Hello all,
First I want to say that I really tried hard to fix this on my own but I can't find a definitive solution, if there is one, for this. I will try and make this short.
I recently just purchased PLEX Pass and installed the app on my PS3. I have been using PMS for awhile and I am currently using PMS 0.9.11.7. The closest I found related to my issue was a post from 2012 but I could not find a solution in there. Here is the issue:
I have tested various media files but most of my movies are .mp4 extension with:
Video Codec: H.264 - MPEG-4 AVC
Audio Codec: MPEG AAC Audio (mp4a)
When I stream movie and go to the settings option during the movie, it will cap at about 1-2 Mbps showing that as 'best'. This results in artifacts and other noticeable visual elements in the film. I tested the same movie using the PS3 Media Server application and the video streams at a MUCH better quality and is stable around 7-10 Mbps. I love PLEX and do not want to use anything else.
Other information:
-My internet is 30 Mbps/5 Mbps
-Both applications have been tested wireless for the same file so I know it, in all probability, is not the connection.
-Plex on the PS3 is set to the highest, 20 Mbps
-Plex server is set to Transcoding: Automatic. I have tried 'Prefer higher quality encoding' and 'Make my CPU hurt options' but to the same result.
So I thought to come here before I go deeper into config files and other DLNA/Transcode stuff. Please help as this is the last thing I need fixed to have my server set up the way I want it for the household.
Thanks ahead,
Bob
