Plex Deadlocking with to many hung connections issues for last 5 months Now!. (This ended up giving me anxiety attacks!) (Edited title for clarification)
Fresh set sent, happened within 4 hours of updating to new beta!!
Oh also unfortunately due to how this has effected my mental health (I am being treaded for Anxiety now :frowning: ) I have also started to move away from Plex, as this problem has been ongoing for far to long, while the Dev’s can see the problem they can’t pin point the problem, and waiting a week between updates while very helpful and immensely apricated its not helping my health much.
Its very unfortunate and a crying shame (as I actually much prefer Plex and its simplicity) I have to move away from Plex, but its necessary :sob:
Take care of yourself first! Sincere best wishes and good luck.
I am curious if you use any 3rd-party security software, antivirus, network protection, IDS, that sort of thing?
Edit: Geez, I apologize. I asked that same thing before. It sounds like your best bet - if you want to keep investigating - is to keep providing dumps, if or when you can.
Nope, just Windows defender and the same router I have had for 3 years now lol.
What’s happening is there’s a tread within Plex that’s locking up and the coursing a domino effect with all sequential threads after it so it just locks up, think is its also random so pin pointing the course is harder cos there’s no common pattern lol
I assumed there wasn’t. I just recently encountered some broken AV software that was preventing connections from closing correctly, and thought of your thread.
Intermittent problems are the worst.
Yep, if it was say the same time or day each time, or the same users then it would be easier to pin down but alas cos it pops up when it likes and I don’t know about it until I on one of my Kids try to use it its normally a far point into the issue so the course has probably sorted itself but the rest of the connections have yet to catch up lmao
Another day another lockup, the last 2 betas have actually coursed this to increase in frequency :sob:
This is getting a bit old now pmsl
Two somewhat crazy suggestions:
At the times of the deadlocks are you seeing any long I/O wait times? If so your disk storing plex could be starting to fail.
Have you thought about ditching windows completely and running PMS on Linux (ubuntu for example). You may get better results/performance out of Linux.
Nope not seen any Disk I/O issues (running off Dedicated SSD) however when I look at the wait chain via resource monitor it is telling me its waiting for Network I/O, Problem is Plex is the only thing that has this all other network traffic is fine.
Yes I have thought about it and I have a Server that’s currently awaiting some more parts (GPU and a couple of SSD’s) that I will be moving Plex to permanent if this can be solved/fixed.
The biggest problem I have is that Plex has been running on the same machine for almost 10 yeas with very very little problems until 1.2x like of updates started to come out (and looking at reddit and here 1.2x has been a mess for a lot of people for various reasons)
I had thought about dropping back down to 1.20.2.3402 but I am concerned that this will kill my DB big time due to the changes made to the DB code by Plex.
maybe your ISP is attempting to throttle or otherwise ‘manage’ plex related traffic, which causes latency/interference with plex network functionality.
Unfortunately this is definitely not the case, as I have been able to reproduce this with all remote access off and only Local Devices using Plex, Also I have Emby (This is what I am moving to cos of the Plex issues) running perfectly fine on same machine and using the Same SSD for metadata.
The Problem is connections/Threads are stuck within Plex itself (its not closing them) and this is what the Dev’s are struggling with as there is just one single connection/Thread that’s coursing all other connections/Thread’s after to lock up and remain “Jammed” open only finding what is coursing that single Connection/Thread to lock is not proving easy.
Just tonight, when my Partner and Kids started using Plex upstairs on there Xbox’s, it started to fail within about 20 mins, ended up opening 411 connections, yes 411.
Do you have a virus scanner and or internet security app installed? If so disable it and re-test.
Actually just read you don’t.
What I want to see is the screenshots of this happening. You said 411 connections
 show me!
Nope, that was the first thing I tried 4 months ago lol I only have Windows Defender :smiley:
I want to see a screenshot of all the connections in the plex app!!!
Lol you don’t see them via the app, did you not read the top OP post!!
