That worked! Thank you!
@Mark63368 done. you may need to restart your server
Thanks @BigWheel . Iām still having issues with my connection while on my local network. Everything is a relay connection. Any ideas why? My remote connections seem to be 100% fine.
Check that device and server on the same local network? like some routers have a guest wifi network so devices can end up on two different lans.
if your server is running on a docker then docker assigns a separate IP schema and it needs to be put in bridge mode so it is on local lan if i recall ( I am not a docker expert).
Could just be a DNS issue. I generally recommend folks use Googleās DNS to check rather than using the ISP default
It does not sound like there is a cert issue anymore at least. but I would restart all player devices as well.
@bigwheeel The devices and server are on the same network. I have a lot of errors in the Server log. Would that info help you help me?
Hi. Iām having the same problem over here.
Iām getting this message:
CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
Iām getting the same error on my end over and over.
Dec 12, 2021 21:30:45.781 [0x30c3f8000] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
Having the same API limit issue
Dec 12, 2021 21:35:42.261 [0x149c4db1cb38] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
Hi @BigWheel
Iām having the same problem and seeing the same errors in my log:
"CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
error code=ā1003ā message=āAPI rate limit exceededā/>
Can you help with this? Nothing has changed with my server or network that I am aware of.
Plex Media Server.log (5.5 MB)
@leo632 it is reset. You might have to restart device.
@yaryarrr have you tried restarting your server? it does not appear to have a cert yet to reset.
@asajinx reset your on the server that starts with P. since your other one looked like it was created today. might have to restart server.
@arthuraltino reset your cert. might have to restart
@BigWheel, requesting a reset for my cert as well for server that starts with S. Thank you.
@bhduong01 done. you might need to restart
I had it shut down overnight and turned it back on this morning. I just restarted it. All seems well from my end, @BigWheel can you confirm it looks good on your side, please? Thanks!
Thank you @BigWheel, it automatically recovered and was able to download a new cert.
Dec 13, 2021 15:00:53.662 [8203] DEBUG - CERT: Downloaded new cert from plex.tv; took 13 tries.
Dec 13, 2021 15:00:53.861 [8204] DEBUG - [CERT] Subject name is /CN=ā¦
Dec 13, 2021 15:00:53.861 [8204] DEBUG - [CERT] Installed certificate with fingerprint ā¦
@yaryarrr it looks fine to me.
Could you please assist? Thanks!
requesting cert reset please. im receiving the api limit error. Tried looking for the cert-v2.p12 file but canāt seem to find it in the nvidia shield plex data directory
thank you!
