Plex failed RaspberryPi
from yesterday my plex server which is installed on raspberry pi is not working.
these are the logs.
● plexmediaserver.service - Plex Media Server for Linux
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2019-01-29 08:03:35 IST; 5s ago
Process: 1419 ExecStartPre=/bin/sh -c /usr/bin/test -d "{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "{PL
Jan 29 08:03:30 raspberrypi systemd[1]: plexmediaserver.service: Unit entered failed state.
Jan 29 08:03:30 raspberrypi systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
Jan 29 08:03:35 raspberrypi systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
Jan 29 08:03:35 raspberrypi systemd[1]: Stopped Plex Media Server for Linux.
Jan 29 08:03:35 raspberrypi systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Jan 29 08:03:35 raspberrypi systemd[1]: Failed to start Plex Media Server for Linux.
Jan 29 08:03:35 raspberrypi systemd[1]: plexmediaserver.service: Unit entered failed state.
Jan 29 08:03:35 raspberrypi systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