You can only see the connections via http://127.0.0.1:32400/connections?X-Plex-Token=############ and the app is completely unaccessible once it opens more than 50.
Have you tried replacing the ethernet cable?
In the interest of trying to explain the issue here is a snip of tonight’s 411 open connections, ( I have edited IP Addresses and Usernames/Identifiers, the rest is untouched how it displays for me)
I think showing what its doing may help better convey what the problem is.
Now I must remind, this has been going on for last 4 months (out of 8 years of using Plex!!), This all started with Build 1.2x
The Host system was fully wiped and even the Plex DB and All Metadata was removed and restarted thinking this is the issue and it wasn’t.
When Build 1.23.1.4602 hit things did improve (the one with the DNS fix) as I think this may be a small part of the problem, however the last to Beta Builds that I have been asked to test have made things worse again!!
This is Working fine with no issues
1 86.****** - Routed - Paused 8.122s - Written 5706b - GET /:/websockets/notifications - Token (******) (Plex for Android (TV), 8.18.2.25850, Android, 7.1.2, AFTMM, mantis)
2 ??? - Uninitialized
3 192.******- Routed - Paused 2.615s - Written 572960044b - GET /:/websockets/notifications - Token (morpheus2n2)
4 86.****** - Routed - Paused 2.615s - Written 5580b - GET /:/websockets/notifications - Token (******) (Plex for Android (TV), 8.18.2.25850, Android, 7.1.2, AFTMM, mantis)
5 ??? - Uninitialized
6 192.****** - Pending Request - Pipelined - 248
7 127.****** - Routing - GET /connections - Token (morpheus2n2) (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.101 Safari/537.36 Edg/91.0.864.48)
8 86.****** - Routed - Paused 1.296s - Written 8668385b - GET /:/eventsource/notifications - Token (morpheus2n2) (Plex Backup, Plex Media Server, 1.23.2.4656-85f0adf5b, Windows, 10.0 (Build 19042), PC, x64)
9 192.****** - Routed - Paused 1.436s - Written 440208b - GET /:/websockets/notifications - Token (******)
This is when its locking up and the GUI can not be accessed from any where or anything (Its deadlocked).
300 192.****** - Pending Schedule - Paused 526.035s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
301 192.****** - Pending Schedule - Paused 526.015s - GET /library/metadata/268095/children - Token (morpheus2n2) (axios/0.21.1)
302 192.****** - Pending Schedule - Paused 526.000s - GET /library/metadata/76866/children - Token (morpheus2n2) (axios/0.21.1)
303 192.****** - Routing - Paused 1583.289s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=848007&duration=8576544&playbackTime=848211&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
304 127.****** - Pending Schedule - Paused 927.477s - GET /:/metadata/notify/changeItemState?librarySectionID=7&metadataItemID=102219&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=analyzing - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
305 127.****** - Pending Schedule - Paused 927.478s - GET /library/changestamp - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
306 192.****** - Pending Schedule - Paused 927.272s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1504010&duration=8576544&playbackTime=1504226&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
307 ??? - Uninitialized
308 192.****** - Pending Schedule - Paused 92.543s - GET /media/providers?includePreferences=1 - Token (******) (M******-XBOXONE, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One S)
309 192.****** - Routing - Paused 1546.914s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
310 192.****** - Routing - Paused 1471.477s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
311 192.****** - Routing - Paused 1462.253s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=969040&duration=8576544&playbackTime=969245&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
312 192.****** - Routing - Paused 1452.168s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=979066&duration=8576544&playbackTime=979272&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
313 192.****** - Routing - Paused 1516.763s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
314 127.******- Pending Schedule - Paused 8.545s - GET /favicon.ico (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.101 Safari/537.36 Edg/91.0.864.48)
315 192.****** - Routing - Paused 1657.156s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
316 192.****** - Pending Schedule - Paused 25.678s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
317 192.****** - Routing - Paused 1654.197s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=777098&duration=8576544&playbackTime=777301&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
318 192.****** - Pending Schedule - Paused 1301.122s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1130152&duration=8576544&playbackTime=1130361&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
319 127.****** - Pending Schedule - Paused 1297.816s - GET /library/changestamp - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
320 192.****** - Pending Schedule - Paused 1287.802s - GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
