Plex for Android
Plex for Android v4.8.0.389
Plex for Android Google Play download page
Plex for Android APK ~ here (Plex Pass required)
Will be available on the Amazon App Store soon
Note: We are performing a staged rollout, which means that the update may take several hours until it´s available
NEW:
  • MKV support: Requires Experimental Player enabled, or running on the Android TV.
  • 4K HEVC support.
  • [Android TV] (e)AC3 Passthrough support.
FIXES:
  • Fix preplay screen sometimes crashing after a rotation.
  • Fix for filters showing as disabled first time a ‘Music’ section is open.
  • Fix crash editing a “Highest Quality” sync item created by an older version of the app.
  • [Android TV] Show all Watch Later and Recommended content correctly when there are no unwatched items.
Plex for Android v4.8.1.390
FIXES:
  • [Android TV] Disable passthrough by default. This was required due to a number of compatibility issues detected after the initial release. This can be re-enabled via the Settings.
Plex for Android v4.9.0.408
NEW:
  • Allow access to Channels on shared servers, provided that the owner allows it.
  • Better design for Watch Later, Recommended and Channel video preplays.
  • Some UI tweaks to improve the Material Design experience
  • Show status bar on video player overlay for Android versions that support it (KitKat and newer).
  • Improved design for announcements screen.
  • Allow MP4’s to play AC3 via audio passthrough.
  • [Android TV] Chapters are now displayed during video playback.
FIXES:
  • Improve artwork display and remove old placeholders.
  • Make sure non-admin accounts from a Plex Home are able to access their Watch Later / Recommended content.
  • Make sure unwatched indicators and the “mark as watched” action work with Watch Later / Recommended items.
  • Fix appearance of volume bar in video player settings dialog when playing on a remote player.
  • Fix issue where background art would disappear from preplay screens when they were refreshed.
  • Trim library names to prevent blank spaces in Navigation Menu.
  • Fix crash adding item to existing playlist if dialog is closed before the operation completes.
  • Fix issue when sync indicator icon was displayed on top of unwatched episode count for TV shows and seasons.
  • Fix bug where in some cases the app would crash when a music video or TV show season was selected on the new preplay screens.
  • Make sure the video settings dialog can be opened while flinging a local video to Chromecast.
  • Fix bug where Chromecast wasn’t able to reproduce videos / photos from Cloud Sync.
  • Fix issue where buffering message could be displayed incorrectly.
  • Avoid concurrent requests from Sign Up screen.
  • Fix various HEVC playback issues.
  • Fix issue where user selector was set on portrait in some tablets.
  • Resolve playback issues after a track change when playing on some remote players like the Plex for Roku app.
  • Improvements around how we handle AirPlay streaming.
  • Make sure photo player controls are updated after connecting to a remote player (or disconnecting from one).
  • [Android TV] Make sure the app behaves correctly if the system decides to recreate it (may happen if it’s been on the background for a while).
  • [Android TV] Make sure “Now playing” card in device launcher never stays open after a video has finished playing.
  • [Android TV] Resolve an occasional crash when the audio player transitions to a different track.
  • [Android TV] Fix crash that could happen if the video player was closed very quickly.
  • [Android TV] Fix issue when app was skipping Cloud Sync as an available server at start.
  • [Android TV] Fix issue where app would sometimes fail to find any servers after a device reboot.
  • [TV layout] Update Watch later and Recommended playlists after switching accounts.
  • [TV layout] Fix crash when user change occurs on Social/Online sections.
Plex for Android v4.10.0.421
Note: We are performing a staged rollout, which means that the update may take several hours until it’s available
NEW:
  • Add direct play support for VP8/VP9 video codecs and OPUS audio codec (if supported by device).
  • Allow filtering Watch later and Recommended content by “watched” status.
  • Improve home animations when new content is revealed.
  • [Android TV] Add new context actions (add to play queue, play Plex Mix, play music video) to music items.
  • [Android TV] Improve playlist support by adding options to create new playlists, and add/remove items from them.
  • [Android TV] Add play and shuffle actions when browsing libraries.
  • [Nvidia Android TV] Support refresh rate switching for video playback.
FIXES:
  • Fix issue where the Camera Upload library section picker would sometimes show the same library twice.
  • Fix Watch later videos issue affecting playbacks on AirPlay devices.
  • Don’t crash if a new video is selected while the “buffering” notification for the previous one was about to be shown.
  • Change skip back duration to 10s.
  • Fix issue where app would crash sometimes when there was a problem playing a video using native player.
  • Fix AAC playback for some HEVC MP4 files.
  • Make sure we don’t send any spurious status updates when playing photos at the request of a Plex Companion app.
  • Move “Use mobile data” settings from “Advanced>Network” to where they actually belong (“Sync” and “Camera Upload”).
