Plex-desktop (flatpak) errors
Server Version#: 1.26.2.5797
Player Version#: 1.46.1.3069-2ba7b5fe (flatpak on Arch Linux)
~/.var/app/tv.plex.PlexDesktop/data/plex/Logs
Jun 13, 2022 17:37:37.829 [0x7fc2cdde0640] INFO - Starting Plex version: 1.46.1.3069-2ba7b5fe
Jun 13, 2022 17:37:37.829 [0x7fc2cdde0640] INFO - Running on: Freedesktop.org 21.08.14 (Flatpak runtime) [5.18.3-arch1-1] x86_64
Jun 13, 2022 17:37:37.829 [0x7fc2cdde0640] INFO - Happy Plexing!
Jun 13, 2022 17:37:37.829 [0x7fc2d35cc8c0] INFO - [OpenGL] Selected desktop renderer.
Jun 13, 2022 17:37:37.829 [0x7fc2d35cc8c0] INFO - [OpenGL] Default surface format version: 2.0
Jun 13, 2022 17:37:37.829 [0x7fc2d35cc8c0] INFO - [OpenGL] Selecting surface format version: 2.0; profile: 1
Jun 13, 2022 17:37:37.829 [0x7fc2d35cc8c0] INFO - Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
Jun 13, 2022 17:37:37.830 [0x7fc2d35cc8c0] ERROR - Failed to create wl_display (No such file or directory)
Jun 13, 2022 17:37:37.830 [0x7fc2d35cc8c0] INFO - Could not load the Qt platform plugin "wayland" in "/app/bin/../plugins/platforms:" even though it was found.
Jun 13, 2022 17:37:37.830 [0x7fc2d35cc8c0] ERROR - This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Then I enabled socket-wayland (in flatseal)
Jun 13, 2022 17:41:18.750 [0x7f94245e0640] INFO - Starting Plex version: 1.46.1.3069-2ba7b5fe
Jun 13, 2022 17:41:18.750 [0x7f94245e0640] INFO - Running on: Freedesktop.org 21.08.14 (Flatpak runtime) [5.18.3-arch1-1] x86_64
Jun 13, 2022 17:41:18.750 [0x7f94245e0640] INFO - Happy Plexing!
Jun 13, 2022 17:41:18.750 [0x7f942a31c8c0] INFO - [OpenGL] Selected desktop renderer.
Jun 13, 2022 17:41:18.750 [0x7f942a31c8c0] INFO - [OpenGL] Default surface format version: 2.0
Jun 13, 2022 17:41:18.750 [0x7f942a31c8c0] INFO - [OpenGL] Selecting surface format version: 2.0; profile: 1
Jun 13, 2022 17:41:18.750 [0x7f942a31c8c0] INFO - Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
Jun 13, 2022 17:41:18.754 [0x7f942a31c8c0] WARN - QSocketNotifier: Can only be used with threads started with QThread
Jun 13, 2022 17:41:18.756 [0x7f942a31c8c0] WARN - EGL not available
Jun 13, 2022 17:41:18.756 [0x7f942a31c8c0] INFO - [Settings] Web inspector port 0
Jun 13, 2022 17:41:18.757 [0x7f942a31c8c0] INFO - [NanoServer] Starting nano server.
however, when trying to play a video, it gives an error
Jun 13, 2022 17:44:38.102 [0x7f94037fe640] INFO - [MPVEngine/mpv] cplayer:
Jun 13, 2022 17:44:38.103 [0x7f942a31c8c0] ERROR - [Web] [QTMedia(4)] A critical error occurred: 4294967276 An unknown error occurred (4294967276)
Jun 13, 2022 17:44:38.103 [0x7f942a31c8c0] ERROR - [Web] [Player] Direct Play failed, but server can transcode. Attempting to fallback to either Direct Stream or transcode...
Jun 13, 2022 17:44:38.109 [0x7f942a31c8c0] ERROR - [Web] [QTMedia(4)] componentWillUnmount rejected: {
  "type": "[object Error]",
  "stack": "Error: Resolved after unmount\n    at file:///app/resources/web-client/js/main-179-4f11206cf05093d2fc01-plex-4.83.2.24409-d157348.js:2:2575387\n    at async file:///app/resources/web-client/js/58-58-e592d676552063461ed5-plex-4.83.2.24409-d157348.js:2:1156614",
  "name": "Error",
  "message": "Resolved after unmount"
Jun 13, 2022 17:46:06.920 [0x7f942a31c8c0] ERROR - [Web] Did not move header "accept" to query string. This can result in an unnecessary OPTIONS preflight request.
Jun 13, 2022 17:46:06.921 [0x7f942a31c8c0] DEBUG - Enabling OS screensaver
Jun 13, 2022 17:46:06.921 [0x7f942a31c8c0] INFO - doEnableScreensaver : already enabled.
Jun 13, 2022 17:46:06.942 [0x7f942a31c8c0] ERROR - [Web] [QTMedia(6)] componentWillUnmount rejected: {
  "name": "Error",
Jun 13, 2022 17:46:07.081 [0x7f942a31c8c0] ERROR - [Web] [Player] Player was closed or a new playback session was started; ignoring callback
Jun 13, 2022 17:46:25.442 [0x7f942a31c8c0] INFO - [Web] [Connections] Testing all 1 connection(s) for [Loopback]
Jun 13, 2022 17:46:25.443 [0x7f942a31c8c0] INFO - [Web] [Servers] Waiting for initial servers = [Loopback]
Jun 13, 2022 17:46:25.447 [0x7f942a31c8c0] INFO - [Web] [Commands] Executing testServerConnection
Jun 13, 2022 17:46:25.447 [0x7f942a31c8c0] INFO - [Web] [Connections] Retrying connection tests for [Loopback] in 30 seconds
Jun 13, 2022 17:46:25.497 [0x7f942a31c8c0] INFO - [Web] [Connections] Testing connection for [Loopback] at http://127.0.0.1:32400/media/providers
Jun 13, 2022 17:46:25.497 [0x7f942a31c8c0] INFO - [Web] [Connections] Testing legacy connection for [Loopback] at http://127.0.0.1:32400
Jun 13, 2022 17:46:25.501 [0x7f942a31c8c0] ERROR - [Web] [Connections] [Loopback] is unavailable at http://127.0.0.1:32400/media/providers (Status 0)
Jun 13, 2022 17:46:25.502 [0x7f942a31c8c0] ERROR - [Web] [Connections] [Loopback] is unavailable at http://127.0.0.1:32400/media/providers (Status 0)
Jun 13, 2022 17:46:25.503 [0x7f942a31c8c0] ERROR - [Web] [Connections] All connections to [Loopback] failed