321 192.****** - Pending Schedule - Paused 1318.103s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
322 192.****** - Pending Schedule - Paused 1311.154s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1120134&duration=8576544&playbackTime=1120342&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
323 192.****** - Pending Schedule - Paused 786.312s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
324 192.****** - Pending Schedule - Paused 907.225s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1524052&duration=8576544&playbackTime=1524268&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
325 192.****** - Pending Schedule - Paused 692.689s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
326 192.****** - Pending Schedule - Paused 632.480s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
327 192.****** - Pending Schedule - Paused 427.290s - GET /:/prefs - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
328 192.****** - Pending Schedule - Paused 791.735s - GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
329 192.****** - Pending Schedule - Paused 116.353s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
330 192.****** - Pending Schedule - Paused 915.764s - GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
331 192.****** - Pending Schedule - Paused 695.213s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1736063&duration=8576544&playbackTime=1736282&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
332 192.****** - Pending Schedule - Paused 635.068s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1796205&duration=8576544&playbackTime=1796426&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
333 192.****** - Pending Schedule - Paused 625.048s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1806227&duration=8576544&playbackTime=1806449&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
334 34.****** - Pending Schedule - Paused 438.323s - GET /identity - Token (morpheus2n2) (plex.tv)
335 192.****** - Pending Schedule - Paused 412.230s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
336 86.****** - Pending Schedule - Paused 121.507s - GET /media/providers?includePreferences=1 - Token (******) (M******-XBOXONE, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One S)
337 192.****** - Pending Schedule - Paused 1039.038s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1392246&duration=8576544&playbackTime=1392459&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
338 192.****** - Pending Schedule - Paused 1129.113s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1302044&duration=8576544&playbackTime=1302255&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
339 192.****** - Pending Schedule - Paused 1124.086s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
340 192.****** - Pending Schedule - Paused 1028.265s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1403019&duration=8576544&playbackTime=1403232&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
341 127.****** - Pending Schedule - Paused 1020.336s - GET /library/changestamp - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
342 192.****** - Pending Schedule - Paused 1135.856s - GET /identity - Token (morpheus2n2) (Sonarr, Sonarr, 3.0.6.1196, Windows, 7)
343 192.****** - Pending Schedule - Paused 1132.555s - GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
344 192.****** - Pending Schedule - Paused 1139.239s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1292020&duration=8576544&playbackTime=1292232&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
345 192.******- Pending Schedule - Paused 1035.888s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
346 192.****** - Pending Schedule - Paused 1020.864s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
347 127.****** - Pending Schedule - Paused 1020.270s - GET /:/metadata/notify/changeItemState?librarySectionID=7&metadataItemID=81631&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=analyzing - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
348 127.******- Pending Schedule - Paused 1020.247s - GET /library/changestamp - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
349 127.****** - Pending Schedule - Paused 1020.230s - GET /:/metadata/notify/changeItemState?librarySectionID=7&metadataItemID=81569&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=analyzing - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
350 192.****** - Pending Schedule - Paused 1018.239s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1413039&duration=8576544&playbackTime=1413253&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
351 127.****** - Pending Schedule - Paused 865.893s - GET /:/metadata/notify/changeItemState?librarySectionID=7&metadataItemID=55654&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=analyzing - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
352 192.****** - Pending Schedule - Paused 1205.452s - GET /library/metadata/238825 - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
353 192.****** - Pending Schedule - Paused 948.073s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1483207&duration=8576544&playbackTime=1483423&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
