Plex is creating THOUSANDS OF PLAYLISTS
Yesterday I started using Playlists for the first time in order to sync my music to my mobile phone.
I created a playlist by mistake and immediately deleted it afterwards. Now today, I noticed my PMS created the playlist 9000 TIMES!!!
After struggling to delete all the playlists, it simply started re-creating the playlist over and over again till again it reaching over 9000 entries. I have deleted the media that was referenced by the playlist, so they are all blank but PMS keeps on re-creating the delete playlists for some reason.
Anyone have this problem? Removing the Music and re-adding the library does not help. Is there a way to manually delete all playlist entries from the database?
I myself have 3000+ entries… this was after the last (Beta) update I did which would have been the last revision.
Are you using PlexKodiConnect?
see Playlist bug is creating thousands of copies of the same playlist over and over
