Pe8er
October 20, 2021, 4:22pm
1
Hello! I’m back with more crashes… @ChuckPa as per your advice a couple weeks ago:
I checked my network settings and everything seems to be configured correctly on my router and in DSM.
I double checked that library scanning and optimizing is enabled. I also used “Optimize Database” feature under Troubleshooting.
I’m not sure where to go from here. Any advice will be appreciated.
Plex Logs 20 Oct 2021.zip (2.8 MB)
@Pe8er
You forgot –
There are no debugging statements in the logs.
Oct 16, 2021 16:44:36.573 [0x7fb4b65b7b38] INFO - Network Service: Abandoning browse socket, it was closed.
Oct 16, 2021 16:44:36.573 [0x7fb4b65b7b38] ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
Oct 16, 2021 16:44:36.674 [0x7fb4b65b7b38] INFO - Network Service: Abandoning browse socket, it was closed.
Oct 16, 2021 16:44:36.674 [0x7fb4b65b7b38] ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
Oct 16, 2021 16:44:36.774 [0x7fb4b65b7b38] INFO - Network Service: Abandoning browse socket, it was closed.
Oct 16, 2021 16:44:36.774 [0x7fb4b65b7b38] ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
Oct 16, 2021 16:44:36.874 [0x7fb4b65b7b38] INFO - Network Service: Abandoning browse socket, it was closed.
Oct 16, 2021 16:44:36.874 [0x7fb4b65b7b38] ERROR - Network Service: Error in browser handle read: 125 (Operation canceled) socket=-1
Care to give it another try ?
(leaving DEBUG on doesn’t consume more space. Logs are a fixed size)
Pe8er
October 20, 2021, 5:41pm
3
Yes sir! I will upload new logs when it crashes again. Thank you!
@Pe8er
I have moved us to our own thread here to keep the main clear
as well as keep this effort uncluttered.
Pe8er
October 21, 2021, 3:09pm
5
Thank you.
I will see if one of the team (who specializes in crash analysis) will come look)
@Pe8er
Would you now please go to Settings - Server - General - Show Advanced.
Uncheck the box “Send Crash Reports to Plex” and save it.
When it next crashes, the DMP file will be on your system instead of uploaded.
PlexMediaServer/AppData/Plex Media Server/Crash Reports/PLEX MEDIA SERVER//
You’ll see a .dmp file.
Please make a ZIP of that file and upload it here along with the current Logs ZIP file.
sa2000
October 22, 2021, 12:17pm
9
Pe8er:
Got new logs for you!
Could you see if you can find a filename 5ba4ed4d-7c5f-4ee8-79e8f49c-477ce4e1 - it may or may not have a filename extension
The file should have got moved to the Plex Media Server tmp directory
/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/tmp/
if you find the file - please zip it and attach here
sa2000
October 22, 2021, 12:26pm
10
Unrelated to the issue:
You have syntax error in the server network advanced setting
List of IP addresses and networks that are allowed without auth
You have an invalid character between '192.168.1 and 255.255.255.0
Please refer to the support article for the syntax and examples
Network | Plex Support
Pe8er
October 22, 2021, 3:55pm
11
Duh, you’re right. Thank you for spotting it! Just set it to 192.168.1.1/255.255.255.0
Pe8er
October 22, 2021, 3:56pm
12
Pe8er
October 22, 2021, 3:57pm
13
Uploading the DMP file. Sorry for multiple posts, I’m very disorganized this morning.
d06b9a0d-298a-45fb-b13d94bb-42f42f4f.dmp.zip (337.3 KB)
sa2000
October 27, 2021, 11:50am
14
Pe8er:
Found it, here you go
Thank you - The crash was in the Music Sonic Analysis code. I have referred it to the development team - there may be a fix already on its way. I will let you know once the fix is released
sa2000
15
Thank you. it is a similar crash
Pe8er
October 27, 2021, 3:42pm
16
Makes sense, now I realize crashing began around the time when Sonic Analysis became available. Thank you for finding out! Crossing fingers for a fix.
sa2000
November 12, 2021, 9:34am
17
The fix for this Sonic Analysis crash has been released in the latest beta - Plex Media Server 1.25.0.5220
See Release Notice
Plex Media Server 1.25.0.5220 is now available to Plex Pass users in the Beta update channel.
NEW:
(Metadata) Add Croatian as language option for modern Movie and TV agents (#13119)
(Subtitles) New font package and default styles for server-side subtitle rendering
(Transcoder) Architectural changes to provide future support for hardware transcoding on additional NAS devices
(Transcoder) Architectural changes to provide improved support for remuxing some HDR formats
(Transcoder) Support for ha…
(Music) Rebuilding sonic indexes could result in crashes.
Pe8er
November 17, 2021, 7:46pm
18
Confirming it doesn’t crash anymore. Thank you!!
system
Closed
February 15, 2022, 7:46pm
19
