Plex Employee to Reset Server Certificate? "API rate limit exceeded" error
Thank you.
Certificate reset.
You may restart the server.
You’re an angel! Thank you.
Hi Chuck, may I also request a certificate reset?
Hi @ChuckPa ,
I’m having the same issue:
WARN - [CERT] TLS connection came in with unrecognized plex.direct SNI name '192-168-1-252.c38580e7ba574e12bb47bbd58a1886f9.plex.direct'; using installed plex.direct cert
Can you also reset it for me ?
THX.
Thank you! That worked
@ChuckPa Here is the full ZIP logs file
Plex Media Server Logs_2021-07-04_09-30-44.zip (3.5 MB)
@nasbear
Your certificate is valid
https://acme-v02.api.letsencrypt.org/acme/order/44416311/10844148517 Valid Sun, 04 Jul 2021 14:52:31 +0000 Sun, 04 Jul 2021 14:52:42 +0000
Was throttled
Jul 03, 2021 21:31:40.609 [8180] DEBUG - HTTP requesting PUT https://plex.tv/api/v2/devices/65fa2e4db497bf745f0f6d931eec08c6e4d83d3a/certificate/csr?reason=expiring&invalidIn=-52300
Jul 03, 2021 21:31:40.757 [8180] DEBUG - HTTP/1.1 (0.1s) 429 response from PUT https://plex.tv/api/v2/devices/65fa2e4db497bf745f0f6d931eec08c6e4d83d3a/certificate/csr?reason=expiring&invalidIn=-52300 (reused)
Jul 03, 2021 21:31:40.758 [8180] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
<errors>
  <error code="1003" message="API rate limit exceeded"/>
</errors>
Jul 03, 2021 21:31:40.768 [3356] DEBUG - [CERT] Subject name is /C=US/ST=California/L=Los Gatos/O=Plex, Inc./CN=*.e1a5e63c7a064241b079d736e4b4f3ae.plex.direct
Jul 03, 2021 21:31:40.769 [3356] DEBUG - [CERT] Installed certificate with fingerprint a4:27:67:22:1b:5c:c6:3d:76:03:cf:0e:e5:26:72:4d:0b:1f:87:5f.
Jul 03, 2021 21:31:40.769 [3356] DEBUG - [CERT/OCSP] Stapling requests will be made to 'http://ocspx.digicert.com/'.
Jul 03, 2021 21:31:40.770 [3356] INFO - [CERT/OCSP] Successfully retrieved response from cache.
Restart the server
@Speculos
Reset - you may restart
@paazel
Both machines reset. restart both
Thanks a lot, I no longer see the warning.
Good weekend.
Thank you!
Hi hi, I’m having the same issue. Could someone also reset mine? Thanks in advance, and let me know if you need the logs.
@shayanzadeh
Prestidigitation applied. Old server removed, remaining two reset.
You may restart both
I’m also seeing this on my server, running version v1.23.3.4707-ebb5fe9f3 in docker. Could I have my certificate reset? Thanks!
Hi there, may I please request a certificate reset? A few days ago I could no longer access my server via app.plex.tv or from any remote access. Here’s what my logs say that lead to this forum:
CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?> < errors> < error code=ā€œ1003ā€ message=ā€œAPI rate limit exceededā€/> < /errors>
Please and thank you!
Please reset my server also.
Synology Package - version 1.23.4.4712
Jul 05, 2021 20:07:22.596 [0x7f1f72697b38] DEBUG - HTTP/1.1 (0.0s) 429 response from PUT https://plex.tv/api/v2/devices/42e797e42ee5918ccd9ad8b96fe0bd46483203db/certificate/csr?reason=expiring&invalidIn=-195400 (reused)
Jul 05, 2021 20:07:22.596 [0x7f1f72697b38] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
Plex Media Server Logs_2021-07-05_20-39-55.zip (4.5 MB)
Hello, my server is also having this issue. Can I be reset? Thanks!
Hi @ChuckPa, I’m afraid this has reoccurred again (again about 12 days after the last reset). I’ve checked everything I can think of on the local network: the server is on a static IP and everything looks like it’s working fine with port forwarding etc. I’ve attached my log files if there’s anything else that I can try on my end let me know. Could you reset my certificate again?
Thanks.
Plex Media Server Logs_2021-07-08_17-46-02.zip (748.9 KB)
@ChuckPa Since a few days i’m also having problems. Seems to be certificate related. I can access plex trough local website. Also trough app.plex.tv (remote). But I cannot use the android app. The android app can login, but as soon as it tries to show the library’s it keeps on loading. Also tried on a 2nd phone outside the network.
I’ve checked port forwarding, recreated the docker, rebooted router and still not working.
WARN - [CERT] TLS connection came in with unrecognized plex.direct SNI name ā€˜192-168-1-100.cdad5a766c184b2ba50a8448d4a3cada.plex.direct’; using installed plex.direct cert
Another line says: DEBUG - CERT: incomplete TLS handshake: sslv3 alert bad certificate
Plex Media Server Logs_2021-07-09_00-13-45.zip (577.7 KB)
@timalander
Which server please ?
The user has 8 servers: Red red red Kemba SHIELD Android TV red tim red
Would you like me to do some cleanup while there ?
@leo632
Your certifcate has been reset. You may restart the server.
@Senaxx
The certificate has been reset. You may restart the server.