354 127.****** - Pending Schedule - Paused 618.991s - GET /library/changestamp - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
355 127.****** - Pending Schedule - Paused 1236.548s - GET /library/changestamp - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
356 192.****** - Pending Schedule - Paused 1236.172s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
357 192.****** - Pending Schedule - Paused 1206.870s - GET /library/metadata/238825 - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
358 127.****** - Pending Schedule - Paused 618.975s - GET /:/metadata/notify/changeItemState?librarySectionID=7&metadataItemID=57702&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=analyzing - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
359 127.****** - Pending Schedule - Paused 865.793s - GET /:/metadata/notify/changeItemState?librarySectionID=7&metadataItemID=55656&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=analyzing - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
360 127.****** - Pending Schedule - Paused 649.658s - GET /:/metadata/notify/changeItemState?librarySectionID=7&metadataItemID=57800&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=analyzing - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
361 127.****** - Pending Schedule - Paused 662.006s - GET /favicon.ico (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.101 Safari/537.36 Edg/91.0.864.48)
362 127.****** - Pending Schedule - Paused 649.658s - GET /library/changestamp - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
363 192.****** - Pending Schedule - Paused 662.595s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
364 192.****** - Pending Schedule - Paused 667.716s - GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
365 192.****** - Pending Schedule - Paused 655.108s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1776160&duration=8576544&playbackTime=1776381&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
366 127.****** - Pending Schedule - Paused 667.757s - GET /favicon.ico (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.101 Safari/537.36 Edg/91.0.864.48)
367 192.****** - Pending Schedule - Paused 665.132s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1766136&duration=8576544&playbackTime=1766356&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
368 192.****** - Pending Schedule - Paused 525.995s - GET /library/metadata/115411/children - Token (morpheus2n2) (axios/0.21.1)
369 192.****** - Pending Schedule - Paused 525.992s - GET /library/metadata/267333/children - Token (morpheus2n2) (axios/0.21.1)
370 192.****** - Pending Schedule - Paused 525.980s - GET /library/metadata/267308/children - Token (morpheus2n2) (axios/0.21.1)
371 192.****** - Pending Schedule - Paused 525.986s - GET /library/metadata/189990/children - Token (morpheus2n2) (axios/0.21.1)
372 192.****** - Pending Schedule - Paused 636.695s - GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
373 192.****** - Pending Schedule - Paused 525.941s - GET /library/metadata/267975/children - Token (morpheus2n2) (axios/0.21.1)
374 192.****** - Pending Schedule - Paused 611.400s - GET /photo/:/transcode?url=%2Flibrary%2Fmetadata%2F189456%2Fart%2F1617812679&width=1920&height=1080&minSize=0&upscale=1&crop=center - Token (******) (Mozilla/5.0 (Windows NT 10.0; Win64; x64; Xbox; Xbox One; MSAppHost/3.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.102 Safari/537.36 Edge/18.19041)
375 127.******- Pending Schedule - Paused 588.090s - GET /:/metadata/notify/changeItemState?librarySectionID=7&metadataItemID=57703&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=analyzing - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
376 192.****** - Pending Schedule - Paused 705.238s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1726036&duration=8576544&playbackTime=1726256&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
377 127.******- Pending Schedule - Paused 679.904s - GET /:/metadata/notify/changeItemState?librarySectionID=7&metadataItemID=57778&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=analyzing - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
378 192.****** - Pending Schedule - Paused 698.715s - GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
379 192.****** - Pending Schedule - Paused 611.884s - GET /library/metadata/189456/children - Token (Kai_louise) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
380 192.****** - Pending Schedule - Paused 605.212s - GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
381 127.****** - Pending Schedule - Paused 556.908s - GET /library/changestamp - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
382 192.****** - Pending Schedule - Paused 796.205s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1635066&duration=8576544&playbackTime=1635284&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
383 127.****** - Pending Schedule - Paused 834.897s - GET /library/changestamp - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
384 127.****** - Pending Schedule - Paused 834.890s - GET /:/metadata/notify/changeItemState?librarySectionID=7&metadataItemID=55660&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=analyzing - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
