Hey man I hope the tone of my previous message didn’t come across as accusatory or condescending in any way. I was merely offering my very limited and quite possibly very incorrect understanding of what may be going on. Maybe @anon18523487 can chime in to better summarize the issue as he initially pointed out if was likely due to the missing audio bitrate metadata
Anyway here’s a snippet of the PMS Server Log during playback:
Mar 17, 2020 23:22:22.574 [0x7f82777fe700] DEBUG - We're going to try to auto-select an audio stream for account 584228.
Mar 17, 2020 23:22:22.574 [0x7f82777fe700] DEBUG - Selecting best audio stream for part ID 85683 (autoselect: 1 language: en)
Mar 17, 2020 23:22:22.574 [0x7f82777fe700] DEBUG - Audio Stream: 195723, Subtitle Stream: -1
Mar 17, 2020 23:22:22.575 [0x7f82777fe700] DEBUG - Streaming Resource: Attempting to create AdHoc transcode session 186b4c124410f9dd-com-plexapp-android
Mar 17, 2020 23:22:22.575 [0x7f82777fe700] DEBUG - MDE: Selected protocol hls; container: mpegts
Mar 17, 2020 23:22:22.575 [0x7f82777fe700] DEBUG - MDE: analyzing media item 81473
Mar 17, 2020 23:22:22.575 [0x7f82777fe700] DEBUG - MDE: E6 - Short Treks: Q&A: Direct Play is disabled
Mar 17, 2020 23:22:22.575 [0x7f82777fe700] DEBUG - MDE: E6 - Short Treks: Q&A: media must be transcoded in order to use the hls protocol
Mar 17, 2020 23:22:22.575 [0x7f82777fe700] DEBUG - MDE: E6 - Short Treks: Q&A: no direct play video profile exists for http/mkv/h264
Mar 17, 2020 23:22:22.575 [0x7f82777fe700] DEBUG - MDE: E6 - Short Treks: Q&A: no direct play video profile exists for http/mkv/h264/eac3
Mar 17, 2020 23:22:22.576 [0x7f82777fe700] DEBUG - MDE: Star Trek: Discovery - E6 - Short Treks: Q&A: selected media 0 / 81473
Mar 17, 2020 23:22:22.576 [0x7f82777fe700] DEBUG - Streaming Resource: Required bandwidth unknown (media requires deep analysis) Changing decision parameters provided by client to fit bandwidth limit of 200000kbps
Mar 17, 2020 23:22:22.576 [0x7f82777fe700] DEBUG - Streaming Resource: Determining preferred transcode encoders through transcode only decision.
Mar 17, 2020 23:22:22.576 [0x7f82777fe700] DEBUG - Scaled up video bitrate to 6522Kbps based on 1.500000x fudge factor.
Mar 17, 2020 23:22:22.577 [0x7f82777fe700] DEBUG - Scaled up video bitrate to 6522Kbps based on 1.500000x fudge factor.
Mar 17, 2020 23:22:22.577 [0x7f82777fe700] DEBUG - Streaming Resource: Reducing playback quality for 190476kbps stream bitrate: video resolution to 1248x520, audio channels to 6, quality to 99, disable video DS as 2147483647kbps is > the 6489kbps available, disable audio DS as 2147483647kbps is > the 768kbps available
Mar 17, 2020 23:22:22.578 [0x7f82777fe700] DEBUG - MDE: Selected protocol hls; container: mpegts
Mar 17, 2020 23:22:22.578 [0x7f82777fe700] DEBUG - MDE: analyzing media item 81473
Mar 17, 2020 23:22:22.578 [0x7f82777fe700] DEBUG - MDE: E6 - Short Treks: Q&A: Direct Play is disabled
Mar 17, 2020 23:22:22.578 [0x7f82777fe700] DEBUG - MDE: E6 - Short Treks: Q&A: media must be transcoded in order to use the hls protocol
Mar 17, 2020 23:22:22.578 [0x7f82777fe700] DEBUG - MDE: E6 - Short Treks: Q&A: no direct play video profile exists for http/mkv/h264
Mar 17, 2020 23:22:22.578 [0x7f82777fe700] DEBUG - MDE: E6 - Short Treks: Q&A: no direct play video profile exists for http/mkv/h264/eac3
Mar 17, 2020 23:22:22.578 [0x7f82777fe700] DEBUG - MDE: E6 - Short Treks: Q&A: Direct Streaming is disabled, so video stream will be transcoded
Mar 17, 2020 23:22:22.578 [0x7f82777fe700] DEBUG - MDE: E6 - Short Treks: Q&A: no remuxable profile found, so video stream will be transcoded
Mar 17, 2020 23:22:22.578 [0x7f82777fe700] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Mar 17, 2020 23:22:22.578 [0x7f82777fe700] DEBUG - Scaled up video bitrate to 6522Kbps based on 1.500000x fudge factor.
Mar 17, 2020 23:22:22.578 [0x7f82777fe700] DEBUG - MDE: E6 - Short Treks: Q&A: Audio Direct Streaming is disabled, so video's audio stream will be transcoded
Mar 17, 2020 23:22:22.578 [0x7f82777fe700] DEBUG - MDE: Cannot direct stream audio stream due to profile or setting limitations
Mar 17, 2020 23:22:22.578 [0x7f82777fe700] DEBUG - MDE: Star Trek: Discovery - E6 - Short Treks: Q&A: selected media 0 / 81473
Mar 17, 2020 23:22:22.579 [0x7f82777fe700] DEBUG - Streaming Resource: Adding session 0x7f827c76bcf0:186b4c124410f9dd-com-plexapp-android which is using 7620kbps of WAN bandwidth. Used is now 7620kbps
Mar 17, 2020 23:22:22.579 [0x7f82777fe700] DEBUG - Streaming Resource: Adding session 0x7f827c76bcf0:186b4c124410f9dd-com-plexapp-android which is using transcoder slot. Used slots is now 1
Mar 17, 2020 23:22:22.579 [0x7f82777fe700] DEBUG - Streaming Resource: Added session 0x7f827c76bcf0:186b4c124410f9dd-com-plexapp-android
Mar 17, 2020 23:22:22.579 [0x7f82777fe700] DEBUG - Streaming Resource: Reached Decision id=38475 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=81473 part=(id=85683 decision=transcode container=mpegts protocol=hls streams=(Video=(id=195722 decision=transcode bitrate=6489 encoder=libx264 width=1248 height=520) Audio=(id=195723 decision=transcode bitrate=768 encoder=aac channels=6 rate=48000))))
If it was unclear your help is very much appreciated. Thank you again for looking into this for me. Cheers
Edit: Streaming Resource: Reducing playback quality for 190476kbps stream bitrate: video resolution to 1248x520, audio channels to 6, quality to 99, disable video DS as 2147483647kbps is > the 6489kbps available, disable audio DS as 2147483647kbps is > the 768kbps available
This line specifically made me think it was doing some kind of whacky estimation but I freely admit I really have no clue what’s going on there
