Plex hardware transcoding suddenly stopped working on TrueNAS SCALE (Intel iGPU, VAAPI)
Hi all,
I’ve been successfully using hardware transcoding with Plex for years on my self-hosted server, but recently (past few weeks) it suddenly stopped working. Playback only works in Original quality, but fails with a “source error” if transcoding is required. No changes were made intentionally.
:clipboard: System details:
  • Platform: TrueNAS SCALE (latest stable release, up-to-date)
  • Plex installation: Official Plex app (Latest: V1.41.6.9685-d301f511a) from the TrueNAS Apps interface
  • Plex Pass: Yes (active)
  • CPU: Intel i5-10500T (UHD 630 iGPU)
  • GPU passthrough: Enabled (/dev/dri is available inside container)
  • Transcoding settings:
    • Hardware transcoding enabled
    • “Use hardware-accelerated video encoding” also enabled
    • Experimental HEVC transcoding tried both ON and OFF — no difference
:page_facing_up: What I’ve tried so far:
  • Verified that /dev/dri is visible inside the container (card0, renderD128)
  • Checked Plex logs — VAAPI and iHD driver are detected and initialized
  • Cleared the Codecs folder and restarted Plex (to force codec reload)
  • Tried multiple videos (SD, HD, H.264, H.265) — none transcode
  • Plex logs show Unable to create output stream for transcode session, no segments found
:test_tube: Example log snippet:
[Transcode] [FFMPEG] -init_hw_device vaapi=va:/dev/dri/renderD128
[AVHWDeviceContext @ 0x...] libva: VA-API version ...
[AVHWDeviceContext @ 0x...] libva: va_getDriverName() returns 0
[AVHWDeviceContext @ 0x...] libva: Trying to open /usr/lib/dri/iHD_drv_video.so
[Transcode] ERROR - Unable to create output stream for transcode session, no segments found
:red_question_mark: Looking for:
  • Anyone else experiencing similar issues recently with Plex hardware transcoding on TrueNAS?
  • Is there any known regression in Plex’s latest builds that affects VAAPI or Intel iGPU setups?
  • Suggestions on how to fully reset transcoder environment in containerized Plex?
The problem is solved, but it is hard to say why.
The only last missing part was (at least it seems) a complete server (hardware) restart.
But I don’t think it was alone the solution.
Maybe clearing the cache was not enough by itself, but a restart was needed too.