385 192.****** - Pending Schedule - Paused 756.105s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1675163&duration=8576544&playbackTime=1675381&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
386 192.****** - Pending Schedule - Paused 729.734s - GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
387 192.****** - Pending Schedule - Paused 734.248s - GET /:/prefs - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
388 192.****** - Pending Schedule - Paused 831.462s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
389 192.****** - Pending Schedule - Paused 827.037s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1604243&duration=8576544&playbackTime=1604460&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
390 127.****** - Pending Schedule - Paused 679.892s - GET /library/changestamp - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
391 127.****** - Pending Schedule - Paused 679.892s - GET /:/metadata/notify/changeItemState?librarySectionID=7&metadataItemID=57779&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=analyzing - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
392 127.******- Pending Schedule - Paused 649.640s - GET /library/changestamp - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
393 127.****** - Pending Schedule - Paused 649.640s - GET /:/metadata/notify/changeItemState?librarySectionID=7&metadataItemID=57801&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=analyzing - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
394 192.****** - Pending Schedule - Paused 647.579s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
395 127.******- Pending Schedule - Paused 679.900s - GET /library/changestamp - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
396 127.****** - Pending Schedule - Paused 526.347s - GET /library/changestamp - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
397 192.****** - Pending Schedule - Paused 550.287s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
398 192.****** - Pending Schedule - Paused 952.035s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
399 192.******- Pending Schedule - Paused 988.171s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1443113&duration=8576544&playbackTime=1443327&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
400 192.****** - Pending Schedule - Paused 958.094s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1473186&duration=8576544&playbackTime=1473400&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (M******-XBOXONE, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
401 192.******- Pending Schedule - Paused 253.211s - GET /media/providers?includePreferences=1 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One S)
402 127.******- Pending Schedule - Paused 989.301s - GET /library/changestamp - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
403 127.******- Pending Schedule - Paused 989.287s - GET /:/metadata/notify/changeItemState?librarySectionID=7&metadataItemID=107603&metadataType=4&state=-1&parentID=-1&rootID=-1&mediaState=analyzing - Token (morpheus2n2) (PlexMediaServer/1.23.3.4706-f48049cad)
404 192.****** - Pending Schedule - Paused 946.774s - GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 - Token (******) (M******-XBOXONE, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
405 192.****** - Pending Schedule - Paused 906.778s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
406 192.******- Pending Schedule - Paused 897.201s - GET /:/timeline?key=%2Flibrary%2Fmetadata%2F267012&ratingKey=267012&state=playing&time=1534081&duration=8576544&playbackTime=1534298&playQueueItemID=194336&context=home%3Ahub.continueWatching&row=0&col=0 - Token (******) (BEDROOM-XBOX, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One X)
407 192.****** - Pending Schedule - Paused 280.078s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
408 192.****** - Pending Schedule - Paused 460.687s - GET /identity - Token (morpheus2n2) (Sonarr, Sonarr, 3.0.6.1196, Windows, 7)
409 86.****** - Pending Schedule - Paused 253.152s - GET /media/providers?includePreferences=1 - Token (******) (M******-XBOXONE, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One S)
410 86.****** - Pending Schedule - Paused 28.433s - GET /media/providers?includePreferences=1 - Token (******) (M******-XBOXONE, Plex for Xbox, 5.17.0, Xbox, 10.0.19041.7772, Xbox, Xbox One S)
411 192.****** - Pending Schedule - Paused 251.411s - GET /status/sessions - Token (morpheus2n2) (Plex-Backend, Tautulli, v2.7.3, Windows, 10, Windows 10)
Yep, as said its only Plex that’s the issue everything else with the system and network all work fine and as they have done for years :smiley:
Even if there was a contributory network or disk issue, Plex shouldn’t be getting into this state.
I think you’re doing the right thing by reporting and sharing dumps.
Sorry I asked about AV software twice. Short memory apparently. :slight_smile:
I’m just trying to think what makes your Windows 10 computer different from everyone elses. Are there any other people reporting this do you know?
Have you tried to switch out your router or disable the firewall on your router?
