Plex HDR problems (even with direct play)
Server:
  • Windows 11
  • Plex Server Version 1.41.5.9522
  • Intel Core i5-12600K (Intel® UHD Graphics 770)
  • Ethernet (1Gig fibre internet)
Everything is working well otherwise (instant media loads local and remote) but I couldn’t help but notice that HDR looks pretty bad.
To make sure I wasn’t imagining it I tested with some media on a device under these parameters:
  • Macbook Pro (M1 with latest Sequoia OS)
  • brightness set to max with automatic brightness turned off
  • same 4K episode of TV show with hybrid Dolby Vision / HDR10+ / HDR
HDR format: Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2094 App 4, Version HDR10+ Profile B, HDR10+ Profile B compatible
  • Test A - Plex Mac app Version 1.108.1.307-dd5b87aa (to ensure direct play) accessing via local network
  • Test B - IINA Player (supports HDR and falling back to HDR from Dolby Vision Profile 8+, but not Dolby Vision Profile 5)
The problem is that the HDR looks great on the media player (B) but does not look right on Plex via the official app (A). Below is a link to a gallery that shows the issue I am having,
Or here is a timeslide GIF that will also show it but in lower quality:
And I will again confirm that Plex is delivering the media via Direct Play and not transcoding.
Any advice would be appreciated. Thanks!
Happening to me now too
Unfortunately I don’t have any fix yet :frowning:
Next I plan to do some tests on my OLED. To make it a fair test I will add the media to a USB and play via the native WebOS player and see how HDR looks. Then I will play via the Plex app (I can test both the TV Plex and the Xbox Plex) and see how it looks.
If I see more results that suggest Plex is making HDR look poor then I will have to think about canceling my Plex pass. I have 8 family/ friends using my server and they only have Plex pass for this reason, they will also all be cancelling if I drop Plex, so Plex only hurt themselves with this poor experience then not offering any insights.
Dows your Mac support HDR? The Plex app does not convert from HDR to SDR. It will play it as is. If you need the video converted to SDR, enable this on your server.
@MovieFan if my Mac didn’t support HDR then how would the media player I used in Test B show HDR perfectly. I detailed it all in the initial post.
Do you have any media you can test which only has the HDR10 layer, not Dolby Vision (just as a test)? My experience is that Dolby Vision in this environment (Plex App on Mac) can have a kind of dim, green hue; however, HDR10 looks great. I just performed so quick tests to confirm that.
Plex has had some DV issues recently but I think they’re working on sorting them out.
This reminds me somewhat of a Roku Ultra 4k issue with certain x265 files where it would be saturated in red and it took YEARS for them to finally fix it… It would happen on Plex but also outside of Plex… so it was a Roku issue they finally fixed.
The current player just does not want to direct play or transcode my video here with the AppleTV plex player. Same issue with ipad pro M2, iphone 15 pro, however it works perfectly with emby on all platforms in directplay, it works on my MAC with plex direct play. So, it seems like the new player has a nice bug here…
When did they finally fix this? I’ve been avoiding HEVC/x265 files for years because of it.
