Plex for iOS v9.3 and playing to Xbox 360
Long time Plex Pass member.
I have issues on iOS 9.3 in “casting” to Plex on Xbox 360:
  1. sometimes the App crashes the Xbox 360 theatre App causing a disconnect with the app on the Xbox and it freezes
  2. the app times out on the iOS device with an hourglass, and the App only shows the “Stop” button as usable. And then the App spawns an error message that it lost connection with the Media Server.
  3. if you try to go and look at any other content without playing it the Xbox stops playing to bring up the other content, even though you are only browsing it in Plex on the iOS device.
I will try to report any clearer messages, but I was so frustrated. This use to work without issue in previous releases, and it is only now that I found it out.
Thanks,
Brian
