Same issues here.
CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
Server Name: jimmy-server
***I can just turn this off and wait until tomorrow, if that would work.
Same issues here.
Thanks, I’ll check back in a few hours. Let me know if there’s any info i can share
Plex.tv is having a problem. (see above). I just alerted the operations team.
Local time here is 02.00
I will be offline soon
I will return here when I wake
Understood! Thanks for the help.
folks, try now (restart)
Works for me now! Thanks!
@ChuckPa Everything seems to be working again, thanks!
Much appreciated!
Thanks,
Hello ![]()
i usually use a rasperry to connect to plex, but today, the server (from my NAS, on the same network) was found, but not reachable. (the web interface is functionnal, as well as my app on android)
After some research, i found these messages each i was trying to connect:
CERT incomplete TLS handshake: tlsv1 alert unknown ca
yes, 2 times, and i don’t know why.
From what i read, can you reset the certificate?
thanks in advance
Nevermind, all is fine now. My version of the server was not up to date.
@ChuckPa Thanks for all your hard work.
Hopping on this train as well. New PMS installation and I am running into a whole lotta
ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
<errors>
<error code="1003" message="API rate limit exceeded"/>
</errors>
If you could also reset my certs, that’d be lovely. For now, I’ve turned off the server until you’ve done so.
I reinstalled Plex and am pointing it to my old Plex Media Server directory. HTTP works but HTTPS does not. I think I need a cert reset too. I’ve shutdown my server. This is from the debug console:
Sep 19, 2021 23:45:26.661 [10740] Debug — [CERT] MyPlex: Last published value didn’t change, we’re done.
Sep 19, 2021 23:45:26.661 [4216] Error — [CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
Sep 19, 2021 23:45:26.661 [4216] Error — [CERT] Found a certificate, but couldn’t install it.
Sep 19, 2021 23:45:26.661 [4216] Debug — [CERT] CERT: Forcing refresh.
Sep 19, 2021 23:45:26.662 [4216] Error — [CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
Sep 19, 2021 23:45:26.662 [4216] Debug — [CERT] CERT: Unable to parse existing certificate, fetching a new one.
Sep 19, 2021 23:45:26.662 [4216] Debug — [CERT] HTTP requesting GET Sign In | Plex
Sep 19, 2021 23:45:26.844 [4216] Debug — [CERT] HTTP/1.1 (0.2s) 200 response from GET Sign In | Plex (reused)
Sep 19, 2021 23:45:27.099 [4216] Debug — [CERT] HTTP requesting PUT https://plex.tv/api/v2/devices/a67fa24b6c558a695b53ed42086625f7ba78eac9/certificate/csr?reason=unreadable&invalidIn=0
Sep 19, 2021 23:45:27.280 [4216] Debug — [CERT] HTTP/1.1 (0.2s) 429 response from PUT https://plex.tv/api/v2/devices/a67fa24b6c558a695b53ed42086625f7ba78eac9/certificate/csr?reason=unreadable&invalidIn=0 (reused)
Sep 19, 2021 23:45:27.280 [4216] Error — [CERT] CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
Certificate reset.
You may restart the server.
In the future, there is no need to keep deleting the server instance. You had used up a large number of certificates do to this.
Seem to be having the same issue. Could i get my cert rest please?
Server Name: Mattlock Holmes
Same issue after a reinstall
Server= New Server
Can I get my cert reset also having this issue also, from the logs:
<errors>
</errors>
Sorry for the delay.
I only see one server on this account and it does not have a certificate.
I can’t help you much with this (Windows) but the server was last seen 4 hours ago as of this post time.
Certificate reset, you may restart the server.
