Plex Employee to Reset Server Certificate? "API rate limit exceeded" error
Hey @ChuckPa, I believe I would be looking for a reset too please.
@Itzando
I see 2 main servers, one of which is a duplicate.
Which should I be paying attention to?
@Chuckpa There should only be 1 running. What do you need to determine which is which?
check your PM
Hi there,
I believe the same issue is happening to my server, could you please reset and clean up? Thank you,
Kaya
It would seem I am having this issue now as well.
Plex Media Server Logs_2021-09-12_22-45-13.zip (514.9 KB)
Hello @ChuckPa
I’m having the same issue with the following errors. Could you also please reset my cert?
CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?> <errors> <error code="1003" message="API rate limit exceeded"/> </errors>
Thank you
Hello,
It appears that I am encountering this same problem. Could I get a reset as well, please?
Sep 13, 2021 05:12:35.426 [0x7faf7c2eab38] DEBUG - CERT: Forcing refresh.
Sep 13, 2021 05:12:35.426 [0x7faf7c2eab38] DEBUG - CERT: Certificate did not exist, fetching a new one.
Sep 13, 2021 05:12:36.055 [0x7faf7c2eab38] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
<errors>
</errors>
Sep 13, 2021 05:12:36.056 [0x7faf7cd7db38] DEBUG - [CERT] MyPlex: Last published value didn't change, we're done.
Thanks!
@yjonjonman9_gmail_com
@chauster
@t-richards
Your certificate has been reset. You may restart the server
Hi Chuckpa,
Thanks for the quick reply. I unforunately still have the same issues. and I’m getting this message on the log
This all happened after i recently upgraded my synology nas to DSM7. Follow the guide to reinstall plex.
Let me know what info i can grab for you.
Thanks,
Hey @ChuckPa
I think I may be experiencing something similar. I moved my server today but am having issues connecting through plex.tv securely. Same errors,
https://plex.tv/api/v2/devices/0e2e099542ca091fa9c3129014dc3a6a42ecd01a/certificate/csr?reason=missing&invalidIn=0 (reused)
Sep 12, 2021 22:16:21.541 [7768] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
Not sure if it showing duplicate servers. I had signed out of my old Server after migrating and not before.
Let me know if you can reset the cert!
Thanks,
@chauster
429 = RATE LIMITED
I reset the cert but you’ll now need to keep it off for a while until it releases from being limited.
Normally, when i reset the cert, the 429 is cleared. Which server name should I have reset ?
ALL:
REQUEST: When asking for a certificate reset, Please provide the server name.
@TheNelsonAteHer
I see your certificate was stuck in GENERATING status.
I’ve reset it.
You may restart the server.
Hello @ChuckPa,
Unfortunately I am stuck back in the same place as well. Initially, it looked like things were going well until the request for the certificate timed out:
Sep 13, 2021 05:38:03.389 [0x7f0ff4d77b38] ERROR - CERT: Error acquiring new certificate: Timed out waiting for cert response from plex.tv
Then, 15 minutes later, Plex retried the request and got rate limited again.
Sep 13, 2021 05:53:03.389 [0x7f0ff51e3b38] DEBUG - CERT: Forcing refresh.
Sep 13, 2021 05:53:03.389 [0x7f0ff51e3b38] DEBUG - CERT: Certificate did not exist, fetching a new one.
Sep 13, 2021 05:53:04.041 [0x7f0ff51e3b38] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
<errors>
</errors>
Sep 13, 2021 05:53:04.041 [0x7f0ff553db38] DEBUG - [CERT] MyPlex: Last published value didn't change, we're done.
Once in this state, Plex seems to retry the request every two minutes which can’t be helpful…
Sep 13, 2021 05:55:04.581 [0x7f0ff51e3b38] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
<errors>
</errors>
Any ideas?
@chauster
429 = RATE LIMITED
Hi Chuckpa,
Cosmo-plex is the server name.
Do i need to shut the server down for sometime after you reset the cert?
@t-richards
Yep… unfortunately you need wait now.
For you and all who are getting 429 (Rate Limited) state –
  1. Stop the server
  2. Wait 60 minutes
  3. Try again
  4. If it doesn’t come right up
  5. Server stop
  6. Repeat
@chauster
It was stuck in generating again
Restart… try again
I will keep an eye on it
@chauster
It went to GENERATING again.
This is an issue for Plex.tv folks to clear.
I’ve alerted the team. Fortunately Europe will wake within the hour
