Hi, I have been getting this error for a while now. Have tried multiple restarts and transcoder setting chagnes. Still cant find a solution
When I try and record something from the guide thats already in progress it sometimes works ok. 50/50.
When I have a scheduled recording it seems to always fail. 100%. Just get a “There was a transcoder error”
Any help would be appreciated.
Windows 10 Pro
AMD X3 450 3.2ghz
4GB Ram
Geforce 9500GT
Networked HDHomerun brand new.
All wired connections
What version of Plex Media Server? Have you looked in the Plex Media Server logs to see if there are any other messages?
I have gone through them a little bit, but I’m not really sure where to look for this error. I was trying to record a tv show. The transcoder logs are extremely difficult to decipher. Which logs would be specifically helpful to look through? On version 1.9.2.4285
Same issue here but only on second recording
To clarify the first recording I said on my dual tuner works, the second one always says Transcodes error when trying to record two shows at the same time
Plex Media Server.log is the one to start with.
Ok, I looked through it but its still a little rough because of all the debug entries. Not sure If I should have had that on. Is there any problem with posting it here?
This shows up right away, but I think this was after a server restart.
Oct 02, 2017 20:00:05.905 [5356] ERROR - [Transcoder] [mpeg2video @ 00f228e0] Invalid frame dimensions 0x0.
Then there is this section about 3 minutes into the recording
Oct 02, 2017 20:03:02.191 [7216] DEBUG - Completed: [127.0.0.1:52431] 206 PUT /video/:/transcode/session/c57194bc-5a81-44d4-be54-afcd540fe240/81681db7-6ffa-4725-babd-1879f0756bb3/progress/stream?index=1&id=0&codec=ac3&type=audio (9 live) 1ms 227 bytes
Oct 02, 2017 20:03:02.206 [5688] ERROR - [Transcoder] Invalid decoder type ‘mpeg1video’
Oct 02, 2017 20:03:02.222 [5268] DEBUG - Jobs: ‘C:\Program Files (x86)\Plex\Plex Media Server\PlexTranscoder.exe’ exit code for process 8444 is 1
Oct 02, 2017 20:03:02.222 [0804] DEBUG - Jobs: ‘C:\Program Files (x86)\Plex\Plex Media Server\PlexTranscoder.exe’ exit code for process 8444 is 1
Oct 02, 2017 20:03:02.222 [5268] DEBUG - DVR:Recorder: Asked to stop recording ‘The Big Bang Theory - E2 - The Retraction Reaction’.
Oct 02, 2017 20:03:02.222 [5268] DEBUG - DVR:Recorder: Stopping transcode session.
Oct 02, 2017 20:03:02.222 [5268] DEBUG - Killing job.
Oct 02, 2017 20:03:02.222 [7216] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Oct 02, 2017 20:03:02.222 [7216] DEBUG - Auth: authenticated user 1 as xxxxx
Oct 02, 2017 20:03:02.222 [7216] DEBUG - Auth: Came in with a super-token, authorization succeeded.
Oct 02, 2017 20:03:02.238 [9144] DEBUG - Request: [127.0.0.1:51935 (Loopback)] GET /status/sessions/background (8 live) GZIP Signed-in Token (xxxxx)
Oct 02, 2017 20:03:02.238 [7224] DEBUG - Completed: [127.0.0.1:51935] 200 GET /status/sessions/background (8 live) GZIP 2ms 397 bytes (pipelined: 36)
Oct 02, 2017 20:03:02.238 [5268] DEBUG - Job was already killed, not killing again.
Oct 02, 2017 20:03:02.238 [5268] DEBUG - Stopping transcode session 04fcdfac-2f0c-46c7-b128-86113d2d9175
Oct 02, 2017 20:03:02.238 [5268] DEBUG - DVR:Grabber: Freed a tuner (now 2 available)
Oct 02, 2017 20:03:02.238 [5268] DEBUG - DVR:Grabber: Recording for ‘The Big Bang Theory - E2 - The Retraction Reaction’ stopped with status error.
Oct 02, 2017 20:03:02.238 [5268] DEBUG - DVR:Grabber: Using recording status.
Oct 02, 2017 20:03:02.238 [5268] DEBUG - Activity: updated activity e71cb71a-a7f5-4874-9343-3b8418974998 - completed 100% - Recording
Oct 02, 2017 20:03:02.238 [0804] DEBUG - Jobs: ‘C:\Program Files (x86)\Plex\Plex Media Server\PlexTranscoder.exe’ exit code for process 1892 is -1059143458
Oct 02, 2017 20:03:02.238 [5268] DEBUG - DVR:Grabber: Scheduling ‘The Big Bang Theory - E2 - The Retraction Reaction’ for assimilation.
Oct 02, 2017 20:03:02.238 [2596] DEBUG - DVR:Subscription: Failed to resolve subscription for ‘guid: com.gracenote.onconnect://show/185554 thumb: http://tmsimg.plex.tv/assets/p14215412_b_v5_ad.jpg title: The Big Bang Theory type: 2 year: 2007’ to library item
Oct 02, 2017 20:03:02.238 [2596] DEBUG - DVR:Grabber: Postprocessing, we’re going to put The Big Bang Theory - E2 - The Retraction Reaction in C:\Users\xxxxx\Videos\Recorded TV\The Big Bang Theory (2007)\Season 11\The Big Bang Theory (2007) - S11E02 - The Retraction Reaction.ts
Oct 02, 2017 20:03:02.238 [2596] DEBUG - DVR:Grabber: Operation for The Big Bang Theory - E2 - The Retraction Reaction completed with status error (There was a transcoder error)
Did you ever get your issue fixed? I seem to be having the same problem, with similar Widows 10 setup (Plex Server Version 1.9.6.4385 ). Every recording starts and finished instantly, and the Recording Schedule says “there was a transcoder error”. I did recently update the firmware (20170930) on my HDHR Prime Tuners, I wonder if this caused the issue?
Unfortunately no I didn’t. Sounds like the same problem I’m having. It’s definitely a plex problem. I switched to the hd homerun DVR application they sell with the tuner and it works like a champ. Hasn’t missed a recording yet.
Unfortunately this was my only reason for plex pass, so I’ll cancel it.
Well I tried to fix by entirely deleting and reinstalling Plex server and the problem, still persists: recording “completes”immediately after starting, empty file created, transcoder error.
Yea I tried that too. No luck. If you’re in the market for a new tuner, the home run hd is great, and the software for it is like $25 per year I think. The DVR works so much better than Plex.
