running WD PR 4100 latest version
have found this twice now on 4/13/21 and 5/4/21
deleted it the first time and quarantined today.
running Anti-Virus Essentials
How do I get rid of this for good?
mnt/HD/HD_a2/Nas_Prog/plex_conf/Plex Media Server/Metadata/Albums/a/373d38789d1f142120a6df5b6b60b964cab65cf.bundle/Contents/_stored/posters/tv.plex.agents.music_33fa24abd7684989291095ca17527d65389c5f5c: BC.Img.Exploit.CVE-2017-16386-6404655-1 VIRUS DETECTED
I do, i have now gone to Discogs and used one of their images instead of the match from Plex. Will re run Anti Virus again. Only takes like 50 hours to do the full system scan.
Now 4 Places, help is no where to be found, please someone point me in right direction.
I just deleted the Weezer OK Human file folder and rerunning Anti Virus, Will see if it picks it up again or not.
5/16/21
/mnt/HD/HD_a2/Nas_Prog/plex_conf/Plex Media Server/Cache/PhotoTranscoder/76/766f32167fba984259895d7061f39ed9b4253bab.jpg: BC.Img.Exploit.CVE-2017-16386-6404655-1 VIRUS DETECTED
/mnt/HD/HD_a2/Nas_Prog/plex_conf/Plex Media Server/Cache/PhotoTranscoder/4d/4dedd2284bb9de3a87b911b8fdd53e816f5d9b18.jpg: BC.Img.Exploit.CVE-2017-16386-6404655-1 VIRUS DETECTED
/mnt/HD/HD_a2/Nas_Prog/plex_conf/Plex Media Server/Cache/PhotoTranscoder/bb/bb7a9ac136568b33725a23c3c8620a003443b5c1.jpg: BC.Img.Exploit.CVE-2017-16386-6404655-1 VIRUS DETECTED
/mnt/HD/HD_a2/Nas_Prog/plex_conf/Plex Media Server/Metadata/Albums/a/373d38789d1f142120a6df5b6b60b964cab65cf.bundle/Contents/_stored/posters/tv.plex.agents.music_33fa24abd7684989291095ca17527d65389c5f5c: BC.Img.Exploit.CVE-2017-16386-6404655-1 VIRUS DETECTED
Personally I think these are all false positives anyway. Even if not, CVE-2017-16386-6404655-1 is an old PDF exploit and you’d need to open the files with a very old version of acrobat reader for it to even matter.
rm 766f32167fba984259895d7061f39ed9b4253bab.jpg ’ :cant remove No such file or directory
I cant seem to get all the way to the"76" directory. If i use find it finds the file but rm does not remove it.
I can only get to plex_conf using the cd command
any ideas why?
did a total factory reset. seems to be running better. Had a bunch of little glithes going on. Like some photos not loading and playing. While away from home music play back would start and stop. So may the whole database was FUBAR
ran full system virus scan and no virus found after factory reset and reload media files . Had to down grade to version 1.21.4.4079 as the latest update made Photos not work.
