Plex does not load on Samsung Smart TV
I have a Samsung UN55NU8000. Almost every time I turn the TV on, Plex will not load properly. It will just have the background color, nothing on the screen. You can’t even exit out of it. The only thing that works is re-installing it.
There is also no search option on the home screen, when t does work.
I’ve read posts about the same issue, with promises that Plex is working on this, even offered a beta version once because videos weren’t even able to play.
Samsung is huge, why can’t Plex seem to get this done so it works?
If I knew of an alternative, I would use it!
