Server Version#: 1.21.3.4046
Player Version#: 4.51.1
I just went onto Plex to watch something and I see that its showing Recently Added Movies 2x and Recently Added TV is gone. I clicked the Edit on the Corner and tried to play around with Manual vs Automatic. When I do Manual plex shows Unreachable. Not sure how to fix this.
Are these issues exclusive to the native Plex apps for Windows/Mac?
Do you get different results with the web app https://app.plex.tv ?
If using the web app, try this:
Set it to automatic.
Then verify that all libraries, of which you want to see content on your home page, have been pinned to the sidebar.
Maybe unpin, re-pin a few.
These libraries must also not have set their Visibility to âExclude from home screenâ (in the properties of the library, on the âAdvancedâ tab).
Afterwards, try clearing the cache of the web browser and force-refresh the web app.
Do you still see the âhubsâ on the âRecommendedâ tabs of your library?
If so, what happens if you remove the currently empty hubs from your home page and add them anew?
Or inspect them yourself. Take a look at the Plex Media Server.log file and seek for messages about database corrupt or malformed.
If you find these, you may have to repair your database.
Feb 22, 2021 11:58:38.668 [8140] ERROR - SQLITE3:0xba988c3, 11, database corruption at line 79051 of [bf8c1b2b7a]
Feb 22, 2021 11:58:38.668 [8140] ERROR - SQLITE3:0xba988c3, 11, statement aborts at 47: [select distinct section_locations.root_path,path,metadata_items.parent_id,metadata_items.id,media_items.id from directories join media_parts on media_parts.directory_id=directories.id
Feb 22, 2021 11:58:38.668 [8140] ERROR - Soci Exception handled: sqlite3_statement_backend::loadRS: database disk image is malformed
