Plex is not seeing embedded subtitles in MKV file
Hello all. I’m having a problem with my plex client on all my devices (iOS, TVOS, and ROKU). I’m trying to get subtitles from an MKV file. The movie in question is The Fellowship of the Ring Extended Edition. If I play the file(s) using VLC on my windows desktop all the subtitle files are there and they play just fine. The Plex Client doesn’t see them.
The only wrinkle I can think of is that the movie is in two parts due to length. I’ve got them set up to chain together and appear as one title in the client.
The folder housing the 2 mkv files for each part looks like this:
The Lord of the Rings The Fellowship of the Ring (2001)/
The Lord of the Rings The Fellowship of the Ring (2001) - pt1
The Lord of the Rings The Fellowship of the Ring (2001) - pt2
I don’t know if this is part of the problem or not. Thank you in advance for any help offered.
Is this the only movie with embedded subtitles or do you have other movies in the same library which work with embedded subtitles?
Can you please copy the contents of the Plex XML info of this movie into a post here (don’t worry if it doesn’t show up at first, I can repair it.)
Other subtitles in other movies work fine. Thank you for the quick response. Here is the XML:
Not sure if that went through. Its now telling me the post is too long. Will split it up:
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="1" librarySectionTitle="Movies" librarySectionUUID="6210d357-42b4-4c9c-a89b-88a7c60ff934" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1576861888">
<Video ratingKey="4394" key="/library/metadata/4394" guid="com.plexapp.agents.imdb://tt0120737?lang=en" studio="WingNut Films" type="movie" title="The Lord of the Rings: The Fellowship of the Ring" titleSort="Lord of the Rings: The Fellowship of the Ring" librarySectionTitle="Movies" librarySectionID="1" librarySectionKey="/library/sections/1" contentRating="PG-13" summary="Young hobbit Frodo Baggins, after inheriting a mysterious ring from his uncle Bilbo, must leave his home in order to keep it from falling into the hands of its evil creator. Along the way, a fellowship is formed to protect the ringbearer and make sure that the ring arrives at its final destination: Mt. Doom, the only place where it can be destroyed." rating="9.1" audienceRating="9.5" viewOffset="2593000" viewCount="1" lastViewedAt="1579593876" year="2001" tagline="One ring to rule them all" thumb="/library/metadata/4394/thumb/1579547754" art="/library/metadata/4394/art/1579547754" duration="13698780" originallyAvailableAt="2001-12-18" addedAt="1579389992" updatedAt="1579547754" audienceRatingImage="rottentomatoes://image.rating.upright" chapterSource="media" primaryExtraKey="/library/metadata/4395" ratingImage="rottentomatoes://image.rating.ripe">
<Media id="7279" duration="13698780" bitrate="7039" width="1920" height="1080" aspectRatio="1.78" audioChannels="7" audioCodec="dca-ma" videoCodec="h264" videoResolution="1080" container="mkv" videoFrameRate="24p" audioProfile="ma" videoProfile="high">
  <Part accessible="1" exists="1" id="7280" key="/library/parts/7280/1579388791/file.mkv" duration="6343420" file="M:\WellsMedia\Movies\Movies\The Lord of the Rings The Fellowship of the Ring (2001)\The Lord of the Rings The Fellowship of the Ring (2001) - pt1.mkv" size="29299871425" audioProfile="ma" container="mkv" deepAnalysisVersion="4" requiredBandwidths="39190,38596,37836,37643,37458,37282,37017,37017" videoProfile="high">
    <Stream id="15414" streamType="2" selected="1" default="1" codec="dca" index="1" channels="7" bitrate="4718" language="English" languageCode="eng" audioChannelLayout="6.1" bitDepth="24" profile="ma" requiredBandwidths="5524,5266,5025,4884,4793,4793,4793,4793" samplingRate="48000" title="Surround 6.1" displayTitle="English (DTS-HD MA 6.1)"/>
    <Stream id="15415" streamType="2" codec="dca" index="2" channels="7" bitrate="1509" language="English" languageCode="eng" audioChannelLayout="6.1" bitDepth="24" profile="es" requiredBandwidths="1509,1509,1509,1509,1509,1509,1509,1509" samplingRate="48000" title="Surround 5.1" displayTitle="English (DTS-ES 6.1)"/>
