Plex for Roku
The 4.0.7 update has been published to the official channel.
NEW:
  • Media Optimizer support (requires Plex Media Server 0.9.14 or greater)
  • Secure connections preference
  • Recursive photo Play Queue support (requires Plex Media Server 0.9.14 or greater)
  • Play On Deck episode when playing from a season containing an episode On Deck
  • Add burned in subtitle preference to the preplay settings
  • Add maximum H.264 level to global video settings
  • Update home and library screen buttons (icons)
  • Tweak the direct play and direct stream settings (“Force” DP with fallback)
  • Add HEVC and VP9 support for the Roku 4
  • Add Apple Lossless support for the Roku 4 (firmware 7+)
  • Show available stream selection count on preplay
FIXES:
  • Fix flinging media from iOS
  • Fix screen flicker starting video playback (Roku 4)
  • Use Roku’s global caption size for subtitle size (burned in subtitles)
  • Hide items scrolling underneath the header
  • Improve user selection screen loading time
  • Overlay scrollbar on all dropdowns and lists
  • Hide the scrollbar after a delay for dropdowns and lists
  • Fix possible missing images in vertical list
  • Fix [music] now playing repeat and shuffle status color
  • Use local video quality for external connections on the same network
  • Fix unnecessary text truncation on the preplay screen
  • Various UI tweaks
We’ve released an update to the Plex Pass preview channel - 4.0.8
NEW:
  • Support for manual connections
  • Roku 4: Support to Direct Play compatible 4k media
FIXES:
  • Add audio seek workaround for Roku’s 7.x firmware
  • Fix using insecure connections if PMS security settings change
  • Better error messaging for failed server connections
  • Fix duplicated photo background while flinging photos
  • Fix misleading video error regarding server transcode support
  • Fix transcoding media in Watch Later and Recommendations (CBS)
  • Exclude grid play/shuffle all when viewing photos by photo albums
We’ve released an update to the Plex Pass preview channel - 4.0.9
FIXED:
  • Proper fix for possible connection testing issue (not testing all connections)
note: We have updated the public version as well, awaiting Roku’s review, and we’ll post when it is officially available.
The 4.0.9 update has been published to the official channel.
NEW:
FIXES:
  • Fix possibility of not testing all available server connections
  • Fix flinging media from a known, but previously unreachable server
note: these are all the includes changes from the last official release (4.0.7)
We’ve released an update to the Plex Pass preview channel - 4.0.10
FIXES
  • Used timed lyrics first if available
  • Fix video playback with mono audio using PMS 0.9.14 or greater
  • Fix playback of FLAC 192kHz files (transcode)
  • Fix avatar background on user selection screen
  • Fix transcoding Watch Later content if a transcode server is available
  • Fix a few possible crashes
We’ve released an update to the Plex Pass preview channel - 4.0.11
FIXES
  • Do not direct play Apple Losseless (ALAC) audio. A firmware regression cause a reboot during playback.
We’ve released an update to the Plex Pass preview channel - 4.1.0
NEW:
  • Custom video player - excludes Roku LT (2400, 2450) and Roku HD (2500)
  • Updated Video Overlay (OSD) - Now with 100% more awesome
  • View and change settings in player
  • View and select chapters in player
  • View, select and modify video queue in player
  • Skip videos using in player controls
  • Shuffle videos in player
  • Repeat one or all videos in player
  • Direct Stream/Transcode using MKV instead of HLS
  • Support to copy DTS, AC3 and EAC3 audio streams while transcoding video
  • Support to copy compatible HEVC/VP9 and 4k video while transcoding audio (Roku 4)
  • Transcoding incompatible subtitles (copy video instead of convert)
  • Select media versions within player (including channels)
  • Support to use Plex screensaver while video is paused
  • Include video stream in the video settings
  • Show stream selection count (availability) in video settings
  • Support audio, video, and subtitle stream selection via Plex Companion
  • Add tri-state subtitle preference - Burn Subtitles: [Always, Automatic [default], Only image formats]
  • Add “Online” quality preference (channels, watch later, vevo, trailers, etc)
  • Support to search within channels
  • Support to handle remote keyboard entry (mobile Roku app)
FIXES:
  • Fix flinging media when screen saver is active
  • Improve loading time exiting screensaver
  • Fix enabling/disabling player controls (in channel and Plex Companion)
  • Only show “Play Next” if a Play Queue exists
  • [video] Fix subtitle sync while transcoding
  • [video] Fix possible crash marking as watched
  • [music] Fix repeat in the audio player
  • [music] Fix button status color for shuffle/repeat
  • [music] Smooth the Now Playing progress bar animation a bit
  • [music] Show mini player when adding items to an empty queue
  • [music] Fix adding a single item to the Play Queue
  • [music] Fix anti-aliasing issue on now playing screen when toggling controls
  • [music] Fix progress time (better lyric sync)
  • Bump default quality preference (specific to Roku model)
      - 4Mbps local/online, 3Mbps remote: Roku LT, Roku HD, Roku Stick
      - 8Mbps local/online, 4Mbps remote: Roku 2 [HD, XD, XS], Roku 1, Roku 2, Roku SE
      - 12Mbps local/online, 4Mbps remote: Other Rokus
  • Improve video playback support for multi-part media (direct play / direct stream / transcode)
We’ve released an update to the Plex Pass preview channel - 4.1.1
  • Fixes a possible crash during startup
  • See the 4.1.0 update for all the exciting details
We’ve released an update to the Plex Pass preview channel - 4.1.2
  • Fix transcoded video playback using servers less than 0.9.14.x.
