Plex DVR: "There was a transcode error" when trying to record a program
You would start the command on the line you typed in:
Thanks John,
Thats what I entered however get the following error, am I still entering it incorrect?
Error is saying the Remote Server returned an error 404 Not Found. That sounds like the tuner device is rejecting the request to tune the channel. The http part of the command is what Plex is using to tune the channel to record a show. I copied that part directly out of your logs for the failed recording attempt. This was found by looking for a line shortly after the recording start that says ā€œFinal URLā€. What type of device is this? Do you have the software that came with the tuner installed, or just the driver installed?
i have a leadtek winfast DTV1000s card. I have had just the drivers installed up until now. I just installed the full software and got the same powershell fault
I know the card isnt on the supported card list but has worked on every other PC PVR software to date
I get the same problem, but I’m using the supposedly supported Hauppauge QuadTV tuner. Only seems to happen on certain programs frustratingly and has been working fine up until around 6 weeks ago. I think a Plex Server update has caused the problem.
Let me know if this is helpful for this topic, or if it should be moved to another topic.
Windows 10 Professional
32GB Ram
Plex runs from C: (1.14.0.5468)
Recordings stored on external USB (N: drive - NTFS)
Using HDHomeRun Tuner (3 tuners) - 20180817 version
I watched Plex try to record the show: It recorded for about 5 seconds, then failed with the error.
Than maybe a minute later, plex tried recording the show again. After 5 secs, it failed.
Plex tried 3 times to record the show.
Logs attached.
Capture
Plex Media Server Logs_2018-11-24_20-01-38.zip (2.7 MB)
Plex Media Server Logs_2018-11-24_20-09-06 (3 fails).zip (3.0 MB)
P.S. Going into Plex Recordings Calendar the next day, that show no longer shows up in yesterday’s list of shows to record. It does create a tracking problem in that if shows that don’t record for some reason, are removed, it prevents you from realizing that you even have a problem. Just saying…
same for me ;/
are there any news on this?
I think for me it happens if the recording times overlap a little. despite having a homerun expand quad tuner.
Please is there any suggestions, i am having the same transcoder error when trying to record, using HDHomerun Prime.
from the last 40 to 50 recordings there were only 5 that were completed. and these wehere the ones that did not overlap.
from the overlapping recordings not a single one worked. despite having a 4 tuner device.
it looks like the latest version did fix the problem. overlaping recordings are fine now
and the behavior looks to be quite nice also. overlapping recordings on the same channel don’t use a second tuner but only one.
