Your certificate was stuck Generating. I reset it.
Please restart the server
perfect, thank you.
Hi, recently set up a private DNS at home but from what i understand this shouldnât cause any issues for plex, but ever since i rebuilt my library i have the below errors which i believe are to do with the SSL certs.
[CERT] HTTP requesting GET Sign In | Plex
[HttpClient] HTTP/2.0 (0.1s) 200 response from GET Sign In | Plex (reused)
[CERT] HTTP requesting PUT https://plex.tv/api/v2/devices/2f9da8b94c4cb3732bef46cccc64baca99edf87c/certificate/csr?reason=unreadable&invalidIn=0
[HttpClient] HTTP/2.0 (0.0s) 429 response from PUT https://plex.tv/api/v2/devices/2f9da8b94c4cb3732bef46cccc64baca99edf87c/certificate/csr?reason=unreadable&invalidIn=0 (reused)
[CERT] CERT: Error acquiring new certificate: Failed to upload CSR: 429,
[CERT] MyPlex: Last published value didnât change, weâre done.
[CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
[CERT] Found a certificate, but couldnât install it.
[CERT] CERT: Forcing refresh.
[CERT] CERT: Unable to parse existing certificate, fetching a new one.
and just keeps looping that info.
I have reset your certificate.
Please restart the server.
That worked! Thank you so much!
@CryoTwinkie your server got a new cert yesterday and i donât see anything unusual about it. Are you still having issues?
done @michaelage
Thank you! it works like a charm!!!
Hello,
i have the same problem cert canât be renewed and i have the folllowing error âapi rate limit exceededâ as what i can see in the pms log.
Can you please reset my certificate too ?
Thanks !
I have same the secure access / cert problem and also get the âapi rate limit exceededâ error message in the logs.
Can you reset my certificate as well.
Thank you!
@Psyko460 - which server ?
@massimo00 â Certificate reset . Restart your server
@danny251 â Certificate reset. Restart your server
Works again. Thank you
@ChuckPa The server name is Dalaran
Do you have a link where i can manage all server and delete the one i donât use anymore ?
Settings - Authorized Devices (upper left corner) - Server (dropdown).
Shortcut is: https://app.plex.tv/desktop/#!/settings/devices/pms
I have reset the certificate for Dalaran
I am having the same error: CERT: Error acquiring new certificate: Failed to upload CSR: 429
Can I get a reset please? Thank you!
Can someone please reset my API hits so that I can get the certificate installed please? Thank you!
