Has anyone seen an issue with Plex DVR cutting off recordings early? I am on the latest PMS and I noticed that occasionally a show will only record a couple of minutes and then abruptly stop. Because it’s not consistent it’s definitely hard to “reproduce”. It happened again today with a show that was supposed to be 30 minutes long and the DVR only recorded for 3-4 minutes before stopping. The Guide says it was 30 minutes long and that it was recorded successfully but that’s obviously not the case. I can provide logs if that would help debug.
Thanks!
