pms-703d7052-e34b-410a-9262-3e466fc93e70
The dump file was 2492d061-aa66-4549-1bcafe94-ed01d014 1
as an example
Experiencing deadlocks tonight with 300+ connections. Tried killing the pid inside the docker console and got this error
# ps aux
root 1 0.0 0.0 204 4 ? Ss 13:39 0:00 s6-svscan -t0 /var/run/s6/services
root 38 0.0 0.0 204 4 ? S 13:39 0:00 s6-supervise s6-fdholderd
root 338 0.0 0.0 204 4 ? S 13:39 0:00 s6-supervise plex
abc 5419 95.7 0.3 323896 201848 ? Ssl 19:59 99:15 /usr/lib/plexmediaserver/Plex Media Server
abc 5454 0.1 0.0 62184 41740 ? SNl 19:59 0:07 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/R
abc 5510 0.0 0.0 42236 10384 ? Sl 19:59 0:04 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmed
abc 6216 1.6 0.0 2564 1172 ? S 20:20 1:23 Plex EAE Service
root 9683 0.0 0.0 2616 608 pts/0 Ss 21:42 0:00 sh
root 9689 0.0 0.0 8900 3272 pts/0 R+ 21:43 0:00 ps aux
# kill -SEVG 5419
sh: 2: kill: Illegal option -S
# kill -SEVG 5419
sh: 3: kill: Illegal option -S
# kill 5419
Itās -SEGV not -SEVG. I also see the CPU was spiking while the deadlock happened. Bet this has something to do with database querys. For some reasonā¦
@sa2000 Iām still adding crash reports and dmp+logs+connections into that Onedrive for 1.24.1.4931-1a38e63c6
Is this somehow related to the deadlocks?
New BETA PMS Version Available - 1.24.2.4973-2b1b51db9
- (Library) The server could become unresponsive if certain HTTP requests were made simultaneously (#12844)
passably dose sound interesting
It is the fix for the issue i said we discovered - so i recommend running that version. There was no clear indication from the ones I have seen in this thread that this was the cause - but best to run with that fix
SEGV not SEVG
@Lo-ki ping - please see my earlier response
Best to hold fire on adding more. I would like to see more examples from different users
Is this issue fixed for anyone in the latest release?
