We’ve released an update to the Plex Pass preview channel - 4.1.13
FIXES:
- Delay lock screen/screensaver initialization after video playback on firmware 7.1.x
- Do not direct play Apple Losseless (ALAC) audio. A firmware regression caused a reboot during playback.
note: We have updated the public version as well, awaiting Roku’s review, and we’ll post when it is officially available.
We’ve released an update to the Plex Pass preview channel - 4.1.14
FIXES:
- [video] Better handle advancing playback on failures
- [video] Fix possible crash on a playback failure (Roku LT and HD)
- Proper fix to delay screensaver/lock screen on 7.1 firmware
The 4.1.14 update has been published to the official channel.
(All changes since 4.1.10)
NEW:
- TV theme music
- Rotten Tomatoes ratings
- Additional movie and episode pivots in playlist screen
- Support to toggle watched status for shows and seasons
FIXES:
- Possible duplicate key presses
- Missing camera and video roll from iOS mobile server
- Missing images while running Plex Media Server in a FreeBSD jail
- Advanced preference to toggle overscan compensation
- Possible issue searching within channels
- Delay lock screen/screensaver after video playback on firmware 7.1
- [music] Possible crash during playback while the screensaver is active
- [music] Make sure the mini player always displays the current track
- [music] Negative timestamp while seeking using Plex Companion
- [music] Refresh Now Playing queue when the screensaver is closed
- [music] Exit screensaver properly when music stops
- [music] Possible memory leak resulting in a crash during playback
- [music] Playback when the sample rate is greater than 96kHz
- [music] Transcode Apple Losseless (ALAC) audio to inhibit reboots
- [video] Start live streams at the current position
- [video] Original/Media Optimized version selection when source is HEVC or VP9
- [video] Use 10/30/60 seconds for x1/x2/x3 using the FWD/RWD buttons
- [video] Loading indicator was hard to see on different backgrounds
- [video] Better handle intermittent video unavailable errors
- [video] Preference to modify the transcode format [Automatic/MKV/HLS]
- [video] Queue and Chapters overlay background color
- [video] Better support to direct stream channel content
- [video] Possible reboot during playback on firmware 7.1
We’ve released an update to the Plex Pass preview channel - 4.1.15
FIXES:
- Possible startup crash if the Roku is using firmware less than 7.0.
The 4.1.15 update has been published to the official channel.
FIXES:
We’ve released an update to the Plex Pass preview channel - 4.1.16
NEW:
FIXES:
- User selection screen is a lock screen by default
- Possible issue transcoding Watch Later (Plex It!) videos
We’ve released an update to the Plex Pass preview channel - 4.1.17
FIXES:
- Do not shuffle all episodes when shuffling a season (regression in 4.1.16)
- OSD progress and end time flicker (regression in 7.1 firmware)
- Show full extras title in video overlay
We’ve released an update to the Plex Pass preview channel - 4.1.18
FIXES:
- [video] Preserve surround sound while converting audio having more than 6 channels when DTS is disabled
The 4.1.18 update has been published to the official channel.
NEW:
FIXES:
- [video] Possible issue transcoding Watch Later (Plex It!) videos
- [video] OSD progress and end time flicker (regression in 7.1 firmware)
- [video] Show full extras title in OSD
We’ve released an update to the Plex Pass preview channel - 4.1.19
NEW:
- Localization
Server Claiming - server sign-in from the client
- Handle remote play button within video settings
- Support for more H.264 Reference Frames (Roku 3 and newer)
- Add local IP address to the startup logging
- Recent search history
FIXES:
- Season episode number visibility
- Caching issue on the WL/R list screen (video progress)
- Better handle discovered servers active connection going away
- Update server button and server list on connection changes
- Scrolling user screen with more than 9 users
- Add a default timeout for all requests (30 seconds)
- Convert 5.1 AAC to preserve surround sound (Roku 4)
- Audio resume support from any screen (album, folders, search)
We’ve released an update to the Plex Pass preview channel - 4.1.20
NEW:
- Added support for Relay connections
- Update server lock status to indicate a relay is in use
- Server button flyouts if connection is relayed or unavailable
- Better handle verifying and testing insecure connections
- Prefer local insecure connection over remote secure connection when insecure connections are allowed
FIXES:
- Convert 5.1ch FLAC to preserve surround sound (7.2 firmware)
- 2ch FLAC was transcoded if Roku was set to stereo (7.2 firmware)
- Add support for downmixing FLAC if Roku is set to stereo (7.2 firmware)
- Recompute available audio decoders on surround sound changes (headphones)
ljunkie
92
We’ve released an update to the Plex Pass preview channel - 4.1.21
FIXES:
- Remove initial relayed playback notification
- Display a secure lock indicator for relayed connections
ljunkie
93
The 4.1.22 update has been published to the official channel.
NEW:
- Localization
- Support for Relay connections
FIXES:
- Default timeout for all requests (30 seconds)
- Convert 5.1ch AAC to preserve surround sound (Roku 4)
- Embedded subtitles were displayed when disabled
- Fix a crash using Plex Companion from Plex Web
- Fix a possible crash transcoding videos on older Roku models
ljunkie
94
We’ve released an update to the Plex Pass preview channel - 4.1.23
FIXES:
- Plex Companion discovery (flinging media to Roku)
ljunkie
95
We’ve released an update to the Plex Pass preview channel - 4.1.24
NEW:
FIXES:
- Multi-part playback of very short parts
- Erroneous server claiming dialog for signed-in servers
ljunkie
96
We’ve released an update to the Plex Pass preview channel - 4.1.25
NEW:
- Transcode reason available in video settings during playback (Press OK on Stream Info -> Playback). Requires PMS v1.2.1 or greater
FIXES:
- Do not restart existing theme music while browsing within the same show (regression in 4.1.24)
- Forced Direct Play (regression in 4.1.24)
- Vertical jump list missing on dropdowns
- Do not display empty pivots (e.g. "More with [Actor]”)
ljunkie
97
We’ve released an update to the Plex Pass preview channel - 4.1.26
FIXES:
- Lower the maximum number of supported refFrames (transcode if number exceeds 9 reference frames).
ljunkie
98
We’ve released an update to the Plex Pass preview channel - 4.1.27
FIXES:
- Raise the max refFrames to 12
- Added workaround for DTS-MA playback failures (transcode to AC3 5.1)
- Improve quality settings selection
- Do not offer 4k unless the video is 4k resolution
- Show the original quality as selected if Direct Played
- Fix a handful of crashes
ljunkie
99
The 4.2.0 update has been published to the official channel.
NEW:
- Streaming Brain support
- Handle remote Instant Replay button while OSD is visible
- Transcode reason available in video settings during playback (Press OK on Stream Info -> Playback). Requires PMS v1.2.1+
- Support for new Roku models (Express/Premiere/Ultra)
- Identify cloud servers and extend connection timeout
- Capability checks for 4k, hevc, vp9, and 1080p@60
FIXES:
- Crash using Plex Companion from Plex Web
- Playing audio from folder view having no subfolders
- Possible crash transcoding videos on older Roku models
- Plex Companion discovery from iOS/Android
- Audio player tweaks for upcoming Roku firmware
- Do not display empty pivots (e.g. “More with [Actor]”)
- Workaround for DTS-MA playback failures (transcode to AC3 5.1)
- Handful of various crashes
ljunkie
100
We’ve released an update to the Plex Pass preview channel - 4.2.1
FIXES:
- Music lyrics using PMS 1.2.x or greater
