Server Version#: 1.32.8.7639
Player Version#: 10.5.0.4996
The latest update Plex for Android, opens, then shuts down after 2-3 seconds, now i have to reopen the app, then it shuts down again and opens automatically, and now it works fine…
Just FYI to the developers
Would need the android logs to try to see what might be causing it.
What mail should i send the logs to?
you can click on my avatar/username to message it to me on forum
Didn’t see anything wrong in logs. Trying to figure out what it might be
I can send you a screenrecord, so you can see the error better, maybe that can give you an idea?
If its possible in here…
By the way, i have cleared cache etc…
Tried reinstalling, still the same…
I am having the same issue, but I have noticed it only happens on mobile data. It works fine when connected to wifi.
I have the issue on both wifi and mobile data… :-/
Rolled back to previous app version, problem persists.
EDIT: Rollback version stopped crashing after clearing data and logging back in, but cannot access media server remotely.
EDIT2: Lack of remote access appears to have actually been a glitch in my VPN. Remote access is working now.
Spoke to soon. Problem now occurs with rolled back version. I can get it to work ONCE after clearing data and logging back in.
One of the Android devs said they think this ma be fixed in the Beta for 10.6.0 which should be out later this week.
Im already on 1.0.6.0, still the same issue.
I’ve now tried downgrading to 1.0.4.0, the issue is now gone
ok weird. thanks for update
No problem at all, keep up the good work
Still an issue with 10.6.0.5127
Downgrading to 10.4.0.4843 solves it.
Still an issue with 10.6.0.5141
Zhelll
December 22, 2023, 2:21pm
18
I have the same problem with the latest version
By the way, same issue on android tv as well…
Just noticed today
I have the same issue on multiple android devices.
It is the “Sign in automatically” option that is breaking it for me.
More specifically, it works when it is on and breaks when it is off.
