Plex Does not utilise GPU for decoding
Server Version#: 1.19.4.2865
Player Version#: Any
Hello!
I’ve just noticed that my plex instance does not utilize gpu for video decoding but only for encoding. This issue applies to any codec like H264 which is definetly supported by my gpu.
This gets me high cpu usage.
As far as i know plex can utilise gpu for the decoding part too, and as i remember it worked flawlessly in my past installation on the same environment.
I do run plex as a service, could this be a problem?
Thanks for any advice!
Regards
Peter
Yes. Don’t do that if you want gpu transcoding to work.
Many threads about this.
