Plex & dlna
Server Version#:
Hi all,
I am running PLEX server on my synology.
My Bang & Olufsen products access my flac music via DLNA.
Metadata, etc. works well but there are no playlist support.
Will Plex introduce this in a future update?
Br,
Uffe
I am indeed using WebOS on my LG.
Thank you for the information.
Br,
Uffe
I have found a workaround regarding Plex’ missing DLNA playlist support, hence, I don’t need the functionality.
I really like the Plex interface, Plexamp etc. so I will still be using Plex as a DLNA server for music.
We have new LG OLED tv’s in some rooms and we plan the Plex webOS app installed on them (our house is currently being renovated).
I plan not to give the plex client on the LG TV access to music archive as I will use the TV for movies & series only.
However, based on the setup described above, do I still need to establish a reboot schedule?
If yes, when will Plex fix this issue?
Thanks again!
