Problem with Plex Desktop Flatpak on Fedora 40 - just started This afternoon
Server Version#: 1.40.2.8395
Player Version#: current flatpak version
Hi all,
Plex Desktop on Fedora 40 had been working great - even this morning it worked. This afternoon (even though I hadn’t run any system update or flatpak update - plex is insta-crashing on my Fedora 40 install. I uninstalled it and re-installed the flatpak with the same result.
My system is running an AMD Ryzen 7 Pro 7840u w/ 780m integrated graphics, 32G ram.
here’s the error that I’m seeing in the plex log:
May 24, 2024 15:18:27.518 [140568722147008] INFO - Starting Plex version: 1.93.0.144-9b2f4a13
    May 24, 2024 15:18:27.518 [140568722147008] INFO - Running on: Freedesktop SDK 23.08 (Flatpak runtime) [6.8.10-300.fc40.x86_64] x86_64
    May 24, 2024 15:18:27.518 [140568722147008] INFO - Happy Plexing!
    May 24, 2024 15:18:27.517 [140568760044928] INFO - [OpenGL] Selected desktop renderer.
    May 24, 2024 15:18:27.517 [140568760044928] INFO - [OpenGL] Default surface format version: 2.0
    May 24, 2024 15:18:27.517 [140568760044928] INFO - [OpenGL] Selecting surface format version: 2.0; profile: 1
    May 24, 2024 15:18:27.517 [140568760044928] DEBUG - [OpenGL] Using QRhi with backend OpenGL
      Graphics API debug/validation layers: 0
      QRhi profiling and debug markers: 0
      Shader/pipeline cache collection: 0
    May 24, 2024 15:18:27.520 [140568760044928] ERROR - Failed to create wl_display (No such file or directory)
    May 24, 2024 15:18:27.783 [140568760044928] INFO - Could not load the Qt platform plugin "wayland" in "/app/bin/../plugins/platforms:" even though it was found.
    May 24, 2024 15:18:27.783 [140568760044928] ERROR - This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, wayland-egl, wayland, xcb.
It appears to be something with my specific local user account (not my plex account) - I created a second account on my laptop and was able to launch plex. I’m not quite sure what files are causing grief at this moment…
Any tips on what to check next or what I should look into with regards to my main local account that could be triggering the crash? What’s weird is I was watching a couple movies this morning (well, technically listening to them while I was working) and exited plex just before lunch. Attempted to launch it a few hours later and it’s been crashing ever since. Nothing had changed between the morning and afternoon sessions. I did run updates after tho but nothing changed in terms of functionality.
Ps - yes, I posted to Reddit r/plex as well to see if anyone might have ideas there.
Resolved the issue - somehow the flag for Wayland on the flatpak got switched off. Using Flatseal I switched the Wayland windowing system switch back on. My only guess is there was an auto-update that occurred that somehow toggled that setting. I had to fix that setting for a couple other flatpaks as well.