  • Fix issue where “Mark as watched” would sometimes fail for Watch Later and Recommended videos.
  • Make sure audio and video play queues are cleared when they play to completion.
  • Show a helpful error message when audio playback fails because the server lacks transcoding capabilities.
  • Fix "resume playback at previous offset” for Watch later and Recommended videos.
  • Make sure we close the welcome fragment after the Google Play IAP is performed.
  • Fix playback of entire library sections when the “By folder” subset is selected.
  • Rename “Quality over local network” setting to make its purpose less ambiguous.
  • Show an explanatory message after the Google Play activation has been performed.
  • [Android TV] Show all channels in the home screen, not only the ones that have been accessed recently.
  • [Android TV] Add Play/Shuffle actions for TV shows screen.
  • [Android TV] Fix issue where artist preplay were showing wrong actions for Cloud sync items.
  • [Android TV] Don’t stop music when selecting a recommendation from launcher.
  • [Android TV] Fix issue where resume time for movies wasn’t the right one.
  • [Android TV] Show more detailed information on photo cards.
  • [Android TV] Make sure all dialogs have a consistent look and feel.
  • [Android TV] Make sure the “Now Playing” card on the device’s home screen shows the correct progress after a rewind or fast forward operation.
  • [Android TV] Don’t show ‘account’ settings for managed Plex Home users.
Plex for Android v4.10.1.423
FIXES:
  • Fix crash opening Camera Upload preferences when current user is not in a Plex Home.
  • [Android TV] Fix crash skipping to next clip in video player.
Plex for Android v4.10.2.424
FIXES:
  • Fix problem where sign in would fail if the username or password contained some special characters.
Plex for Android v4.10.3.426
FIXES:
  • Show better error message when current user can’t use Camera Upload.
  • [TV Layout] Fix menu button action not working.
  • [Android TV] Resolve crash when video playback was interrupted after 1 minute of playback in a non-activated app.
Plex for Android v4.11.0.433
NEW:
  • Add confirmation dialog when marking shows and seasons (un)watched.
  • Move clip progress to the play button in preplays.
  • Improve readability of Movie and Show summaries.
  • Improve consistency by showing the same context actions (Plex Mix, Play Video, Add to Play Queue…) in every screen that lists tracks.
  • Support new types of extras for videos (“featurette”, “short”, “concert”…).
  • [Android TV] Show icon to indicate which tracks have a music video available.
  • [Android TV] Add play and shuffle actions to TV Seasons.
  • [Android TV] Allow reordering of items within playlists and play queues.
FIXES:
  • Fix a few crashes caused by dialogs being shown after the app had been taken to the background.
  • Fix issue where switching type when a filter was applied caused no items to show.
  • Fix video information appearing under toolbar.
  • Fix issue where Mark as watched wasn’t working for Cloud Sync videos.
  • Make sure the progress and “watched” status of items from Watch Later and Recommended is updated after playback.
  • Make sure screensaver is allowed to kick in when video player is paused.
  • Improve usability of “Activate Plex” dialog in landscape orientation.
  • Show artist name on music video recomendations if available.
  • Remove play queue button when one item is in queue.
  • [Android TV] Hide Play and Shuffle actions from Cloud Sync libraries.
  • [Android TV] Fix missing icon in the resume playback dialog for Watch later and Recommended videos.
  • [Android TV] Fix issue where Global search would sometimes fail to return any results for Plex content.
  • [Android TV] Fix number of columns being shown for Watch later and Recommended content.
  • [TV layout] Correctly update the audio player information when play queue content is modified.
  • [TV layout] Fix crash opening “Advanced” settings in Fire TV and Google TV devices.
Plex for Android v4.11.1.436
FIXES:
  • Fix crash trying to determine if current video can be direct played, when codec is not known.
  • Fix crash trying to play video on an remote Plex app using the Remote Control screen.
  • Make sure items can be added to Sync when folder view is selected.
  • Prevent crash sometimes happening on preplay screens when returning from background.
  • [Android TV] Don’t crash if app starts and in-app purchase needs to be queried again.
Plex for Android v4.12.0.441
NEW:
  • Add Rotten Tomatoes ratings support.
  • Add navigation to corresponding album or artist from music tracks.
  • Add support to switch between audio streams when direct playing.
  • Allow managed users to use Camera Upload.
  • Allow content rating.
FIXES:
  • Resolve problem that caused the “Announcements” screen to be always empty.
  • Make sure app doesn’t crash if a video with no video streams is played.
  • Fix bug where ‘popular tracks’ section would sometimes be missing from artist detail screens.
  • Prevent audio player from restarting a song when shuffle and repeat mode are modified.
  • Fix crash in preplay screens if back button is pressed multiple times quickly.
  • Make sure “New library” option is not available in the Camera Upload settings for servers that are not owned.
  • [Android TV] Ensure recommendation cards stay up to date after server and user changes.
