Plex is faulty and doesn't work for me like it promises
Server Version#: 1.15.4.994
Player Version#: 3.95.2
I’ve been using Plex for about a week, and it is extremely dysfunctional for me.
  • Remote access fails constantly
  • It’s slow, even when on a localhost
  • Streaming videos drop out often
  • Not user-friendly at all
  • Crashed completely once, forcing me to reboot my NAS and reinstalling Plex onto it
  • Bought a Plex pass for hardware transcoding, doesn’t allow me to use it, even if my NAS is compatible
  • In fact, no features of Plex Pass are usable, like I don’t even have it, except it says on my account that I do
If these problems don’t get resolved soon, I’m cancelling my subscription and looking for another server software, because this is pissing me off.
What model NAS?
What do you mean by slow? Slow navigation in the GUI, slow to start streaming, etc.
You won’t see a speed difference using Plex Web pointed directly at the NAS or via https://app.plex.tv/desktop. The media streams directly from Plex Media Server to the Plex client. FYI, the hosted version at plex.tv is updated more frequently than the version included with PMS. You should use the hosted version if possible.
If you are watching media on a PC or Mac, suggest you try Plex Media Player instead of the web client. Plex Media Player is a much more capable client than Plex Web. It will direct play many more audio & video codecs. It does not have the limitations imposed by the various web browsers that affect Plex Web (no H265 support, limited audio codecs, etc).
DS918+, brand-spanking-new.
Both. I’m specifically talking about the iPhone app, since that’s the main thing I’m testing right now. The web browser’s GUI is also slow, though I haven’t streamed on it since I don’t have a need to.
I haven’t tried Plex.tv yet, I’ll look into it.
Thanks for the tip. I’ll remember that when I start to stream to computers.
You’re running PMS directly on the DS918+, no docker, virtual machine, etc., correct? It is best to avoid the overhead of Docker/VMs/etc on a low power CPU such as the Celeron in the 918+. I think it will also interfere with the ability to use hardware accelerated transcoding (I can’t say for sure, as I’ve never run PMS via docker/vm/etc on my 918+).
For the transcoding, what settings do you have in PMS Settings → Transcoder?
Try leaving Transcoder Quality = Automatic, and make sure the Use hardware acceleration when available box is checked (select “Show Advanced” to make this visible).
Now play something that transcodes or force a transcode by lowering the quality during playback (ex: force 480p playback of a 1080p video).
With Plex Web, go to Status → Dashboard from the Home page. Click on the gold box thing (hamburger bar?) to the right to show details. b
What do you see? If transcoding is being accelerated, you’ll see (hw), like in the picture below.
A video transcode has two parts: First, the video is decoded from its native format; Second, it is encoded into the a new format. Both parts may be accelerated. That is why you see two (hw) in the pic below. One for decoding from HEVC and one for encoding to H264.
Note that audio will always be transcoded on the CPU. VC1 video will also be transcoded on the CPU (some older Blu-ray discs have video in VC1 instead of H264).
You should avoid video transcoding whenever possible, especially with 4K material. The iGPU ASIC in the Celeron can handle one 4K transcode and two or three 1080p transcodes. However, there are some instances where PMS will transcode video on the CPU (such as with VC1 video) and the Celeron in the 918+ just doesn’t have enough horsepower.
I run PMS on a 918+ and it works quite well for me. However, I rarely transcode video. My primary client is a Nvidia Shield, which direct plays almost everything.
a
My setup:
Nvidia Shield <—> Denon 4300H <—> LG B7 OLED
PMS 1.15.6.1079 on DS918+
Thanks for your advice, but I just so happened to have found the solution to Hardware Transcoding just as you posted. Apparently, Synology, by default, installs the 32-bit version of PMS. I didn’t know this. Manually installing the 64-bit version solved that. Transcoding now works perfectly. In fact, most of my problems seem to be fixed now. I can’t thank you enough. I use a 4K TV, but don’t currently own anything 4K. I hope to change that in the future, once I get the proper drives I want. right now, I’m using throwaways just to get Plex and everything else working for when I make it more permanent.
Since I’m pretty new to the NAS scene, I wouldn’t even know how to use dockers or VMs, or the benefit of doing so. I’m hoping the hardware is good enough to be streamed to a few devices at the same time in 1080 from a few towns away.
I didn’t mention the 32-bit / 64-bit thing because I didn’t think the 32-bit version would run on the 918+. Synology made some changes in DSM a few months back that was supposed to stop that.
You should always download updates from Plex. Do not use the Synology Package Center. Synology does not host the 64-bit version of PMS in the Package Center.
You can follow the PMS Release thread to be notified when a new release is available.
Anyway, glad you have things working.
Cheers.
