Server Version#: i am not sure
Player Version#: Latest
Ok so we had a brief power outage while the music library was in use and since the power on, none of it works, the docker constantly shows unhealthy after 2 minutes, and neither app.plex.tv or its direct IP show anything in ways of content, app.plex.tv just says “unreachable” ive reinstalled it twice now, tried other versions and all to no avail. i have no clue what is going on and logs are providing little to no detail as to what it is that i can make sense of. but they are below, and this is all i can find to my knowledge that unraid gives me
##Below is log##
text error warn system array login
/config/Library/Application Support/Plex Media Server/Preferences.xml:1.1: Document is empty
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0
Failed to load preferences at /config/Library/Application Support/Plex Media Server/Preferences.xml
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 40-plex-first-run: executing…
Attempting to obtain server token from claim token
Plex Media Server first run setup complete
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing…
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
[cont-init.d] 50-plex-update: executing…
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting Plex Media Server.
[services.d] done.
##end##
any help at all would be lovely
