Plex for floor screens in company
Hey there,
is it possible to use regular TVs along with plex to show floor plans and image films on screens? Power and network connection is given. However, somehow a schedule is needed to put TVs on and off (TV feature of course) but also to start plex and the right media. Would a consumer synology be good enough to cast to 4/5 screens in 720 or 1080p (different films)?
Review Plex’s TOS. Pretty sure it limits things to personal use only.
You’re probably better served by a digital signage system. Especially if you need to control display on/off times, schedule media start/stop times, insert ads/scrolls (like stock tickers, weather), etc.
As much as I’d love people using Plex over something else - I think in this case Plex is not for you.
I think for such applications you should look into ‘digital signage’ software. There is at least one open source project which can run on a Raspberry Pi or similar.
Thank you two! I ll look up other products.
Chromecasts/Chromebits might be a good fit for this, Google has digital signage software for them.
Thanks a lot! will look into this!