We’ve released an update to the Plex Pass preview channel - 4.1.3
  • Fix subtitles for image and advanced formats when transcoding or direct streaming.
We’ve released an update to the Plex Pass preview channel - 4.1.4
NEW:
  • Add support for Instant Replay subtitles in the new video player
  • Add support to Direct Play 5.1 AAC/AC3 when the Roku is set to stereo
      - Roku 4 supports downmixing 5.1 AAC audio
      - Roku TV supports downmixing 5.1 AAC and AC3 audio
FIXES:
  • Fix remote back button in video settings overlay
  • Fix a possible delay handling remote key presses
  • Better handle 1080p60 playback
We’ve released an update to the Plex Pass preview channel - 4.1.5
FIXES:
  • Fix 7.1 DTS audio when the video has to be transcoded
  • Fix a handful of crashes
We’ve released an update to the Plex Pass preview channel - 4.1.6
FIXES:
  • Fix available quality options on the Roku 4
  • Fix filters display bug
We’ve released an update to the Plex Pass preview channel - 4.1.7
FIXES:
  • Add support for unwatched indicators in the video player queue
  • Sanitize chapter titles
We’ve released an update to the Plex Pass preview channel - 4.1.8
FIXES:
  • Fix playback of large Play Queues
We’ve released an update to the Plex Pass preview channel - 4.1.9
FIXES:
  • No audio during video playback when audio sample rate is low
  • Watch Later and Recommendations playback failed while connected to a shared server
  • Duplicate key presses moving between episodes using FWD/REV buttons
We’ve released an update to the Plex Pass preview channel - 4.1.10
FIXES:
  • Possible crash during photo slideshow
  • Possible crash trying to play empty playlist
The 4.1.10 update has been published to the official channel.
NEW:
  • New video player - excludes Roku LT (2400, 2450) and Roku HD (2500)
  • Support for the new 4k Roku TV
FIXES:
  • Flinging media when screen saver is active
  • Available player controls (in channel and Plex Companion)
  • Avatar background on user selection screen
  • [video] Subtitle sync while transcoding
  • [video] Possible crash marking as watched
  • [video] Playback with mono audio using PMS 0.9.14 or greater
  • [video] Transcoding WL/R content if a transcode server is available
  • [video] Improve multi-part playback support
  • [video] Better handle 1080p60 playback
  • [video] TV play queues weren’t advancing
  • [video] No audio during playback if audio sample rate is low
  • [video] Watch Later and Recommendations playback failed while connected to a shared server
  • [video] Add support to Direct Play 5.1 AAC/AC3 when the Roku is set to stereo
  • [video] Bump default quality preference (specific to Roku model)
  • [music] Repeat in the audio player
  • [music] Button status color for shuffle/repeat
  • [music] Adding a single item to the Play Queue
  • [music] Anti-aliasing issue on now playing screen when toggling controls
  • [music] Progress time (better lyric sync)
  • [music] Playback of FLAC 192kHz files (transcode)
  • [music] Used timed lyrics first if available
  • [music] Do not direct play Apple Losseless (ALAC) audio (ALAC may cause a reboot)
We’ve released an update to the Plex Pass preview channel - 4.1.11
NEW:
  • TV theme music
  • Rotten Tomatoes ratings
  • Additional movie and episode pivots in playlist screen
  • Support to toggle watched status for shows and seasons
FIXES:
  • Possible duplicate key presses
  • Missing camera and video roll from iOS mobile server
  • Missing images while running Plex Media Server in a FreeBSD jail
  • Advanced preference to toggle overscan compensation
  • Possible issue searching within channels
  • [music] Possible crash during playback while the screensaver is active
  • [music] Make sure the mini player always displays the current track
  • [music] Negative timestamp while seeking using Plex Companion
  • [music] Refresh Now Playing queue when the screensaver is closed
  • [music] Exit screensaver properly when music stops
  • [music] Possible memory leak resulting in a crash during playback
  • [music] Playback when the sample rate is greater than 96kHz
  • [video] Start live streams at the current position
  • [video] Original/Media Optimized version selection when source is HEVC or VP9
  • [video] Use 10/30/60 seconds for x1/x2/x3 using the FWD/RWD buttons
  • [video] Loading indicator was hard to see on different backgrounds
  • [video] Better handle intermittent video unavailable errors
  • [video] Preference to modify the transcode format [Automatic/MKV/HLS]
  • [video] Queue and Chapters overlay background color
  • [video] Better support to direct stream channel content
We’ve released an update to the Plex Pass preview channel - 4.1.12
FIXES:
  • Possible reboot during video playback on firmware 7.1.x
  • PMS “Now Playing” displayed a video as transcoding during Direct Play
