Plex first shows transcoding and then direct stream
Does anyone know why the following happens?
I have the movie on my NAS and I’m playing it on my TV.
The movie is in E-AC-3 audio format. When playing, the Plex dashboard says “Transcode to AAC,” but this only lasts for about 5 seconds, and then the word “Transcode to AAC” changes to “Direct Stream.”
Is this because my TV can play E-AC-3, or because the entire audio track has been transcoded?
Is that the same file? The durations are different.
It’s a different file because after posting this, I also wanted to share a screenshot of what the first few seconds look like, and then I clicked on a file from the same series. However, both files use the same audio and video codec. Both files transcode the first 5 seconds to AAC, and after that, it says “direct stream.”
I can’t think of why it would do this. If you reproduce and provide the server logs i can check what it actually does.
I also find it strange that it does this.
Here are the logs. I just started an episode twice around 11:40 AM, and with both subtitles it did the same thing as I described above.
I sent the logs in a private message
Good morning, have you been able to look at the logs and found anything?
Ok, looked at your logs. What you are seeing is the theme music being played first, then the main video. For some reason the theme isn’t playing properly so PMS is transcoding it to a different format. The UI is just slow to change, which is why you see 2 different status. The second status is the correct one for the actual video.
Okay thanks for watching!
The theme music comes from Plex sources, right? Do you happen to know what codec that is?
The theme is an mp3 file. The tv app doesn’t want a music file but is asking for an audio only mp4 files so pms is transcoding it to aac, which is what you see in the dashboard. I don’t remember if the tv app always did it this way or if it’s a change.
Okay, thanks so much for watching and sharing your knowledge! I learned something new too.