  • [Android TV] Resolve problem where global search would sometimes fail if user is part of a Plex Home.
Plex for Android v4.12.1.442
FIXES:
  • Fix bug that would sometimes cause the app to crash on startup after upgrading from an older version.
  • Fix issue where channel items were available to rate.
Plex for Android v4.13.0.448
NEW:
  • Improve subtitle handling when using Experimental Player.
  • Move preferences from the “General/Device profile” category to “Video” and “Advanced/Player”.
FIXES:
  • Several improvements and fixes related to play queues.
  • Fix issue where upwards navigation was crashing for synced content.
  • Don’t crash when trying to reorder a play queue composed of Sync items.
  • [Android TV] Resolve issue where background image wasn’t correct when browsing episodes within a season.
Plex for Android v4.13.1.452
FIXES:
  • Fix crash trying to play videos from certain channels.
  • Fix problem that prevented audio capability preferences (such as “Device supports DTS”) from being properly saved.
Plex for Android v4.14.0.459
NEW:
  • Provide better subtitles in item cards.
  • Include codec and “forced” flag in subtitle descriptions
  • [Android TV] Add Rotten Tomatoes rating support.
  • [Android TV] Add an advanced preference to force Direct Play.
FIXES:
  • Make sure “Go to album” option is only shown in those screens where it makes sense.
  • Fix issue where opening synced photos could sometimes fail.
  • Fix playback of entire photo sections.
  • Prevent Home screen from scrolling to the current position every time it becomes visible.
  • Fix crash trying to play video with no streams.
  • Apply “Sign in automatically” preference to managed Plex Home accounts.
  • Fix problem where search would not work properly for certain channels.
  • [Android TV] Fix problem where only the first search performed inside a Channel would work reliably.
Plex for Android v4.15.0.464
NEW:
  • Add “Go to show” and “Go to season” menu entries for TV show items.
  • Add runtime permissions support for devices running Android 6.
  • [Android TV] Add repeat mode to VideoPlayer and improve the usability of the controls overlay.
  • [Android TV] Add a delete option to preplay screens.
  • [Android TV] Improve title and subtitle for photos and albums.
FIXES:
  • Correctly update navigation menu when “Show camera roll” preference changes.
  • Fix issue where progress of Watch Later and Recommended videos wouldn’t update after playback.
  • Fix ‘stop’, ‘next’, and ‘previous’ actions in audio player when current track is still loading.
  • Fix problem were account creation would fail when some characters were used.
  • Fix issue where ‘play’ button would reappear while scrolling through synced content.
  • Fix crash when drawing ‘play’ button in preplay screens.
  • Fix crash opening video settings in Google TV devices.
  • Fix crash resuming a playlist details screen after the app had been in the background for a while.
  • Fix issue that could cause preplay screens to crash.
  • Make sure playlists from the iTunes channel can be played correctly.
  • [Android TV] Fix issue where the ‘Now Playing’ card would sometimes show the wrong video.
  • [Android TV] Fix issue when binding title and subtitle to photo cards could crash.
Plex for Android v4.16.0.472
NEW:
  • Add preference to disable using secure connections to servers.
  • Allow layout selection for home libraries (grid, list, folder).
  • Add support for MPEG2 decoding when supported by the local device.
  • Inform the user when the app activates as the result of a previous purchase being detected.
  • [Android TV] Add support for DTS/DTS-HD Passthrough.
FIXES:
  • Update 3rd party AirPlay library.
  • Resolve AirPlay issue where playback wouldn’t start immediately when using AirServer.
  • Resolve remote playback issue where the UI didn’t update playback progress after switching audio, subtitle streams or changing quality.
  • Clean up resources when disconnecting from remote playback.
  • Don’t crash if the video player is closed at the same time that the next video in the play queue starts playing.
  • Fix issue where music playback would stop after unlocking the device screen.
  • Resolve issue when attempting to change volume of a remote player that doesn’t support it.
  • [TV layout] Fix issue where focused item wasn’t highlighted in track lists.
  • [Android TV] Fix issue where movies in a PQ had the “music video” icon.
Plex for Android v4.16.1.473
FIXES:
  • Resolve issue where device would attempt to playback unsupported audio format, resulting in no audio being heard
Plex for Android v4.16.2.475
FIXES:
  • Fix crash trying to play videos in devices with versions of Android older than 4.1 (Jelly Bean).
  • [Android TV] Fix crash when a different filter or view was selected inside a library section.
Plex for Android v4.17.0.484
NEW:
  • New design for Audio Player.
FIXES:
  • Make sure user avatar in the home screen has enough resolution.
  • [Fire TV Stick] Resolve recent audio regression which resulted in center channel not being audible.
Plex for Android v4.17.1.485
FIXES:
  • Fix issue where playing a song could sometimes fail.
