Plex for Android crashing
Plex version 6.15.2.4143 running on Nvidia Shield TV
Plex is crashing whenever I try to select a TV show without metadata info.
Here’s what I gathered from the logs:
04-05 21:07:09.914 i: [UserAction] Click item Kitchenightil (/library/metadata/2151/children).
04-05 21:07:09.917 i: Fetching [method:GET] https://192.168.86.28:32400/library/metadata/2151?includeExtras=1&X-Plex-Token=...i3tN
04-05 21:07:09.942 i: Fetching [method:GET] https://192.168.86.28:32400/library/metadata/2151/children?X-Plex-Token=...i3tN
04-05 21:07:10.002 i: Creating PreplayShowActivity.
04-05 21:07:10.019 i: Fetching [method:GET] https://192.168.86.28:32400/library/sections/1/all?includeCollections=1&type=2&X-Plex-Token=...i3tN
04-05 21:07:10.033 i: [Boot] PreplayShowActivity took 9ms to run create behaviours.
04-05 21:07:10.039 i: Resuming PreplayShowActivity.
04-05 21:07:10.114 e: Fatal exception occurred.
04-05 21:07:10.115 e: An exception occurred: java.lang.RuntimeException: Unable to resume activity {com.plexapp.android/com.plexapp.plex.activities.tv17.PreplayShowActivity}: java.lang.NullPointerException: Attempt to invoke virtual method ‘boolean java.lang.String.equals(java.lang.Object)’ on a null object reference
04-05 21:07:10.116 e: Stacktrace: java.lang.RuntimeException: Unable to resume activity {com.plexapp.android/com.plexapp.plex.activities.tv17.PreplayShowActivity}: java.lang.NullPointerException: Attempt to invoke virtual method ‘boolean java.lang.String.equals(java.lang.Object)’ on a null object reference
at android.app.ActivityThread.performResumeActivity(ActivityThread.java:3454)
at android.app.ActivityThread.handleResumeActivity(ActivityThread.java:3494)
at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2758)
at android.app.ActivityThread.-wrap12(ActivityThread.java)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1461)
at android.os.Handler.dispatchMessage(Handler.java:102)
at android.os.Looper.loop(Looper.java:154)
at android.app.ActivityThread.main(ActivityThread.java:6120)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:865)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:755)
Caused by: java.lang.NullPointerException: Attempt to invoke virtual method ‘boolean java.lang.String.equals(java.lang.Object)’ on a null object reference
at com.plexapp.plex.activities.tv17.PlexPreplayActivity.an(SourceFile:603)
at com.plexapp.plex.activities.tv17.k.a(SourceFile:122)
at com.plexapp.plex.activities.tv17.PlexPreplayActivity.ar(SourceFile:136)
at com.plexapp.plex.activities.tv17.PlexPreplayActivity.onResume(SourceFile:129)
at android.app.Instrumentation.callActivityOnResume(Instrumentation.java:1269)
at android.app.Activity.performResume(Activity.java:6768)
at android.app.ActivityThread.performResumeActivity(ActivityThread.java:3431)
… 10 more
Potentially related thread:
Would be really grateful if someone from the Plex team can comment on this. I’m happy to install debug builds or anything else that would help in tracking this down.
Same issue +1. Crashes straight after selecting a tv channel. Transcoding seems to start on the server correctly - process still running after the Android app crash. Works fine via web though. Anybody an idea?
Having the exact same issue here. Plex reports that my DR has 2 tuners recording at all times. It is a 2 tuner HDHomerun. Successful or not Plex will report a 3rd recording after trying to launch a channel. There are a few posts in the DVR and Live TV forum with similar issues.
Bumping this up in hope to get a response from Plex team member.
Hi Plex team. This issue is effecting a large portion of my library, effectively making Plex unusable. It seems I am not alone. Is there any chance someone might look into this? If there’s anything I can do to contribute to fixing this please let me know.