    <Stream id="15416" streamType="2" codec="ac3" index="3" channels="2" bitrate="192" language="English" languageCode="eng" audioChannelLayout="stereo" requiredBandwidths="192,192,192,192,192,192,192,192" samplingRate="48000" title="Stereo" displayTitle="English (AC3 Stereo)"/>
    <Stream id="15417" streamType="2" codec="ac3" index="4" channels="2" bitrate="192" language="English" languageCode="eng" audioChannelLayout="stereo" requiredBandwidths="192,192,192,192,192,192,192,192" samplingRate="48000" title="Stereo" displayTitle="English (AC3 Stereo)"/>
    <Stream id="15418" streamType="2" codec="ac3" index="5" channels="2" bitrate="192" language="English" languageCode="eng" audioChannelLayout="stereo" requiredBandwidths="192,192,192,192,192,192,192,192" samplingRate="48000" title="Stereo" displayTitle="English (AC3 Stereo)"/>
    <Stream id="15419" streamType="2" codec="ac3" index="6" channels="2" bitrate="192" language="English" languageCode="eng" audioChannelLayout="stereo" requiredBandwidths="192,192,192,192,192,192,192,192" samplingRate="48000" title="Stereo" displayTitle="English (AC3 Stereo)"/>
  </Part>
  <Part accessible="1" exists="1" id="7284" key="/library/parts/7284/1579392062/file.mkv" duration="7355360" file="M:\WellsMedia\Movies\Movies\The Lord of the Rings The Fellowship of the Ring (2001)\The Lord of the Rings The Fellowship of the Ring (2001) - pt2.mkv" size="33967091844" audioProfile="ma" container="mkv" deepAnalysisVersion="4" requiredBandwidths="41384,40009,39056,38437,38142,37896,37375,37375" videoProfile="high">
    <Stream id="15431" streamType="2" selected="1" default="1" codec="dca" index="1" channels="7" bitrate="4762" language="English" languageCode="eng" audioChannelLayout="6.1" bitDepth="24" profile="ma" requiredBandwidths="5534,5415,5215,4993,4984,4984,4984,4984" samplingRate="48000" title="Surround 6.1" displayTitle="English (DTS-HD MA 6.1)"/>
    <Stream id="15432" streamType="2" codec="dca" index="2" channels="7" bitrate="1509" language="English" languageCode="eng" audioChannelLayout="6.1" bitDepth="24" profile="es" requiredBandwidths="1509,1509,1509,1509,1509,1509,1509,1509" samplingRate="48000" title="Surround 5.1" displayTitle="English (DTS-ES 6.1)"/>
    <Stream id="15433" streamType="2" codec="ac3" index="3" channels="2" bitrate="192" language="English" languageCode="eng" audioChannelLayout="stereo" requiredBandwidths="192,192,192,192,192,192,192,192" samplingRate="48000" title="Stereo" displayTitle="English (AC3 Stereo)"/>
    <Stream id="15434" streamType="2" codec="ac3" index="4" channels="2" bitrate="192" language="English" languageCode="eng" audioChannelLayout="stereo" requiredBandwidths="192,192,192,192,192,192,192,192" samplingRate="48000" title="Stereo" displayTitle="English (AC3 Stereo)"/>
    <Stream id="15435" streamType="2" codec="ac3" index="5" channels="2" bitrate="192" language="English" languageCode="eng" audioChannelLayout="stereo" requiredBandwidths="192,192,192,192,192,192,192,192" samplingRate="48000" title="Stereo" displayTitle="English (AC3 Stereo)"/>
    <Stream id="15436" streamType="2" codec="ac3" index="6" channels="2" bitrate="192" language="English" languageCode="eng" audioChannelLayout="stereo" requiredBandwidths="192,192,192,192,192,192,192,192" samplingRate="48000" title="Stereo" displayTitle="English (AC3 Stereo)"/>
  </Part>
</Media>
</Part>
2nd part:
Judging by the file size, I think these are full Bluray remuxes, right?
Apart from the subtitle issue, I think you will get better results if you merge the two files to get one, contiguous file.
See [HowTo]: joining multi-part movies files with MKVtoolnix GUI
When you drag the first part into mkvtoolnix, as described in the above link, do you see the subtitle tracks listed?
Hey this worked like a charm. Thank you very much. Its better too that I’m down to only one file. Much thanks.
