Server Version#: 1.29.2.6364-6d72b0cf6
Player Version#: 1.30.1.3391-8c2e653b
Rebuilt my kitchen display using Ubuntu running Plex HTPC. Had it running MCE on Windows 7 for years and wanted something newer. Swiping to scroll/navigate does not work on the screen. Using the wireless micro media keyboard works fine, but a good deal of the usability is killed when the touchscreen does not function fully. Tapping works fine, the OS sees the screen and it works fine in pretty much every other app Iāve tried. Just not Plex
So if I install and use the Desktop app for Linux that will fix my issue? Iāll go ahead and give that a go. I really like the interface on HTPC, Iām hoping it wonāt be too different on the Desktop app.
I guess my problem is that where this is set up sometimes Iāll be right up at the screen, swiping around for something to watch. Other times Iāll be across the room using a remote. So I need both versions at the same time. Easiest thing would be is if the UI rendering was different but everything else stayed the same. Keep everything under the hood the exact same code base and the ācoverā different depending on your need.
So, web app using Firefox is no go, no touch scrolling. Using Opera does give me the touch scrolling in the web app though. Using the Linux version of Desktop also gives me the touch scrolling. The UI is not as nice as the HTPC version though, and I canāt find where to turn on the Photos screen saver.
After playing with the various options it looks like Iāll stay with the HTPC and deal with the limited functionality. Iāll have a remote nearby and supplement it with touch control.
If they could enable the touch navigation like in Desktop and include a Back arrow in the top corner, this would be perfect. An option to enable those in the settings would allow this version to accommodate the many people who are looking for exactly this.
I might still play around with versions of windows with the player clients. The HTPC GUI is best for my setup because the icons are larger. The desktop GUI works with the touch navigation but itās harder to hit the smaller icons and the layout isnāt as good as the HTPC GUI. Might have to roll back to Windows 7 MCE worst case.
