Server Version#:1.43.3.10828
Player Version#: 1.112.0.359-0d79a49f
Hello, I’ve been trying to get (hw) transcode to work for a couple weeks and I’m at a loss on how to fix it. I’ve looked around at various forum posts about plex hardware transcoding issues and nothing has been able to help. I think I have everything enabled correctly, but when trying to transcode it sticks to software transcoding and my cpu usage maxes out. I’d like to be able to stream things outside my local network, and hardware transcoding is a must-have for me.
System details:
CPU: Intel i5-12500 (Intel UHD Graphics 770)
Motherboard: Asus PRIME B760M-A AX
Memory: 16GB DDR5 4800MHz (soon to be 21GB)
OS: Unraid 7.3.2
Having the exact same issue here on almost the same setup, but I have a Core Ultra 7 265k. I am also on unRAID 7.3.2 and the same version of PMS as you
then I checked that folder (/config/Library/Application Support/Plex Media Server/Cache/va-dri-linux-x86_64/) and saw it was empty, when it should have iHD_drv_video.so
So for the issue I’m seeing, that cache/va-dri-linux-x86_64 folder isn’t getting initialized correctly
And I see the device in the transcoding device list
